deafen Samba Member
Posted: Thu May 04, 2017 5:39 am Post subject: What carb is this? |
This is on a Thing I'm going to check out this evening (if it doesn't get sold out from under me first!)
I can't find any pictures of any VW carb that has the fuel cutoff solenoid terminal on the rear like this. It doesn't look like any of the applicable Solex's. Any ideas?
doublecanister Samba Member
Joined: September 23, 2008 Posts: 1184 Location: Richmond, Va
Posted: Thu May 04, 2017 9:43 am Post subject: Re: What carb is this? |
I'm guessing it's a piersburg carb.
But that's a guess. I think they were replacements but not 100% sure.
anybody else have any info here? _________________ ****************************************
2020 - Mustang Eco Boost [High Performance]
1973 - Thing
1966 - Mustang GT- Fastback
1951 - Ford F1 pickup Flathead V8 |
deafen Samba Member
Posted: Thu May 04, 2017 11:31 am Post subject: Re: What carb is this? |
Just talked to the seller, and he looked at it and said it was a "Warner". I'm assuming that either he misread, or I misheard, and it's actually a Weber. But it still doesn't match up with any pictures I can find.
He did say it was an "option", but given that the car is an older resto (professionally repainted, engine rebuilt, etc.) I can only assume it was replaced during the engine rebuild. As far as I know, there were no factory or dealer carb "options" for VW in 1974.
So ... probably a Weber. But which one? |
citroen Samba Member
Joined: February 28, 2010 Posts: 1578 Location: louisville ky
Posted: Thu May 04, 2017 12:49 pm Post subject: Re: What carb is this? |
here is the same carb with a manual choke . I sold quite a few of these when I had my store over 20 years ago they was a pretty good little carb . The box said Weber here are a few pictures . you can see the manual jet where the other one has a electric jet you can see the W stamped in the front and the VW Audi on the tag
deafen Samba Member
Posted: Thu May 04, 2017 7:14 pm Post subject: Re: What carb is this? |
Yup, that's the one! So it's a Weber version of the 30 PICT. I got a closer look at this one, and it looks to be Brazilian - I didn't know Weber made anything in Brazil, but who knows?
On this Thing, it's paired with some sort of SVDA. Assuming that everything is working, is there any reason to consider switching to a different carb, if I do buy it? |
Posted: Thu May 04, 2017 7:36 pm Post subject: Re: What carb is this? |
deafen wrote: |
if it works ok use it . It was a good little carb the one I have runs real good on a single port engine |
Posted: Fri May 05, 2017 10:13 am Post subject: Re: What carb is this? |
cool, never seen one of those.
now that I've seen a close up, I can just make out the W in the first pic.
neat!
I 2nd what Citroen says, if it works run it!
and I learned something too. [Thanks Citroen]
T _________________ ****************************************
1973 - Thing
