wmp100 Samba Member
Posted: Mon Apr 17, 2017 10:21 am Post subject: Shaking at high speeds |
| My standard beetle has just recently started shaking consistently at speeds of 60 or higher. The whole front end was just replaced maybe 1000 miles ago with new moog parts and I just checked it all and it's solid. Is this a wheel balance issue? The shaking seems to be coming from the right side and it shakes the whole car and pulls it to the left, but the shaking is periodic. I'll get it to sixty it will shake then smooth out then shake again consistently. The tires don't look to be wearing irregularly, but this just started over the weekend. Any thoughts? |
anthax Samba Member
Joined: October 21, 2016 Posts: 317 Location: Hälsingland, Sweden
Posted: Mon Apr 17, 2017 10:26 am Post subject: Re: Shaking at high speeds |
| Lost balance weight on one of the front rims. |
air-h2o-air Samba Member
broken belts or cords in either or both frt tires...or balance issue
jack up and spin each tire and look for any runout....or out of round....if found ...replace that tire.
if no runout or out of round found....balance both frt tires |
pfrancescutti Samba Member
Joined: January 26, 2015 Posts: 44 Location: Victoria BC
Posted: Mon Apr 17, 2017 1:13 pm Post subject: Re: Shaking at high speeds |
What was included in the "The whole front end was just replaced" work?
I don't think a wheel balancing problem would make the car pull to the left but I've been wrong before. |
wimkever Samba Member
Joined: July 16, 2004 Posts: 439 Location: Holland (the Netherlands)
Posted: Tue Apr 18, 2017 5:19 am Post subject: Re: Shaking at high speeds |
| pfrancescutti wrote: |
You're not the only one.
_________________ a beetle is like a cocker spaniel, always funny but sometimes not listening |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23945 Location: SHALIMAR ,FLORIDA
Posted: Tue Apr 18, 2017 7:31 am Post subject: Re: Shaking at high speeds |
| shake rattle and roll...vw's mantra. as for the issue. check the breaks for the pulling issue. and for the shake I kinda like chockalate.....check&retighten the wheel bearings, check as in pull drum/rotor all see if there good or dead then replace/regreessee if nessary add some greessee(i like the thin syn stuff) and make sure there tight. not snug but tight then back off a little bearings like this have to have a preload. not just a little. as I recall arkwuled just sent out wheel bearing tightening instructions,you might check thier site. or... a good manul. I do mine by feal but Ive done it all my life,most people thing there just turn the nut till tire dont shake any more with your hand. that aint it. probably another half turn. |
Posted: Tue Apr 18, 2017 7:56 am Post subject: Re: Shaking at high speeds |
For background. the reason I asked what was replaced on your front in is I experienced bad shaking on my front end, usually at speed while braking. I thought it was the brakes so I decide to replace them. While I was at it I decided to upgrade to discs. When I was tightening the last caliper bolt I noticed this:
well $4i7 |
wmp100 Samba Member
Posted: Tue Apr 18, 2017 4:09 pm Post subject: Re: Shaking at high speeds |
| The ball joints, tie rods, shocks, bearings, damper were all replaced. Everything is super solid. I am going to have the tires balanced tomorrow as it can't hurt. I will check the bearings though, I may have adjusted them wrong. What is the correct procedure for tightening the spindle nut so that it is not too loose or too tight? |
wmp100 Samba Member
Posted: Wed May 10, 2017 1:36 pm Post subject: Re: Shaking at high speeds: Solved! |
| Just an update for anyone who might need it later on, I solved the shaking issue! After having my front wheels balanced, and replacing my rear shocks and alot of head scratching nothing changed. I finally decided to rotate my front and rear tires and lo and behold the problem was the rear right tire! I never once thought of this, but about a day before this problem started I put slime tire sealant in that tire on my way home from school. I only drove a mile or two after putting it in and then it sat all night. My guess is that because I didn't drive it very far with the slime, it hardened in one clump on the tire and the resulting loss of balance caused the shaking. My dad followed me on the highway and said that he could see that tire hopping 2-3 inches off the ground! Lesson learned I guess. Am I right in saying that you must drive for a while after putting the slime in? It sealed the tire fine, I think Im gonna take that tire off and really see whats going on in there. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33414 Location: Hot Arizona
Posted: Wed May 10, 2017 2:16 pm Post subject: Re: Shaking at high speeds: Solved! |
| wmp100 wrote: |
#1 Since it started right after adding the Slime, that should've been a really good hint.
#2 On the other hand, a mile or two is a lot of revolutions, so I'm surprised the Slime did not distribute evenly. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Holey42001 Samba Member
Joined: January 13, 2017 Posts: 94 Location: Fresno, CA
Posted: Sat Jun 24, 2017 5:12 pm Post subject: Re: Shaking at high speeds |
I have a very similar issue with mine (even the same side and pull to the left) except mine starts at ~44mph. I might go and rotate the tires too for kicks and giggles. Who knows, it might solve the issue on mine too.
EDIT: Front left wheel was slightly out of round, shaking issue solved _________________ Post...edit...post...edit....
If it’s not leaking oil, there probably isn’t any left.
1973 Standard Bug
1972 MG Midget
1973 Hilux w/flatbed & crate motor
1989 Aero & Adams FV |
