vwjetboat Samba Member
Posted: Thu May 11, 2017 9:12 pm Post subject: VW flat 4 jet ski/boat project |
Was wondering if anyone has a boat project with a VW air cooled in it? I am working on a jet ski / boat
Letterman7 Samba Member
Joined: March 14, 2004 Posts: 3198 Location: Downingtown, PA
Posted: Wed May 24, 2017 5:06 pm Post subject: Re: Any VW flat 4 boat projects on forum? |
got flywheel for vw jetboat build today.. its off a nissan sentra 96 or so. 10 3/4 inch
panel Samba Member
Joined: December 02, 2001 Posts: 1091 Location: Victoria B.C. Canada
Posted: Wed May 24, 2017 9:09 pm Post subject: Re: Any VW flat 4 boat projects on forum? |
Neat.. but no wheels are going on mine.. |
Posted: Tue May 30, 2017 2:04 pm Post subject: Re: Any VW flat 4 boat projects on forum? |
flexplate adapter done
Posted: Tue May 30, 2017 2:05 pm Post subject: Re: Any VW flat 4 boat projects on forum? |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Wed May 31, 2017 4:37 am Post subject: Re: VW flat 4 jet ski/boat project |
So what's the plan for coupling engine to the drive, belt driven? Have you verified that the engine rotation will be in the right direction to drive the impeller? |
Posted: Wed May 31, 2017 7:29 am Post subject: Re: VW flat 4 jet ski/boat project |
Bashr52 wrote: |
yes it rotates right way.. 3 v belt pulley is the plan at the moment |
HeidelbergJohn4.0 Samba Member
Joined: March 01, 2004 Posts: 1199 Location: Havre de Grace, MD
Posted: Thu Jun 01, 2017 10:40 am Post subject: Re: VW flat 4 jet ski/boat project |
cool project. It kinda looks like my 11' invader with the top deck removed. I used to run a 40hp Johnson. 50 mph on an 11 ft boat is a thrill, not real fond of those speeds on a PWC though.
I'm missing something though. isn't the motor in backwards? I see the flex plate adaptor, how are you coupling it to the input shaft on the jet pump at the other end of the block?. _________________ 71 LWB Manx style dunebuggy
71 Beetle
71 Volksrod
Machette Speedster
2012 Passat TDI SE (sadly sitting in a buyback parking lot somewhere waiting for it's heart to be ripped out.)
Last edited by HeidelbergJohn4.0 on Thu Jun 01, 2017 1:10 pm; edited 1 time in total |
Posted: Thu Jun 01, 2017 11:18 am Post subject: Re: VW flat 4 jet ski/boat project |
HeidelbergJohn4.0 wrote: |
cool project. It kinda looks like my 11' invader with the top deck removed. I used to run a 40hp Johnson. 50 mph on an 11 ft boat is a thrill, not real fond of those speeds on a PWC though. |
there will be some slight modifications on hull to give it more of a V shape.. and the nose will be a few feet longer into a point.. Like the old vintage 70s jet boats.. I figure if i have less then 500 bucks in it.. and it moves.. I will crap all over myself just from the stand point of accomplishing it.. The only reason Im doing this.. is we live in treasure beach Florida.. im on the water so to speak.. GF has a Manufactured home on one of the canal's that leads to the ICW 100 yards or so away.. |
Dr OnHolliday Samba Member
Joined: May 11, 2012 Posts: 1215 Location: was Escondido now San Berdoo
Posted: Thu Jun 01, 2017 12:39 pm Post subject: Re: VW flat 4 jet ski/boat project |
Kool project! I'll be interested to see the finished boat. _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
Posted: Fri Jun 02, 2017 12:51 pm Post subject: Re: VW flat 4 jet ski/boat project |
ordered a few more parts for vwjetboat
Posted: Sat Jun 03, 2017 4:30 pm Post subject: Re: VW flat 4 jet ski/boat project |
well.. I am adding 3 feet to bow.. gas tank will go up here ..
Posted: Mon Jun 05, 2017 2:26 pm Post subject: Re: VW flat 4 jet ski/boat project |
you can kinda see were I am going with this a little better now.. it went from 9 feet to 12 feet..
Posted: Wed Jun 07, 2017 10:21 am Post subject: Re: VW flat 4 jet ski/boat project |
Started polishing the intakes.. about half way done with 1
Posted: Wed Jun 21, 2017 6:56 pm Post subject: Re: VW flat 4 jet ski/boat project |
Well.. crap.. so.. the plan was to build this used 1776 motor.. new bearings cam & lifters & rings.. ya know a CHEAP rebuild because the case is an older H case.. So i do not want to spend a lot of money on it.. .. Well today .. my old boss gave me a motor that was pretty much sitting in the weather but with rocker arms off.. heads got water in intake ports and little in the case but nothing damaging.. well anyway .. the plan was to use this new junk motor for mock up in the boat.. something i could leave in and not worry about weather..but.. turns out.. the case.. is a std main.. std thrust std bore 1600 dual port dual relief AJ case...now WTF. to do. obviously smart thing to do would be use the H case for mock up and build the AJ case.. but dang .. I really do not have the money to do it right.. UGGGGGGGGGGGGGG i hate being poor.. sometimes.. lol its fun doing things that most could never do with so little like I do.. but dangit.. I want to go boating THIS SUMMER .. |
Posted: Tue Jun 27, 2017 6:18 pm Post subject: Re: VW flat 4 jet ski/boat project |
I was asked what I am going to do about the drive system.. and then it dawned on me .. I had a few parts I might be able to do something with and I will be damned.. I think it this will work .. all the lateral force on the belt will be on this front wheel bearing that is still good.. and the love joy off the yellow jet ski. and... so far.. $0 invested in these parts.. once I figure out what ratio the crank and pump need.. I will go junk yard and get.. Id love to put a Harley drive belt on it but they are way to much money .. so two serpentine belts 1 inch wide should do it.. of course with manual tensioner or some sort.. I know the pitch of the prop.. its booked marked someplace 18 degree or something.. so anyone that is into this and would like to take a gander at what pulleys I should prob get then by all means.. ask what ya need..
Posted: Tue Jun 27, 2017 6:24 pm Post subject: Re: VW flat 4 jet ski/boat project |
Why complicate things? Why not just put the water jet back in it? RPM's should be close to the original engine at cruise, plus you gain a little bit of torque. Hook it up to a clutch mechanism coming off the crank pulley like you're attempting. Or ... is that what you are doing? You said "prop" and got me thinking you were heading I/O with it.[/b] |
