pete000 Samba Member
Posted: Thu May 04, 2017 6:15 pm Post subject: Vintage Speed Stainless Vanagon J-Pipe replacment |
Saw this in the vendor section and figured I would try one out. The quality is really good. Welds are excellent. Stainless seems a little thin compared to the other pipes, but seems very high quality. Came with all the mounting hardware and gaskets. Was pretty easy to put on and it lined up perfectly. Bus seems to like it...It is lighter than the cast iron elbow and J-Pipe combination. Less joints to leak too. Overall I'm impressed.
_________________ 1990 Vanagon RS 2.1
1967 Deluxe 21 window
Koni Shocks
H & R Red Springs
Addco Sway Bars Front-Rear
18 X 7.5 and 18 X 8 OEM Porsche Wheels
Recaro Power-Heated seats |
buildyourown Samba Member
Posted: Thu May 04, 2017 8:15 pm Post subject: Re: Vintage Speed Stainless Vanagon J-Pipe reeplacment |
As someone who welds for a living, those welds actually look like they were done by someone who knew what they were doing.
Thats a rare thing on van exhausts. |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6247 Location: Portland OR
Where's the bung for the O2 sensor? I thought it was on the J pipe. Is it on the cat?
Nevermind. I see it. Looks like a nice replacement. _________________ 89 Westy 2.1 Auto |
jberger Samba Member
Posted: Thu May 04, 2017 8:38 pm Post subject: Re: Vintage Speed Stainless Vanagon J-Pipe reeplacment |
Which vendor did you score this from? |
Posted: Fri May 05, 2017 6:22 pm Post subject: Re: Vintage Speed Stainless Vanagon J-Pipe replacment |
I have a Small Car Performance SS 100 Cell CAT and SS muffler... _________________ 1990 Vanagon RS 2.1
Koni Shocks
H & R Red Springs
whafalia Samba Member
Joined: January 28, 2009 Posts: 685 Location: San Francisco
Posted: Fri May 05, 2017 9:27 pm Post subject: Re: Vintage Speed Stainless Vanagon J-Pipe replacment |
My van badly needs some body/paint attention but that stainless steel exhaust tip could buy me another year, _________________ 84 westie 2.2 w/ digijet, AT |
SCM Samba Member
Joined: January 26, 2011 Posts: 3119 Location: Bozeman MT
Posted: Fri Aug 14, 2020 1:11 pm Post subject: Re: Vintage Speed Stainless Vanagon J-Pipe replacment |
I just put one of these on my van and am happy with it. It's fits great although I still have a small exhaust leak at the upstream end that I was hoping to eliminate. I plan to remove the SS pipe and file the flange of the OE pipes to make the mating surfaces flatter.
It could be my imagination but my butt cheek dyno tells me that I have just a little more oomph between 3k and 4k RPMs.
The sound is a little different. Less of a pulsing thump-thump-thump, and more of a humming, thumm-thumm-thumm. But, again, adding the pipe did eliminate/reduce an exhaust leak that I had.
I'll report back on MPG changes once I run through a couple tanks of gas. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Fri Aug 14, 2020 3:14 pm Post subject: Re: Vintage Speed Stainless Vanagon J-Pipe replacment |
Get a tube of high temp copper silicone. Follow the directions. I attach my race card header to the head with only this, no gaskets. Coat your gasket and assemble. Should seal up fine. _________________ ☮️ |
shadetreemech Samba Member
Joined: October 05, 2005 Posts: 777 Location: Claremont, CA
Posted: Fri Aug 14, 2020 4:11 pm Post subject: Re: Vintage Speed Stainless Vanagon J-Pipe replacment |
SCM wrote: |
The sound is a little different. Less of a pulsing thump-thump-thump, and more of a humming, thumm-thumm-thumm. But, again, adding the pipe did eliminate/reduce an exhaust leak that I had. |
Mine sounds like the Hannibal Twin 8 from the Movie "The Great Race" (you'll note it's rear-engined).
It's got a cannon, too.
1/4 the cylinders and all the rumble. Kind of a deep-throated burble with a hint of that VW chime. At least, so I tell myself.
Nice pipes, SCM.
Dan _________________ '84 GL 1.9
'01 Volvo V70 T5
'88 Westy - "MZDRTHY" |
jlrftype7 Samba Member
Posted: Fri Aug 14, 2020 4:26 pm Post subject: Re: Vintage Speed Stainless Vanagon J-Pipe replacment |
I have their SS Tail Pipe on my stock 1.9:exhaust. I got fed up with the tail pipe that came with the exhaust system kit rusting like crazy no matter what I did to it.
The last straw was when I removed it, sand blasted it to bare metal, painted high temp exhaust paint on it that was holding up fairly well in the rest of the exhaust, and the tail pipe rusted the same as before....
Day that I installed the Vintage Speed part.
_________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
puchfinnland Samba Member
Joined: December 26, 2005 Posts: 279 Location: Deale Maryland
Posted: Sat Aug 15, 2020 5:46 pm Post subject: Re: Vintage Speed Stainless Vanagon J-Pipe replacment |
that pipe is beautiful, is the company still selling it? _________________ ABYC marine master technician , EX European auto technician, new business- EASTCOASTWEST , custom work on campers, only systems, no mechanical |
Yellow Rabbit Samba Member
Posted: Sat Aug 15, 2020 7:21 pm Post subject: Re: Vintage Speed Stainless Vanagon J-Pipe replacment |
I sure could use one of those tailpipes! |
Posted: Sat Aug 15, 2020 7:36 pm Post subject: Re: Vintage Speed Stainless Vanagon J-Pipe replacment |
puchfinnland wrote: |
that pipe is beautiful, is the company still selling it? |
. As far as I know. It shipped from Taiwan straight.
Trying to remember what Vendor I bought it from. I’ll have to look it up... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
sphet Samba Member
Joined: November 09, 2016 Posts: 345 Location: Vancouver, BC
Posted: Sat Aug 15, 2020 8:35 pm Post subject: Re: Vintage Speed Stainless Vanagon J-Pipe replacment |
jlrftype7 wrote: |
Trying to remember what Vendor I bought it from. I’ll have to look it up... |
I saw a stainless tailpipe on cip1 that looks similar:
https://www.cip1.ca/ProductDetails.asp?ProductCode=C31%2D251%2D185%2D025CE _________________ 1982 Diesel Westfalia 1.6 NA - The Shellakabuukiee |
Posted: Sun Aug 16, 2020 5:25 am Post subject: Re: Vintage Speed Stainless Vanagon J-Pipe replacment |
I found it , I ordered thru Aircooled.net back in Feb.
Part Number Item Qty Item Subtotal Grand Total
025-251-185C-VS Vintage Speed Stainless Steel Vanagon Waterboxer Tailpipe, 1983-91 Vanagon (T3), 025-251-185C-VS
1 $44.95 $44.95
^ SETUP $15 Flat Rate Shipping for this item has been added to your Shipping Estimate
1 $0.00 $0.00
Parts Subtotal: $44.95
Tax: $0.00
Shipping Cost: $15.00 _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
