Solid Shafts
bugguy1967
bugguy1967 is offline
PostPosted: Sat Apr 22, 2017 8:33 pm    Post subject: Solid Shafts Reply with quote
Does anyone have any sources for modifying the stock rocker shafts to make them a solid setup? I did a quick check, but couldn't find anything.
Someone sent me their rocker assemblies to modify the arms for swivel adjusters. I normally do the mod to 1.1:1 late rockers, but I told him I'd look them over to see if I could safely accomplish the job. We discussed modifying the shafts as well.
For high performace use, are there any weak links? Can I narrow the spacers that separate the intake and exhaust rockers, or are they a perfect fit in their saddles? Has anyone ever found it difficult to attain correct adjuster-to-valve stem alignment with the stock setup, or are they perfect every time? With late engines this is a problem. An easy fix is to narrow the rocker blocks, and use shims to set the adjusters in the correct locations. Btw, I have shim assortments in different thicknesses.
txoval
txoval is online now
PostPosted: Sat Apr 22, 2017 8:44 pm    Post subject: Re: Solid Shafts Reply with quote
Here are mine
Milled the ends of the shaft to remove the clip mounts, drilled and tapped the ends. Made a solid center spacer
bugguy1967
PostPosted: Sun Apr 23, 2017 8:20 am    Post subject: Re: Solid Shafts Reply with quote
Thanks! The set screw reminds me of GB shafts.
txoval
PostPosted: Sun Apr 23, 2017 6:36 pm    Post subject: Re: Solid Shafts Reply with quote
I wish I could remember what I made the center spacer out of...I believe 9-chome
I didn't like the stock spring setup, so went this route and have had no issues
bugguy1967
PostPosted: Mon Apr 24, 2017 7:44 pm    Post subject: Re: Solid Shafts Reply with quote
I sourced the parts today. I'll use high-strength aluminum for the center spacer and endcaps. The center spacer material I.D. is .635", which will give me about .008" clearance. The O.D. of the tube is 22.30mm, which also works out nicely. No mods! I just need to cut it to length, which seems to be about 49mm. I'll try and update once I finish...
snowbug
snowbug is offline
PostPosted: Sat May 06, 2017 3:36 pm    Post subject: Re: Solid Shafts Reply with quote
I used aluminum and bronze.
Old enough to remember THRILLS, the gum that tastes like soap.
bugguy1967
PostPosted: Sun May 07, 2017 7:30 pm    Post subject: Re: Solid Shafts Reply with quote
Finished! High-strength alloy center spacer, with m4 set screws, mounting rings narrowed .060" to allow the use of shims, rockers modified for tool steel adjusters, without affecting geometry, aluminum end caps, and m8x1.25 button head securing screws on the ends. The shaft can still be returned to the stock setup, if desired. This particular setup allows for a total of .240"-worth of shims. The shims are 16mm spring steel - 20mm O.D.
txoval
PostPosted: Sun May 07, 2017 7:42 pm    Post subject: Re: Solid Shafts Reply with quote
Would you be willing to machine another set of rockers for tool steel adjusters?
bugguy1967
PostPosted: Mon May 08, 2017 7:30 am    Post subject: Re: Solid Shafts Reply with quote
Yes sir! My next batch of adjusters should be here in a week or two. In the meantime, I could get some rockers ready for you. P/M or email me please. [email protected]
txoval
PostPosted: Mon May 08, 2017 8:48 am    Post subject: Re: Solid Shafts Reply with quote
email sent
mark tucker
mark tucker is offline
PostPosted: Thu May 25, 2017 7:18 pm    Post subject: Re: Solid Shafts Reply with quote
use a cutter with a raidi to under cut the rocker so it dosent leave a sharp corrner, much stronger. and remember the thrust side of the rockers is the rear side of all the rockers.(rear as in toward the rear bumper if you have one)if your a mid mount it would be toward the front bumper Shocked Wink keep up the good work.
modok
modok is offline
PostPosted: Wed Jun 14, 2017 1:16 am    Post subject: Re: Solid Shafts Reply with quote
Shocked STRESS RISER.
