"What did you do with your Thing today"?
Page: Previous  1, 2, 3 ... 79, 80, 81, 82  Next
GI Joe
GI Joe is offline
PostPosted: Mon Nov 28, 2016 8:02 am    Post subject: Re: "What did you do with your Thing today"? Reply with quote
Poor timing there Zig!! Our Things have a mind of their own sometimes! You were being punished for not driving her enough. 😂
I've had the same issues in the past, and I must highly suggest you get a battery tender and keep her hooked up when not in use. My first battery went bad after just 18months.... I replaced And installed a battery tender and haven't had an issue since! I have them on everything with a battery around here, that doesn't get used daily...(mower, tractor, vw trailer winch box, motorcycles, and Our Thing)..
'74 Thing, "Our Thing"....Blue 181
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...p;start=60
'71 Beetle RPU
http://www.thesamba.com/vw/forum/viewtopic.php?p=8080337#8080337
www.NLEOMF.com
Respect, Honor, Remember
ALANSD
ALANSD is offline
PostPosted: Wed Nov 30, 2016 3:01 pm    Post subject: Re: "What did you do with your Thing today"? Reply with quote
I have a battery "minder" on my 911. The batteries last 6 years or more with this thing.
AngelDeVille
AngelDeVille is offline
PostPosted: Wed Nov 30, 2016 3:28 pm    Post subject: Re: "What did you do with your Thing today"? Reply with quote
installed a horn, charging port, and tonight an inverter and Christmas Lights for the parade on Saturday.
Sent via two tin cans connected by a string and a jailbroken Atari 2600...
Suck it up, Buttercup!
63ziggy
63ziggy is offline
PostPosted: Wed Nov 30, 2016 3:40 pm    Post subject: Re: "What did you do with your Thing today"? Reply with quote
yep, using a battery tender, well at least when I remember to plug it in.
in reality, I will take 9 yrs. we actually had bought the battery long before our Thing was together or road worthy. battery served us well.
View user's profile Send private message Send e-mail AIM Address Instagram Gallery Classifieds Feedback
GI Joe
GI Joe is offline
PostPosted: Thu Dec 01, 2016 11:08 am    Post subject: Re: "What did you do with your Thing today"? Reply with quote
I fixed my fuel gauge isssue! Could narrow down if it was the gauge, or vibrator, so I swapped them both from my Burnt Truggy body! Back in bidness!!(and I need gas BAD!!!)
'71 Beetle RPU
www.NLEOMF.com
Bohemia
Bohemia is offline
PostPosted: Sat Dec 03, 2016 4:20 pm    Post subject: Re: "What did you do with your Thing today"? Reply with quote
Changed the gear oil in transmission. I'm the second owner and this is the first time I've done this so I'm thinking it is 43 year old oil.
oasis
oasis is offline
PostPosted: Sat Dec 03, 2016 4:23 pm    Post subject: Re: "What did you do with your Thing today"? Reply with quote
With rehab and recovery going well, I felt confident getting Thing out of storage for a few drives. Today, towards the end of my errand hopping, I noticed it was idling faster -- 1200-1300 rather than its usual 800-900.
From the last errand heading home, it was pure hell to drive.
Its idle kept increasing. That also meant the RPMs increased when going from gear to gear. By the time I got near my home, I was shutting the engine off at stop lights and stop signs because it wanted to rev over 3,000.
The gas pedal seems to stay lower than usual -- quite pronounced now. With the engine off and Thing parked, I could manually pull the roller looking thingy backwards. I'm guessing when I try to start it again and have to prime the pedal, it will not return.
My next decision is to whether to tow it to the shop I have been going to years, or tow it further. The shop has changed ownership, and my confidence in them has waned a bit -- especially with air-cooled. It's not their cash cow, and their attention to detail has be wondering.
My guess is it is not that big of a problem. Pure bummer, though, because Thing was running great.
Now: 2003 New Beetle Turbo S / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 1974 Thing Acapulco / 2002 Golf GLS TDI
Past: 2009 Eos Komfort / 1997 Jetta GT / 2002 Cabrio GLX / 2002 Passat GLS / 1971 Super Beetle / 1993 EuroVan MV Westfalia / 1981 Pickup LX / 1985 Vanagon / 1986 Jetta GLI
EDragnDean
EDragnDean is offline
PostPosted: Sun Dec 04, 2016 7:06 am    Post subject: Re: "What did you do with your Thing today"? Reply with quote
carb spring
63 Double Cab http://www.thesamba.com/vw/forum/viewtopic.php?t=443823&highlight=deanos
66 Bus Click to view image
73 Thing http://www.thesamba.com/vw/forum/viewtopic.php?p=8111202#8111202
doublecanister
doublecanister is offline
PostPosted: Mon Dec 05, 2016 11:07 am    Post subject: Re: "What did you do with your Thing today"? Reply with quote
I fired up the THING Saturday, worked on the front brakes, they had been making an awful noise after driving a bit (sounded like a taxi when I applied the brakes) so I roughed up the rotors and it seemed to fix the problem.
used a drill and some 80 grit paper to do the roughing. it worked!
Driving I had a similar problem that Oasis mentioned,
the THING had been sitting somewhat since July, my father was hospitialized in July and I've been "on the run" since he got out and he's much better now Thank goodness but the THING suffered sitting a bit.
It started up easy enough but driving was a different story, after warm up I barely got up to speed for 2nd gear and she bogged out on me, but only once after a 20 min test drive all seemed back to normal.
I also ran the heater a few times on the trip, got to keep the pump from freezing up, but all went well.
I did notice while the front wheel's were off, where you grease the front end I think it's the torsion springs-end caps (there is 2 on each side of the THING) one bout fell off as I was cleaning up some greasy deposits..
