vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1357 Location: Richmond, VA
Posted: Fri May 05, 2017 11:54 am Post subject: Ruby Red 66 refresh. |
A friend of mine has had this sitting under a cover for years, with the engine and seats stored inside a dry garage for as long as the bug has been outside. It's complete and relatively unmolested, He wasn't a "car guy'" it was just his car back in the day. He offered it to me for $400. My goal is to get the mechanicals sorted out, make it solid and preserve as much of the OG paint as possible. I'd like to eventually use it as fairweather daily driver, hopefully it's not rotten. I haven't seen the car myself in quite some time, these are pictures he sent me. I'm going by tomorrow to see if we can get the tires aired up and wheels turning so I can have it hauled home next weekend. I'll get some more pics then and turn this into a build thread.
_________________ 1973 Superbeetle: 1st car, owned since age 12. Update thread --> https://www.thesamba.com/vw/forum/viewtopic.php?p=9919140#9919140
1966 Beetle: My new project. (SOLD) Build thread--> https://www.thesamba.com/vw/forum/viewtopic.php?t=678040 |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Fri May 05, 2017 1:47 pm Post subject: Re: Ruby Red 66 refresh. |
It is a bit tough to tell, but it almost looks like vegetation might be growing inside the car. |
Jemezcrusher Samba Member
Joined: March 29, 2017 Posts: 14 Location: Jemez Springs NM
Posted: Fri May 05, 2017 7:36 pm Post subject: Re: Ruby Red 66 refresh. |
Yikes stripes!
May be some old pot seeds got established as it does look like something is growing inside |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Fri May 05, 2017 8:38 pm Post subject: Re: Ruby Red 66 refresh. |
That front upper quarter looks rough. Hopefully the rest is in better shape. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
Posted: Mon May 08, 2017 5:55 am Post subject: Re: Ruby Red 66 refresh. |
Well, I went and looked at it Saturday, and it's actually a lot more solid than it looked in those photos the PO sent me. It does have a bit of vegetation inside, but more importantly it also has all it's original unmolested parts! Even factory popouts! The driver's quarter isn't nearly as bad as it looks, it seems to have some bondo work at some point but no rot through. The floor pans and heater channels will need some attention, but the car is cheap enough I won't feel bad about teaching myself how to weld on it. My dad and I also parted out a 66 years ago, so we've still got a bunch of parts squirreled away. All 4 tires took air, and all the wheels turn freely, which was a big relief. It will be coming home sometime this week. I can't wait to get started on it! Here's a bunch of photos I took:
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2180 Location: Laurel Canyon, CA
Posted: Fri May 12, 2017 12:54 pm Post subject: Re: Ruby Red 66 refresh. |
pretty sweet project dude ! it's rough but looks to have not been f-d with. good luck!
BTW, in my opinion, Wolfsburg West makes the best pan halves and Klassicfab makes the best heater channels (or go with original used ones that were cut out of a car) little more pricy than cheaper options but worth it in the long run i think. |
Posted: Mon May 15, 2017 6:00 am Post subject: Re: Ruby Red 66 refresh. |
She's home!! Much more solid than I'd first thought! Also, the blue fender and apron are original red paint underneath the blue! My guess is that someone tried painting the car blue but changed their mind after the did the fender and apron. The orange decklid is a surprise, but that too has OG red paint underneath. This is great news, because it means the car hadn't been wrecked and repaired like I'd first thought!
Where the seats have been since 1997
Ready to head home!
En route
meeting her new little brother
after scrubbing the years of funk off
Tried buffing with rubbing compound and wax, made a difference!
Front floorboards are in much better shape than I'd thought! I think I can save them, just need the rear half panels. The passengers heater channel is pretty rough, but that's the worst spot on the whole car. Rocker section and bottom are pretty good. Drivers side is much better, it's patchable!
Really pleased with how solid this area is!
