Adjusting Motometer oil pressure switch
Peter_N
Peter_N is offline
PostPosted: Fri Apr 14, 2017 6:26 am    Post subject: Adjusting Motometer oil pressure switch Reply with quote
Hi All,
I found out the oil pressure switch on my 36hp was leaking so I bought a new one. At closer inspection there's a tiny screw in both of them.
After some searching on thesamba I could only find an ad, saying this kind of switch is a period performance part with adjustable pressure cutoff value.
At first I didn't measure any cicuit on the new one so I thought it was broken.
But with some tweaking of the screw I can sometimes get a reading. When I turn it slightly it brakes the circuit again.
Does anyone know what measurement I should get (ohms?) for a standard 36hp? Or should is always give a reading?
Thanks! Any help is appreciated
My 1958 PGSG project topic
Eric&Barb
Eric&Barb is online now
PostPosted: Mon Apr 17, 2017 8:45 pm    Post subject: Re: Adjusting Motometer oil pressure switch Reply with quote
That type of switch should be just an on/off, nothing in between.
In Stereo, Where Available!
Peter_N
Peter_N is offline
PostPosted: Wed Apr 19, 2017 12:19 am    Post subject: Re: Adjusting Motometer oil pressure switch Reply with quote
Thanks for your feedback.
I've asked for another one from the seller and he'll send me one free of charge.
Hopefully that one is functional and leak free, otherways I'll go the repop route.
