Posted: Fri May 05, 2017 7:44 pm Post subject: Re: The Stupid Question Thread |
alman72 wrote: |
79 fi bus sat along time before I got it. can the fuel pump be cleaned? gasket set somewhere? as I am not a huge purest, is there a suggested aftermarket pump? thanks |
If the pump will run then dumping some fuel injection cleaner into the tank will help both the pump and the fuel pressure regulator, but if the tank is all gummed up and you will need to drain and clean the tank before worrying about the fuel pump.
If you do a search you will find the application and part number for a Ford pump that is an exact bolt in replacement. |
cv66seabear Samba Member
Joined: February 18, 2017 Posts: 105 Location: Wisconsin
Posted: Sat May 06, 2017 6:59 am Post subject: Re: The Stupid Question Thread |
Bought a Trojan T1275 flooded lead acid battery, because of the size, I need to install under the rear seat (79 campmobile), I will need to go through to the engine compartment. I have the rubber spark plug grommet to seal opening, and protect the wires.
Is there a recommended location to drill a hole? Right side, so it goes right to the starter battery? Is the wooden box behind the circuit breaker an inverter? If so, can I hook up to it to charge with shore power?
As always thanks for your insights.
Kent _________________ "Not all who wander are lost." JRR Tolkien
1979 Campmobile - "Pancho Verde"
Old Friends - gone now:
1964 Beetle "Liebchen"
Mark 3 Jetta "Liebchen Zwei"
Passat Wagon "Wolf"
2015 Passat Sedan "Rudy" |
Posted: Sat May 06, 2017 8:21 am Post subject: Re: The Stupid Question Thread |
One more thing- The brtake warning light on the dash does not seem to work, I'm pretty sure, because of the leaking right rear cylinder, and my fluid was done to almost nil. Would a fuse be the cause?
Sorry to ask so many questions, but I'm a total noob on this vehicle!
Passat Wagon "Wolf"
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat May 06, 2017 12:01 pm Post subject: Re: The Stupid Question Thread |
Where you drill is up to you, but be careful you don't hit something important like a brake line on the other side, maybe just outboard of where the heater Y passes by the junction between the sloping rear panel and the cargo floor?
The transformer under the seat was equipped to charge the battery if your control panel has a spring wound timer on it, but 40+ year old technology can't hold a candle to modern smart charge systems. A few members have installed marine systems that automatically isolate the batteries when parked and manage charging as well.
The brake warning light won't tell you if the fluid is low, VW expects you to be smart enough to look at the reservoir now and then, it tells you when 1/2 the system has failed. It should light up when you turn on the key before starting the engine and go out when the charge light does, start with checking the bulb if it doesn't. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat May 06, 2017 1:09 pm Post subject: Re: The Stupid Question Thread |
Thanks!
I'll check the heater spot out. I have no timer (Deluxe Campmobile?), and there looks like a grommet or plug under the seat about 1/2 way up on the left rear slope of the engine compartment (I figure the EC is right behind that slope). I have considered going into the storage on the side, then back and over.
Putting up a hoop garage today. PIA and the wind just picked up. _________________ "Not all who wander are lost." JRR Tolkien
Passat Wagon "Wolf"
RixiesRide Samba Member
Joined: August 31, 2005 Posts: 708 Location: Stockton, CA
Posted: Mon May 08, 2017 10:15 pm Post subject: Re: The Stupid Question Thread |
On Saturday I stopped by my mechanics house to swap the wheels from my '79 to the '73. I noticed that in place of my crappy broken steering wheel in the 73 was a nice new looking steering wheel with the crested horn button and the half circle horn ring. I mentioned to him that wasn't my wheel that mine was all chipped and crappy looking to which he replied "well it's yours now". I didnt want to seem ungrateful so I didn't mention that I didnt think a bug wheel would be interchangeable with a bus wheel.
