IntrstlarOvrdrve Samba Member
Posted: Mon May 01, 2017 5:40 pm Post subject: Paint for blue Bosch Screamer distributor? |
I dug up an old thread where Glenn said he gave up trying to find a match for the paint about 5 years back..but has anyone found a "close enough" match? It doesn't have to be dead nuts accurate, I just want to freshen mine up as most of the original paint has since flaked off. _________________ Tennessee, Tennessee, ain't no place I'd rather be |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Mon May 01, 2017 6:29 pm Post subject: Re: Paint for blue Bosch Screamer distributor? |
PM Glenn |
EverettB Administrator
Joined: April 11, 2000 Posts: 69823 Location: Phoenix Metro
Posted: Tue May 02, 2017 5:54 am Post subject: Re: Paint for blue Bosch Screamer distributor? |
Thanks! I hadn't found that thread in my search. I did some more digging last night, I know this isn't really correct either (it's just as correct as the blue on the dist you posted!) but at least it's hammertone. I might give it a shot.
http://www.tcpglobal.com/HAM-41150.html?gclid=CKG60sic0dMCFRc9gQodXI8AUA#.WQh95Wd1vIU
And if all else fails, what black paint is everyone painting their distributors in? _________________ Tennessee, Tennessee, ain't no place I'd rather be |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76938 Location: Sneaking up behind you
Posted: Tue May 02, 2017 6:05 am Post subject: Re: Paint for blue Bosch Screamer distributor? |
NOS
BTW, they were black 019s that were complete and then painted over including the hardware. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue May 02, 2017 6:54 am Post subject: Re: Paint for blue Bosch Screamer distributor? |
Thanks, Glenn! I'd known there were just painted over, in fact mine is about half black again.
Like I said, if all else fails I'll just paint it back to black. I just wanted to clean it up a little and thought it would be cool blue again. What are you using to paint them black? _________________ Tennessee, Tennessee, ain't no place I'd rather be |
Glenn Mr. 010
Posted: Tue May 02, 2017 6:58 am Post subject: Re: Paint for blue Bosch Screamer distributor? |
IntrstlarOvrdrve wrote: |
Like I said, if all else fails I'll just paint it back to black. I just wanted to clean it up a little and thought it would be cool blue again. What are you using to paint them black? |
I use a satin black finish.
Left is NOS and right is restored.
Member #1009
#BlueSquare |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Tue May 02, 2017 9:51 am Post subject: Re: Paint for blue Bosch Screamer distributor? |
The original black paint was notoriously thin. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Wed May 03, 2017 2:49 am Post subject: Re: Paint for blue Bosch Screamer distributor? |
To be perfectly honest, I don't all that much care for the original screamer blue paint, overspray and sloppy. The black looks good, but the "over restored" one in that thread linked looks great.
On most of the 019 distributors I've tore down, they were mostly the same tone, but one had a bit of a teal tint, more than the usual blue. I personally like the black, and use rustoleum 500 degree engine paint, since it holds up very well. If you use it, do the semi-gloss and throw it in the oven (or hotbox if you have one) for an hour or so at 250 degrees to knock down the shine and cure the paint, it will be stronger faster that way.
It looks less gloss in person, but works great if you go this route...
This is the paint I use-
_________________ 73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087! |
darynoval1 Samba Member
Posted: Thu May 04, 2017 4:46 am Post subject: Re: Paint for blue Bosch Screamer distributor? |
Thanks for posting this! |
Shadd Samba Member
Joined: January 18, 2007 Posts: 883 Location: Lancaster, Ohio
Posted: Tue Jun 13, 2017 7:58 pm Post subject: Re: Paint for blue Bosch Screamer distributor? |
would this match the original screamer? Ive bought it at the local big box hardware store for another project. |
Glenn Mr. 010
Posted: Tue Jun 13, 2017 8:09 pm Post subject: Re: Paint for blue Bosch Screamer distributor? |
Shadd wrote: |
No, it doesn't. _________________ Glenn
Member #1009
#BlueSquare |