Jay-Rod Samba Member
Joined: October 06, 2016 Posts: 96 Location: Wheatland, CA
Posted: Mon May 15, 2017 9:37 am Post subject: Re: Ruby Red 66 refresh. |
Im pretty stoked to see how this car comes together. Cool project! _________________ 1963 Beetle |
Posted: Mon May 15, 2017 11:12 am Post subject: Re: Ruby Red 66 refresh. |
So I used some stuff called Rust Mort on the front floor pan sections and other areas that had some exposed surface rust, my dad swears by it. Has anyone used it? Should I put down a layer of POR-15 as well, or would that be redundant? _________________ 1973 Superbeetle: 1st car, owned since age 12. Update thread --> https://www.thesamba.com/vw/forum/viewtopic.php?p=9919140#9919140
Rome Samba Member
Joined: June 02, 2004 Posts: 9653 Location: Pearl River, NY
Posted: Mon May 15, 2017 4:38 pm Post subject: Re: Ruby Red 66 refresh. |
Rust Mort- yes; back in the mid 1980's I first used it on my Ghia pan and body rust control. Then applied Rust-O-Leum enamel paint over the treated metal using a brush on the hidden areas. I still have a bottle of it; I think the local body shop supply store carries it.
The technique I've used in the past few years on heavily rusted small engine parts such as the sled tins, is to clean off the worst of the rust scale using a wire bristle cone-shaped brush on an angle grinder. Wear long-sleeve sweatshirt and of course a face shield in case a bristle flies off. Spray on a rust converter, or the Rust Mort, which chemically neutralizes and stabilizes the rust. Spray on self-etching primer over the entire piece to "eat" into the metal. Spray on filler primer, wet sand with 220, apply more spray filler, wet-sand, then the final color coat which for my engine parts is semi-gloss black. For your floor I would skip the filler primer and the sanding. You could paint the rough treated metal with POR-15, since that paint fills pits nicely and the brush marks disappear. I'd also recommend the black semi-gloss color for a floor or underside of the pan. The POR-15 sticks best to rough surfaces, so that once the original rust is chemically stabilized, the POR-15 will seal the rest of the surface. |
pondoras box Samba Member
Joined: March 22, 2004 Posts: 1226 Location: Eerie PA
Posted: Wed May 17, 2017 6:18 am Post subject: Re: Ruby Red 66 refresh. |
https://www.thesamba.com/vw/forum/viewtopic.php?t=424324&highlight=krylon
Try here, but make sure you read through to see if that has changed, it seems like Krylon changed a few of there colors since this was started.
And its funny how we take something that has sat outside for decades and will not allow to get wet anymore. I am guilty as well as most people on here. I have two non-op VWs in my garage and my daily driver sits out in the rain and snow. _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1961 23 Window (Bobo)
1965 11 Window (Zelda)
1965 13 Window (Lucas)
1957 Oval ragtop
1988 Cabriolet VR6 conversion
Plus a lot of other rusty junk |
cricketseed Samba Member
Joined: August 10, 2015 Posts: 115 Location: North Carolina
Posted: Wed May 17, 2017 6:51 am Post subject: Re: Ruby Red 66 refresh. |
vwuberalles wrote: |
Is there a rattlecan paint that's a fairly close match for Ruby red? |
I had pretty good luck with Rustoleum Regal Red. (If you can find it, try the "Rustoleum Professional" line.)
See my post and photo here:
https://www.thesamba.com/vw/forum/viewtopic.php?p=7909774&highlight=#7909774 _________________ '66 Beetle |
Posted: Wed May 17, 2017 8:07 am Post subject: Re: Ruby Red 66 refresh. |
Also it looks like the paper tubes for the windshield venrs in the trunk have red overspray on them. After looking at pictures of other cars it looks like they have body colored overspray too, was this how it was from the factory? After closer inspection it seems the car has been painted at least once in it's life, but the trunk looks original. There are presumably original wax crayon marks in the trunk between the tank and the dash area. _________________ 1973 Superbeetle: 1st car, owned since age 12. Update thread --> https://www.thesamba.com/vw/forum/viewtopic.php?p=9919140#9919140
GTV Samba Member
Posted: Wed May 17, 2017 8:36 am Post subject: Re: Ruby Red 66 refresh. |
Also it looks like the paper tubes for the windshield venrs in the trunk have red overspray on them. After looking at pictures of other cars it looks like they have body colored overspray too, was this how it was from the factory? |
Nope. _________________ EMPI Power Rules! |
Posted: Wed May 17, 2017 11:48 am Post subject: Re: Ruby Red 66 refresh. |
GTV wrote: |
Nope. |
YES, that is how it was originally. i'm going to try to mimic that when i replace those tubes on my 67. they are the defrost hoses and connect to the front of the heater channels. your car may have had its exterior resprayed once a while back, that is the case with my 67. |
67ctbug Samba Member
Posted: Wed May 17, 2017 11:59 am Post subject: Re: Ruby Red 66 refresh. |
If you want to get that blue and orange off, try acetone on a rag for a few minutes than scrub it off with the rag. _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