Other than the size difference are there any other problems with using a bug wheel? _________________ 1973 Wild Westerner "Mr. Peabody"
1967 Beetle "Sherman"
http://s13.photobucket.com/albums/a269/RixiesRide/WW/ |
Kabasue Samba Member
Posted: Tue May 09, 2017 4:29 pm Post subject: Re: The Stupid Question Thread |
what is the name of the tube under the bus that the wiring harness runs through. I need to buy a replacement.
---edit---edit---edit---edit---edit---edit---edit---edit
1 inch pvc pipping, or 1 inch copper pipping will work. The pvc pipping will just slide right in with a little elbow grease. The copper pipping will work but the holes in the chase will have to be enlarged about .5mm. The length is 50 inches (127 centimeters). I rounded up to 52 inches (133 centimeters) so I could have some overhang to work with.
I ended up using the copper pipe because it has more room to run my wiring harness through, plus all the extra wires I wanted to run. There is a slight turn in each part of the frame of the bus which made me have to get out the wife, and the rubber mallet.
--- Search words ---
wiring harness, channel, stove pipe, tube, under the bus. _________________ Remember to get your VW spayed or neutered
71 SB convertible (Finally Finished!)
73 Transporter (next project)
73 Westy with a 411 engine (Finally Finished)
Posted: Tue May 09, 2017 4:48 pm Post subject: Re: The Stupid Question Thread |
Kabasue wrote: |
what is the name of the tube under the bus that the wiring harness runs through. I need to buy a replacement. |
It is just a tube, it has no separate part number as far as I know. The tube is easy enough to replace if you have the wiring harness pulled for some reason, but a PITA otherwise. I would suggest splitting some PVC conduit from end to end and placing it over the wiring harness and taping it back up as a reasonable long term repair. You could also use plastic flex conduit and cut a single slit down its length and work it over the wire bundle followed by tape. If you have the harness pulled you could use
EMT conduit of the appropriate size or unsplit PVC conduit. Others will surely have ideas as well. |
Smushy Samba Member
Joined: December 19, 2014 Posts: 91 Location: Ontario, Canada
Posted: Wed May 10, 2017 4:50 pm Post subject: Re: The Stupid Question Thread |
I'm trying to replace the front struts. The top bolt is fused to the inner collar which is odd (I'm going to replace the M12 bolt - I uploaded a picture). But my main problem is on the passenger side the bottom nut will not release. I have tried penetrant/heat - It turned slightly but it's backing out from the torsion arm.
Would you try to cut the bolt off as is? I'm assuming it's an M12-1.5 nut?
Thanks _________________ 1964 Type3 Notch
1971 Type2 Dormobile
1971 Type2 Westfalia
1973 Type2 Kombi
1977 Rabbit
1961 & 1964 Heilite Single Wheel |
Posted: Wed May 10, 2017 5:33 pm Post subject: Re: The Stupid Question Thread |
You can cut the bushing off the old bolt for the top if you like, split the collar on the shock, grind away the rubber and grind away the side of the bushing until you just get to the bolt.
If the bottom stud is coming out of the arm remove it, you'll have to drill or drive out the pin that keeps it in there (since it's obviously broken) and replace it to retain the stud. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Smushy Samba Member
Posted: Wed May 10, 2017 6:26 pm Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
If the bottom stud is coming out of the arm remove it, you'll have to drill or drive out the pin that keeps it in there (since it's obviously broken) and replace it to retain the stud. |
Where does that pin insert from? I do have some spacing issue the bolt must have shifted out from the torsion arm. Can you confirm it's a 1.5 thread pitch as my threads are rough shape. _________________ 1964 Type3 Notch
1973 Type2 Kombi
1977 Rabbit
Posted: Wed May 10, 2017 6:44 pm Post subject: Re: The Stupid Question Thread |
Smushy wrote: |
busdaddy wrote: |
Where does that pin insert from? I do have some spacing issue the bolt must have shifted out from the torsion arm. Can you confirm it's a 1.5 thread pitch as my threads are rough shape. |
Look closely at the lower arm in this pic from Ratwell, ~ 20mm in from where the stud emerges you can see the pin. As for thread pitch it looks like 1.5, but a thread gauge or test with a die will confirm.
