The Stupid Question Thread
Page: Previous  1, 2, 3 ... 320, 321, 322 ... 513, 514, 515  Next
cv66seabear
cv66seabear is offline
PostPosted: Mon Apr 24, 2017 5:20 am    Post subject: Re: The Stupid Question Thread Reply with quote
KentPS wrote:
cv66seabear wrote:
I literally ordered every part for the brakes, drums pads, springs, etc. I know it's overkill but I thought it might be best just to totally rebuild them, plus it never hurts to learn something new!
Thanks again,
Kent
Excellent logic and fantastic reasoning!
It must have something to do with the name. Laughing
But BusDaddy is right.... Keep all your old parts to make sure the new ones are gonna work. Did you get brake hoses too? They're simple enough to replace and should be done regularly.
You got that right! I'll be looking at everything. Bought the brake parts at JBugs, so I hope the fit is right.
"Not all who wander are lost." JRR Tolkien
1979 Campmobile - "Pancho Verde"
Old Friends - gone now:
1964 Beetle "Liebchen"
Mark 3 Jetta "Liebchen Zwei"
Passat Wagon "Wolf"
2015 Passat Sedan "Rudy"
beatles4
beatles4 is offline
PostPosted: Mon Apr 24, 2017 9:44 am    Post subject: Re: The Stupid Question Thread Reply with quote
Wildthings wrote:
beatles4 wrote:
Hey guys, I have taken apart my axles and have removed the cv joints to repack and install new boots but I ran into a snag. The snap rings clips that are on the end of the axles that prevent the cv joint from sliding off too far were damaged in the removal process. From inspecting the axle it looks like either an e clip or a snap ring would work best. Any idea what size I would need or what other people usually do?
My idea was something that looks like this but I have no idea what the correct size would be.
https://www.summitracing.com/parts/rnb-933-940?sei...hgoda9ULHQ
Buy yourself a pair of duckbill snap ring pliers so you don't have to fight so hard getting the snap rings on and off.
That is precisely what I used. Well, actually I used a Knipex 90 degree bent snap ring plier but the ends of the clip kept slipping off of the plier.
Click to view image
http://www.vw-mplate.com/mplate2-27771.png
Wildthings
Wildthings is offline
PostPosted: Mon Apr 24, 2017 2:31 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Duckbill pliers are flat on the ends with a small indent in each bill to solidly hold onto the ends of the external retaining ring. Very useful tool.
lil-jinx
lil-jinx is offline
PostPosted: Mon Apr 24, 2017 6:41 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Wear safety glasses,they are Snap rings.
1968 Dune Buggy
1974 parts bus
Flores726
Flores726 is offline
PostPosted: Mon Apr 24, 2017 8:10 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Hey guys. So I'm new to this whole VW scene. I have a fortin shifter but it only goes into shift pattern but no reverse. Could I be able to use this on my 74 bug?
Thanks
alman72
alman72 is offline
PostPosted: Tue Apr 25, 2017 5:23 am    Post subject: Re: The Stupid Question Thread Reply with quote
Thanks
are you pushing down to get it into reverse? and if you are new, do you know that reverse is not like other shift patterns? it is on the left side of the H, and down.
RixiesRide
RixiesRide is offline
PostPosted: Tue Apr 25, 2017 11:09 am    Post subject: Re: The Stupid Question Thread Reply with quote
The screws that hold the turn signal housing together seem to have been lost. Im on my way to the hardware store now to see what I can find. Any clue as to what size I should be looking for?
Also the itty bitty screws that attach the turn signal lever to the housing is missing one screw on each side.
Thanks
1973 Wild Westerner "Mr. Peabody"
1967 Beetle "Sherman"
http://s13.photobucket.com/albums/a269/RixiesRide/WW/
jonasbegood
jonasbegood is offline
PostPosted: Tue Apr 25, 2017 1:15 pm    Post subject: Re: The Stupid Question Thread Reply with quote
If you have a 30 amp generator, how much amps can you safely pull from it?
alman72
alman72 is offline
PostPosted: Tue Apr 25, 2017 2:04 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Thanks
turn signals are different thru the years. whatchagot?
