ajmunayco Samba Member
Joined: March 24, 2017 Posts: 9 Location: Lampasas Texas
Posted: Wed May 10, 2017 4:43 pm Post subject: 1982 vw rabbit air metering sensor plate |
Hello everyone could use some help on trouble shooting air metering plate on fuel injection rabbit 1.7l. not moving up or down when starting car, i can lift it with some pliers from middle bolt and car will then run roughly but once I release, car dies. It does move freely but not on its own. Could this be a electrical issue or air vacuum issue. How to trouble shoot thanks |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Wed May 10, 2017 6:45 pm Post subject: Re: 1982 vw rabbit air metering sensor plate |
The air sucks the plate up. If there is no suction, the engine is not turning over, the cam timing is so messed up the engine cannot suck air, or there is a large air leak.
I would start with the large air leak. |
Posted: Thu May 11, 2017 5:13 am Post subject: Re: 1982 vw rabbit air metering sensor plate |
Thanks Butcher I'll look into. |
vwoldbug Samba Member
Posted: Thu May 11, 2017 3:46 pm Post subject: Re: 1982 vw rabbit air metering sensor plate |
Have you cranked the engine with the boot installed and clamped . If you can get a long Allen wrench on the mixture screw next to the boot you may be able to pull-up on the sensor plate. You may have to knock the plug out from the bottom. If it's like a USA car you should here the frequency valve buzzing when engine is cranking. |