How are those little caps supposed to stay on?
Its a bit larger than a quarter or about a 50cent piece size round metal cap.
I used a socket of approximate size and banged it back on with a few taps after cleaning up the extra grease.
Honestly a tad concerned they will just fall out on their own.
any suggestions there?
I didn't take a photo but I'm sure I could if one is required to better explain.
other than that, was a good weekend.
T
73'- Thing
66' -Mustang GT- Fastback
51'- Ford F1 pickup Flathead V8
vw moses
vw moses is offline
PostPosted: Tue Dec 13, 2016 5:38 pm    Post subject: Re: "What did you do with your Thing today"? Reply with quote
got everything i wanted done
now i want a 57beetle w/2387 (that i'll build)
yes, its for sale Shocked
[email protected] moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
convertable-beetle-w/bugspray & screamer dist.(019) gone
"Where There's a Will There's a Way"
BVC
BVC is offline
PostPosted: Wed Feb 15, 2017 6:26 am    Post subject: Re: "What did you do with your Thing today"? Reply with quote
Pulled motor and transmission, changed transmission gear oil, installed new starter, changed all mounts, changed clutch Cable and Bowden tube, cleaned up cv joints , cleaned transmission (some won painted it black! And with all the grease from the old cv boots it was nasty) removed charcoal filter and caped lines. Oh and found a 73 shroud to replace the bug shroud the thing came with Laughing
After I got everything back together discovered a cut cv boot... bummer
Changed that on Monday. Adjusted clutch, cleaned up peddle assembly. Hope to take it for a drive this coming weekend.[img]
[/img]
oasis
oasis is offline
PostPosted: Sun Feb 19, 2017 5:10 pm    Post subject: Re: "What did you do with your Thing today"? Reply with quote
Photoshoot outtake
kenj06
kenj06 is offline
PostPosted: Sun Feb 19, 2017 8:00 pm    Post subject: Re: "What did you do with your Thing today"? Reply with quote
Took the Thing around the block today for a test drive. Couldn't pass up the 60+ February weather in northern Ohio.
Been working on it over the winter, disc brakes on the front, check the shift linkages and install a quick shift kit and new boot, change the tranny oil, inspect and repack the rear bearings and CV joints. Need to adjust the rear brakes and re-bleed since the pedal is low, rear sounds and feels good after replacing a sketchy cv joint, noise is gone in the tranny too.
Still enough winter left to pull the top frame to straighten then clean out the carb.
Mountain man
Mountain man is offline
PostPosted: Wed Feb 22, 2017 11:28 pm    Post subject: Re: "What did you do with your Thing today"? Reply with quote
I usually just hide in the shadows and watch what everyone else is doing but I'm kinda proud I made the decision to cut the dash and install some switches. Up until now I have added parts but not cut anything. Anyway it's done and I think it looks cool. I also had some work done on my bumper.
doublecanister
PostPosted: Thu Mar 09, 2017 11:27 am    Post subject: Re: "What did you do with your Thing today"? Reply with quote
finally had warm enough weather to paint my rear engine tin part.
Now to just install it!
T
73'- Thing
74superTN
74superTN is offline
PostPosted: Fri Mar 31, 2017 6:00 pm    Post subject: Re: "What did you do with your Thing today"? Reply with quote
purchased my 73
73 Thing
DKK - Deutsche Kafer Klub
www.dkk-savannah.blogspot.com
www.georgiadubs.com
911pickup
911pickup is offline
PostPosted: Sun Apr 02, 2017 7:24 am    Post subject: Re: "What did you do with your Thing today"? Reply with quote
Those wheels look great on your car.
I'm pulling the engine and tranny on my newly acquired Thing. The tranny pops out of second gear and the driver's side cover plate has a serious leak.
I'm on the last engine-to-tranny bolt (the one behind the fan shroud) and it's not cooperating.
I don't think the engine has been out for a long time and the 17mm wrench I'm using isn't very long, so it's hard to get the needed leverage/force to loosen the nut.
I think I'll need to slide a piece of pipe over the end of the wrench to give it some leverage.
GI Joe
GI Joe is offline
PostPosted: Fri Apr 07, 2017 7:55 pm    Post subject: Re: "What did you do with your Thing today"? Reply with quote
Woke Our Thing up from a short winter slumber. My Volksrod project is taking up what little shop space I have, so she was stored in the barn for a month or so..
Turned the kill switch, pumped the accelerator a few times and she fired right up!!
Took her to the house for a MUCH needed detail, which I only got about 75% finished.... I'll finish the rest up when we get to Buga-Paluza tomorrow!
'71 Beetle RPU
www.NLEOMF.com
oasis
oasis is offline
PostPosted: Mon Apr 10, 2017 6:31 am    Post subject: Re: "What did you do with your Thing today"? Reply with quote
Nice!
I did the same sort of thing yesterday with my Thing. It took a few extra pumps of the accelerator, but she fired right up after two or so months of dormancy.
Sadly, I only backed her out of storage -- the "barn" for suburbanites Laughing -- so I could transport my lawn mowers and other summer toys home and put away the snow blower, shovels and other winter toys.
Good for you! I hope to do my detailing this week. More sadly, my endeavors will be more to sell her than anything ... but I hope to get more enjoyment out of her before she changes hands.
My Dalmatian would love your farm. I have to drive all over to find trails and such so he can go off-lead and be a dog without upsetting the leash law police.
74superTN
PostPosted: Fri Apr 14, 2017 6:08 pm    Post subject: Re: "What did you do with your Thing today"? Reply with quote
Took it for a beach cruise last weekend in Daytona Beach, during No Dough.
73 Thing
www.georgiadubs.com
Page 80 of 82
