tobiism Samba Member
Joined: January 21, 2004 Posts: 502 Location: Chandler AZ
Posted: Wed Apr 26, 2017 2:38 pm Post subject: Baja build, 82x94 with single weber, and the older Panchitos |
I'd like to use a single dual weber(mainly for simplicity sake and all the horror stories I hear about running dual carbs offroad). What would you suggest for cam? I've built a few 2276's for the street but always with dual dual carbs. At what point does duration make the single weber hard to tune? I will make sure the manifold has preheat. On the street I've run the FK8(awesome!), and right now the FK45(awesome!).
My main use for the baja(full weight with cage) will be riding the rocky, sandy trails we have around here in Phx. I need torque and don't need a high revving machine.
I usually run tight squish and as much compression as the cam will allow. I don't mind running premium fuel.
Thanks in advance.
Parts that I have right now:
case
010 distributor
2x44 hpmx 2nd gens and 2x48 Weber IDFs
Panchitos 40x35
82mm crank
94 Mahles
scat rods
1 5/8 tri mill
stock, 1.25 and 1.4 rockers
31x10.5 tires with 4.37 ring and pinion, 1st through 4th TBD _________________ "There has never been a genius without a hint of madness."
-Albert Einstein
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Wed Apr 26, 2017 2:49 pm Post subject: Re: Baja build, 82x94 with single weber, and the older Panchitos |
What size rear tires and what gearing in the transaxle? _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Wed Apr 26, 2017 3:26 pm Post subject: Re: Baja build, 82x94 with single weber, and the older Panchitos |
ah yes thank you.
I will amend the post
31x10.5 with 4.37 and rest of the gear tailored to suit _________________ "There has never been a genius without a hint of madness."
-Albert Einstein |
Posted: Wed Apr 26, 2017 3:41 pm Post subject: Re: Baja build, 82x94 with single weber, and the older Panchitos |
I'd suggest the 1.4 rockers with FK-7 or FK-43 _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
RailBoy Samba Member
Joined: March 10, 2008 Posts: 2904 Location: Virginia
Posted: Wed Apr 26, 2017 3:50 pm Post subject: Re: Baja build, 82x94 with single weber, and the older Panchitos |
Don't forget to Tune by Cylinder #3(Furthest), and #2(Closets) When Reading Plugs.. Tuning Jets..... Timing too......
I got 4 Second 0-60 mph when all out with my Single 44 IDF on a Redline Single Carb Intake w/Heat on a Engle 120 Cam Driven 2110 on my Street Rail, And put a few thousand miles on her with same old plugs, man she moved..... RB _________________ [quote="smitty24"]"HELP, I ported my own heads and now have fire coming out my ass" .[/quote]
Posted: Thu Apr 27, 2017 7:42 am Post subject: Re: Baja build, 82x94 with single weber, and the older Panchitos |
vwracerdave wrote: |
I'd suggest the 1.4 rockers with FK-7 or FK-43 |
Thosr are definitely worth a look, thanks! _________________ "There has never been a genius without a hint of madness."
-Albert Einstein |
Posted: Thu Apr 27, 2017 7:43 am Post subject: Re: Baja build, 82x94 with single weber, and the older Panchitos |
RailBoy wrote: |
I got 4 Second 0-60 mph when all out with my Single 44 IDF on a Redline Single Carb Intake w/Heat on a Engle 120 Cam Driven 2110 on my Street Rail, And put a few thousand miles on her with same old plugs, man she moved..... RB |
Thanks for the tuning reminders! _________________ "There has never been a genius without a hint of madness."
-Albert Einstein |
Paul.H Samba Member
Posted: Sat Apr 29, 2017 4:16 am Post subject: Re: Baja build, 82x94 with single weber, and the older Panchitos |
tobiism wrote: |
Thanks in advance.
case
010 distributor
Panchitos 40x35
82mm crank
94 Mahles
scat rods
1 5/8 tri mill
31x10.5 tires with 4.37 ring and pinion, 1st through 4th TBD |
If you go for the single IDF through stock end castings you won't make much more than 100hp so you might as well sell all that lot in your list |
Posted: Sat Apr 29, 2017 5:04 am Post subject: Re: Baja build, 82x94 with single weber, and the older Panchitos |
There are other end casting out that breath better than stock.. Dyno made some, plus there is Fat Performance that is in service. Then you can always opt for the CB Turbo's.
Thing is intake, Redline has bigger plenums than stock plus heat, both DRD and aircooled.net sell it. The Redline intake has heat that goes to the bottom of the carb, so with mine I just waited and took my time for about 15 mins. till the carb got hot then she ran great in winter.. But some fabrication maybe needed of the exhaust to run the heat, but well worth it.. RB _________________ [quote="smitty24"]"HELP, I ported my own heads and now have fire coming out my ass" .[/quote]
Paul.H Samba Member
Posted: Sat Apr 29, 2017 5:13 am Post subject: Re: Baja build, 82x94 with single weber, and the older Panchitos |
RailBoy wrote: |
Thing is intake, Redline has bigger plenums than stock plus heat, both DRD and aircooled.net sell it. The Redline intake has heat that goes to the bottom of the carb, so with mine I just waited and took my time for about 15 mins. till the carb got hot then she ran great in winter.. But some fabrication maybe needed of the exhaust to run the heat, but well worth it.. RB |
If there are bigger end castings then yes but if using stock 1600 castings then it doesn't matter what you do upstream from them and they don't work well much above 4500rpm either |
Posted: Sat Apr 29, 2017 5:30 am Post subject: Re: Baja build, 82x94 with single weber, and the older Panchitos |
My Rev Limit on my Street Rail was 5,000 RPMs do to the use of HD Single Valve Springs, so, you may be right or wrong, but you can portstock end castings to an extreme and I know Off Road Fat Engines tack higher. Fat is a good resorce for they have been building off road engines for decades and are still around.. So a call into them maybe needed. RB _________________ [quote="smitty24"]"HELP, I ported my own heads and now have fire coming out my ass" .[/quote]
Posted: Sat Apr 29, 2017 8:36 am Post subject: Re: Baja build, 82x94 with single weber, and the older Panchitos |
Thanks for the info guys. After seeing a previous thread I may use my current Street engine and build a plenum manifold with 4 runners to my tall match ported 48idf manifolds. _________________ "There has never been a genius without a hint of madness."
-Albert Einstein |
