Turn signal help
MConstable
MConstable is offline
PostPosted: Thu Apr 27, 2017 2:50 pm    Post subject: Turn signal help Reply with quote
My right front turn signal light comes on when I turn on the lights, but it doesn't blink when I hit the turn signal or the hazards. not sure what would cause this, turn signal relay or?
citroen
citroen is offline
PostPosted: Thu Apr 27, 2017 6:55 pm    Post subject: Re: Turn signal help Reply with quote
Have you removed the bulb to make sure it has a double contact bulb and not a single contact
74 Thing
74 Thing is offline
PostPosted: Thu Apr 27, 2017 8:10 pm    Post subject: Re: Turn signal help Reply with quote
It should be the bulb or the contacts for the bulb.
perello
perello is offline
PostPosted: Fri Apr 28, 2017 2:20 am    Post subject: Re: Turn signal help Reply with quote
I found another (funny) source of misbehaviour:
the frame that holds the speedo is hold by 4 screws to the car frame...right?
well yesterday I saw that the grounding was very loose on that frame, by fixing it better I got rid of many electrical gremlins I had on the turn signal!
Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200
MConstable
PostPosted: Thu May 11, 2017 9:35 pm    Post subject: Re: Turn signal help Reply with quote
I have the double contact bulb, could it be the turn signal relay?
cecil
cecil is offline
PostPosted: Wed May 24, 2017 12:22 pm    Post subject: Re: Turn signal help Reply with quote
Instructions on You Tube on how to test relay.....easy
I may not be that funny or athletic or good looking or smart or talented....I forgot where I was going with this
I have this wierd desease called "must tear everything up and put it back together when there's nothing wrong with it...Itus."