Слава Україні! |
Smushy Samba Member
Posted: Wed May 10, 2017 7:44 pm Post subject: Re: The Stupid Question Thread |
Thanks that is perfect! _________________ 1964 Type3 Notch
1973 Type2 Kombi
1977 Rabbit
Jim Bear Samba Member
Joined: March 25, 2006 Posts: 670 Location: Watkinsville, GA
Posted: Thu May 18, 2017 9:08 am Post subject: Re: The Stupid Question Thread |
OK. I am about to pull the heads. Been lingering at this stage for months and finally have the time. Question, really more related to reassembly: Does it matter if the push rods go back in the same order they come out? _________________ "You're either on the bus, or you're off the bus." ~kk
'85 Vanagon Westy - George In the Stable 2020-?/'74 Weekender - Ophelia In the Stable 2007- ?/'69 Beetle Convertible - SOLD 2017-2020/'67 Beetle - September SOLD 2013-2016 /'67 SO42 Westy - Sage SOLD 1996-2001 /'69 Transporter - Baby Blue SOLD 1995-1995/'72 Westy - Nelly - SOLD 1990-1995--STOP FRACKING |
Posted: Thu May 18, 2017 9:49 am Post subject: Re: The Stupid Question Thread |
Jim Bear wrote: |
OK. I am about to pull the heads. Been lingering at this stage for months and finally have the time. Question, really more related to reassembly: Does it matter if the push rods go back in the same order they come out? |
No, you'll be adjusting the valves after reassembly anyways, but the lifters must go back in the same holes they came from. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu May 18, 2017 9:57 am Post subject: Re: The Stupid Question Thread |
Jim Bear wrote: |
The advice to keep pushrods sorted goes way back in time and really doesn't apply anymore. In the olden days pushrods used to wear to match the lifters and the rockers so changing them around accelerated the wear and threw the valves out of adjustment that much quicker. |
Posted: Fri May 19, 2017 7:10 am Post subject: Re: The Stupid Question Thread |
Thanks gents.
A real stupid question now-- I have never been this far into the engine. Keep in mind the purpose of this endeavor is to get the 3/4 head off to fix the stripped time-sert in #4 and to then inspect the head. I am taking the 1/2 head off for inspection as well.
Are the lifters in the head? Any tips on the head removal/what to look for/steps to follow/things to consider?
And, thanks again. _________________ "You're either on the bus, or you're off the bus." ~kk
wcfvw69 Samba Purist
Posted: Fri May 19, 2017 7:48 am Post subject: Re: The Stupid Question Thread |
Jim Bear wrote: |
Thanks gents.
And, thanks again. |
https://vwparts.aircooled.net/v/vspfiles/photos/How-To-Rebuild-VW-Engines-2.jpg
This is an excellent book to have in your VW book collection. I refer to it a lot. The Bentley is also excellent as well. You can find them used for good prices on Amazon and Ebay. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Fri May 19, 2017 9:36 am Post subject: Re: The Stupid Question Thread |
Jim Bear wrote: |
Thanks gents.
John Muir's Idiot Book is a good start book
https://www.abebooks.com/servlet/BookDetailsPL?bi=...%2Bmuir%2B |
10kc10 Samba Member
Posted: Sat May 20, 2017 3:05 pm Post subject: Re: The Stupid Question Thread |
Relatively new bus owner, it's a 74. I am getting a fuel smell recently, and when I looked into the engine bay I found a vacuum hose lying loose. I believe it had fallen off the Charcoal canister. It is the hose on the right which I have reattached. Is this correct?
There is also a second nub on the right side below this one that does not have a hose attached to it. I believe it should, where does it go?
Thank you.
[/img] |
