Strange Cylinder Head Question PLEASE HELP
Page: Previous  1, 2
mark tucker
mark tucker is offline
PostPosted: Sat Apr 15, 2017 10:51 pm    Post subject: Re: Strange Cylinder Head Question PLEASE HELP Reply with quote
if the chamber is in fact too small, then just open it up, unshroud the valves to start with, then cc and see how much more you want and just do it. Shocked hell nikie didnt get where they are by sitting there wishing they could fly through the air.....they had to get pumped first. I see zero issue with using a copper head gasket. and I wouldent run them with out them. dont go wide on the deck clearance,just do the needed chamber work or send them to somebody that can. not realy that hard to do..if you have the stuff to do it with.
DeathBySnuSnu
DeathBySnuSnu is offline
PostPosted: Sun Apr 16, 2017 6:38 am    Post subject: Re: Strange Cylinder Head Question PLEASE HELP Reply with quote
Or
Build a dedicated E85 engine.
williamM
williamM is offline
PostPosted: Sun Apr 16, 2017 8:27 am    Post subject: Re: Strange Cylinder Head Question PLEASE HELP Reply with quote
How much is alcohol now --if you make it from old lawn clippings Question
some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Mon Apr 17, 2017 6:25 pm    Post subject: Re: Strange Cylinder Head Question PLEASE HELP Reply with quote
Those dished pistons and stock chambered heads would be great for boosted apps.
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
midtravelmidengine
midtravelmidengine is offline
PostPosted: Mon Apr 17, 2017 10:41 pm    Post subject: Re: Strange Cylinder Head Question PLEASE HELP Reply with quote
DeathBySnuSnu wrote:
Or
This! ^^^
Take advantage of the cylinder pressure and make some power!
modok wrote:
And I know you don't know because if you did you would know the reason for my knowing you didn't.
youngnstudly wrote:
I just wasn't sure if I should recommend the 1/3 race cam, the 1/2 race cam, or the 5/8 race cam instead...guess it depends on how much of the race he wants to lead???
PumaVW79
PumaVW79 is offline
PostPosted: Tue Apr 18, 2017 4:12 am    Post subject: Re: Strange Cylinder Head Question PLEASE HELP Reply with quote
Or
This! ^^^
These are factory piston to 11/1 compression to run pure ethanol.
Personally I don't like ethanol ...at least not in my cars 😀
By the way, we have here an imposed quota of 27% (E27) in the gas by the government, no pure gasoline from gas pumps.
Jacco Verveer Premium Member
Jacco Verveer is offline
PostPosted: Sun Apr 23, 2017 6:15 am    Post subject: Re: Strange Cylinder Head Question PLEASE HELP Reply with quote
Pistons look nice but not so keen on running E85
nsracing
nsracing is offline
PostPosted: Wed Apr 26, 2017 7:08 pm    Post subject: Re: Strange Cylinder Head Question PLEASE HELP Reply with quote
Those are sweeeeet heads!
So what seems to be the issue of using them? They will work fine.
Just measure your chambers and top of pistons to figure out your compression ratio. Go from there.
PostPosted: Mon May 01, 2017 11:53 am    Post subject: Re: Strange Cylinder Head Question PLEASE HELP Reply with quote
without matching cilinders/pistons? i do not have them
and can i use normal gas/fuel?
PumaVW79
PumaVW79 is offline
PostPosted: Mon May 01, 2017 12:06 pm    Post subject: Re: Strange Cylinder Head Question PLEASE HELP Reply with quote
It will run, but without matching c/p you will end up with .5 inch area of no fins on the top of the cylinders - should expect an increase in temps...
PostPosted: Sun May 07, 2017 7:14 am    Post subject: Re: Strange Cylinder Head Question PLEASE HELP Reply with quote
thanks for the replies
that mahle data was gold
found nos matching cil/pistons Very Happy
Frederik
Frederik is offline
PostPosted: Sat Feb 29, 2020 9:31 pm    Post subject: Re: Strange Cylinder Head Question PLEASE HELP Reply with quote
I have a nos Brazilian longblock engine with those heads and dished pistons. The thread I've asked about it years ago is linked to on page one but the pictures got photo..ucked. Still stand unused in a corner of the garage, but now I need a new engine in my pickup (1600) so came to think about it today and found this thread. If I read the mahle chart correct compression with dished pistons is 7.5:1 and were used with gasoline?
I've also read that they were fitted with dual carbs when used in Brazilian type 2 is that correct? Do you think a dual setup of kadrons or idf40 (what I have) would work or are they to big for the stock engine?
Page: Previous  1, 2
Page 2 of 2
