Mr. Okrasa Original Old Speed
Joined: May 20, 2000 Posts: 726 Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
txoval Samba Member
Joined: January 23, 2004 Posts: 3540 Location: The Woodlands, TX
Posted: Tue Mar 07, 2017 10:35 am Post subject: Re: Twin Webers on a 36 hp engine |
Finally done...
I highly recommend the Sync-Link linkage. It may not fit the Vintage Speed theme, but it is the best linkage I have used. Trust me, CB Hex bar and CSP did not cut it.
I am not saying those are bad linkages, but for a 36HP engine with dual 2bbl carbs, which is rare, they do not work well...too many modifications needed.
Currently running, 57 idles, 120 mains, 180 airs, F11's, and 27mm vents
I'm still playing with the idles/mains, but it currently is running smooth. |
JeeWee Samba Member
Joined: February 05, 2011 Posts: 120 Location: Garijp, the Netherlands
Posted: Thu Mar 16, 2017 4:39 am Post subject: Re: Twin Webers on a 36 hp engine |
Looks great, it's different but looks very clean! any plans to put it on the dyno? |
txoval Samba Member
Posted: Tue Apr 25, 2017 6:01 pm Post subject: Re: Twin Webers on a 36 hp engine |
It's been a while, but I finally have this pig tuned
For others that go this route:
57 idles, 107.5 mains, 180 airs, F11's, 45 power jets, and I had custom 24mm chokes (venturis) made by Jaycee. The chokes may have been overkill, but I wanted to increase port velocity for better drivability. Top end would benefit from 26mm vents.
If you plan your engine build for dual Webers or Dellortos, I highly recommend that you go with a 69.5mm stroke or bigger, and larger pistons. Boost compression to high 7's or 8's. My 64mm x 77mm engine with 7:1 compression has low vacuum and makes tuning a pain.
The power is much improved, I just should have stroked the engine during the original build. That's my two cents...much better than the dual single 32's |
carreraparts Samba Member
Posted: Fri May 05, 2017 7:00 pm Post subject: Re: Twin Webers on a 36 hp engine |
Updated picture...just waiting on a part to complete the hex bar.
I made this high flow breather system, you can bolt on without drill. It has two valve vents, one case vent and return to both side of carbs (air filter)
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4338 Location: Los Angeles, CA 90016
Posted: Sun May 07, 2017 7:50 pm Post subject: Re: Twin Webers on a 36 hp engine |
It's clean! The best thing to do would be to use an air/oil separator in-line before it goes to the intakes. Oil lowers octane rating. Not an issue maybe with super-mild engines, but higher compression, ragged-edge engines will require it. |