Flores726
PostPosted: Tue Apr 25, 2017 2:20 pm    Post subject: Re: The Stupid Question Thread Reply with quote
alman72 wrote:
Thanks
If I push down it's solid and doesn't budge. Yes I've drivin a VW before and I am familiar with the shift pattern. Lol.
RixiesRide
PostPosted: Tue Apr 25, 2017 2:56 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Thanks
It's for a '73. I ended up buying a pkg of each #6-32x3/4, #8-32x3/4 and #6-32x1/2.
Thank you Alman72
busdaddy
busdaddy is offline
PostPosted: Tue Apr 25, 2017 3:22 pm    Post subject: Re: The Stupid Question Thread Reply with quote
RixiesRide wrote:
Thanks
Thank you Alman72
But all the fasteners on a VW are metric, none of those will work.
Слава Україні!
alman72
alman72 is offline
PostPosted: Tue Apr 25, 2017 4:51 pm    Post subject: Re: The Stupid Question Thread Reply with quote
they may work if installed with anger. I do not recommend installing anything angry
RixiesRide
PostPosted: Tue Apr 25, 2017 5:36 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Arrrgh!
alman72
alman72 is offline
PostPosted: Fri Apr 28, 2017 6:04 pm    Post subject: Re: The Stupid Question Thread Reply with quote
found a cold start valve in my stash. 022 906 171 A
google says for a 914 1.7? only one hit, so not sure, so here I am. any chance of interchange on a transporter? 1979? other?
edit-this pic from 914 world ebay link, not mine, but mine is the same
aerosurfer
aerosurfer is offline
PostPosted: Fri Apr 28, 2017 8:18 pm    Post subject: Re: The Stupid Question Thread Reply with quote
itll work just fine
Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone)
Terminatez
Terminatez is offline
PostPosted: Sun Apr 30, 2017 12:02 am    Post subject: Re: The Stupid Question Thread Reply with quote
What would be the optimal compression ratio for a Type 4 2.0 engine using the camper special kit from the type4store on a 72 camper bus loaded with the furniture. Preferably a weekend driver / sometimes daily.
1972 Westfalia P30 hardtop Campmobile [On-going Restoration]
aeromech wrote:
I don't think I've ever seen an engine in worse shape.
cv66seabear
PostPosted: Mon May 01, 2017 7:11 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Another day, another stupid question.
I'm adding a second battery to help ensure I don't drain my starting battery. 1979 Campmobile.
I have a few questions:
1. The stock alternator produces about 70amps, do I need to/or even can I change to a higher output alternator? Is 70a enough to charge both batteries?
2. When plugged into shore power, is the main battery being charged, and therefore the aux battery would be too, or is shore power going straight to the circuit breaker and then to the outlets (one big extension cord)?
3. If the circuit breaker/shore power is not already linked to the battery, can I link the shorepower to with the Bluesea ACR I'll be using, to help charge batteries?
4. What do you guys use to put a kayak on the top of the poptop?
As always, thanks for your help!
Kent
Passat Wagon "Wolf"
The Dubbernaut
The Dubbernaut is offline
PostPosted: Tue May 02, 2017 8:42 am    Post subject: Re: The Stupid Question Thread Reply with quote
Finally found the owner of this bay! But, Ive never dealt with a Riviera and not sure what this plate is. Can you decode this like the M-Plate? Ill post the M-Plate as soon as I can but the door was jammed and there is too much stuff in the way to get to the plate. So I got the VIN plate and this one.
2012 Tiguan 4motion
2 Corrado's
3 Beetle's
76 Bus
2 Baja's
66 Pigalle Squareback
80 Rabbit
80 Rabbit Pickup
and still collecting!
alman72
alman72 is offline
PostPosted: Fri May 05, 2017 2:22 pm    Post subject: Re: The Stupid Question Thread Reply with quote
79 fi bus sat along time before I got it. can the fuel pump be cleaned? gasket set somewhere? as I am not a huge purest, is there a suggested aftermarket pump? thanks
Page 321 of 515
