riverside66 Samba Member
Joined: June 04, 2008 Posts: 218 Location: Sparta, NC
Posted: Mon May 01, 2017 4:54 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
SamboSamba22 wrote: |
Though it never monsooned as projected, the forecast kept a lot of folks home, so the turn out was pretty poor.
But with limited numbers comes delightful surprises!
Dude that's cool as crap! Congrats! The bus itself is the real trophy, but that's a sweet unexpected bit of icing on the cake
Nice job man! _________________ 1977 Standard Beetle -Sold-
1979 Transporter - "Wheatbread" -Sold- |
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Posted: Fri May 12, 2017 1:19 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
With all this rain, I'm finally having to bite the bullet and begin replacing door and window seals on the bus.
Anyone have any suggestions or advice on a quality rear hatch seal? The door seal currently is allowing water to puddle up in the left corner by the linen cabinet and me no likey.
Seems pretty straight forward, looking to have one about mid next week, it's been nothing but rain lately! _________________ The Bus Barn Ltd. Co.
Oct. 67 Double Cab (68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL] |
curtp07 Samba Member
Posted: Fri May 12, 2017 2:05 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Not that it helps the seal but if you're keeping the bus outside (like I do my Beetle) - a nice car cover made ALL the difference for me.
After screwing around with junk Pep Boys covers .... Got a heavy duty cover from JBugs...doesn't BD have a good bus cover?
Anyway good luck w the seal!
Curt _________________ Subaru |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Fri May 12, 2017 3:45 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
I like the bus depot cover. If you live in a real windy area, it will buff your paint, but then any of them would...... _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Posted: Thu May 18, 2017 6:24 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Rear hatch seal has been ordered, back ordered one week through Bus Depot, hoping it's as pretty as I'm anticipating.
I did receive my new non-adjustable tie rod assembly. Now I've been out with a pulled back for a week, but dammit, sitting around is driving me nuts! So hopefully I can worm under the bus and swap it out. Inner tie rod end is shot (only crappy one left) and I'm really hoping it eliminates my slightly sloppy steering on the highway.
Really wanting to button it up against cross winds and big rigs. After this, all I have left is ball joints and steering box. One day... _________________ The Bus Barn Ltd. Co.
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
rusty busty Samba Member
Joined: May 27, 2015 Posts: 310 Location: Vancouver BC
Posted: Sat May 20, 2017 5:19 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Done that before. I got to experience the "death wobble" in an old chevy pickup truck after changing tie rods.
Turns out alignment is kind of important. _________________ 1978 CEII Get-away hightop |
Posted: Sun May 28, 2017 7:03 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
With a free afternoon, no company at the house, today consisted of some maintenance.
With very odd, alarming performance trucking home last night, I decided to change the oil again, to Castrol 20w-50 since we have summer temps now, as well as installing the Bosch spark plugs I've had sitting around for a few weeks.
Cylinder 3 spark plug wasn't tight, though I admit that the last time I put plugs in, I didn't torque them to spec, today everything torqued down to 20ft lbs.
With the sun making it's dance for the day, I left the chore of retiming the engine for another day. Test running today after plug change and oil swap, something's still off a bit.
These dual Solex's sure are fun!
While crawling around in a clean garage, I cleaned and applied grease to all the fittings up front, the beam took about half a tube, shame on me.
Believed to have addressed my alignment issue, at least for the moment, I doubt the true accuracy of my attempts, but we'll see.
Rear hatch seal install and review coming up this coming week. _________________ The Bus Barn Ltd. Co.
Posted: Mon May 29, 2017 7:36 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Keep a eye on the toe setting by rubbing your hand across the tire treads.if the toe is off you will feel a saw tooth pattern,it will feel rough going across the treads one way and smooth going the other. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy
1974 parts bus
A smart man learns from his mistakes,a very smart man learns from other's mistakes. |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Mon May 29, 2017 7:54 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
rusty busty wrote: |
Turns out alignment is kind of important. |
I had that experience once when moving from the Bay Area to Palm Springs. I had a loaded U-Haul with a trailer carrying my SUV. Just as I got onto Hwy 101 and accelerated to 60, it felt like the rig was bouncing from side to side until I was able to slow it to 50.
Probably the dumbest thing I did was to continue the journey, keeping it just under 60 for the 10-hour long drive on a Friday, including rolling thru LA traffic. (I didn't want to have to unload this truck and pack everything in a new truck, assuming U-Haul even had one to give me.). Of course, on that long, boring @$$ stretch of I-5, I'd very slowly speed up and the bouncing would start again, which was better than coffee at waking me up.
I was never so glad to be done with a trip as that one. When I got to PS, I left the rig parked on the street, bared all and jumped in the pool! _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
Posted: Thu Jun 01, 2017 9:13 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Looking for clarification on the linkage here, shown on a '73 throttle arm, in my 74 Westy. What's all missing here, I know of only one other thread regarding this topic and didn't find much clarity with the images given.
There is excessive slack within the throttle cable but no means of increasing the tautness, and I'm tired of dealing with it on the end of the pedal.
Suggestions?
On another note, I received my rear cargo hatch seal from Bus Depot. One week backordered, received today labeled as Parts International, though the seal looks nice (clean form and indentations of cornering), feels durable, it was purchased with the expectation of being genuine VW, as mentioned on the web listing. Calling tomorrow for insight, maybe it's labeled wrong, or I got the wrong part number, though the number matches online, and it's the only option available on their website. Updates to follow. _________________ The Bus Barn Ltd. Co.
Abscate Samba Member
Posted: Fri Jun 02, 2017 2:11 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Genuine V UU, Shirley. _________________ .ssS! |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22462 Location: Escondido CA
Posted: Sat Jun 10, 2017 6:20 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Jason, thanks for the knowledge.
I replaced the C-clip that fits within the notch on the throttle linkage pin (3/8 c-clip).
Kicker is that the return spring has been in the forward most position (when C-clip was missing) so with the spring in the correct position it doesnt have the correct tension to return the throttle linkage, so I am running the bus with the C-clip installed, eliminating slack within the linkage, while the spring is in its non-correct, tension-allowing position.
Anyone have leads on springs?
On another note, I ended up installing the Pacific International rear hatch cargo seal. The new seal was pliable, one-piece, in which I separated at the seam up top, to install behind the rear hatch pivoting arms. The new seal is grayish in color, no where close to the black one that was original, though I think some of the whitish-gray will wash out as the shipping/storage powdery material wears off over time.
The fit is nice, and overall Im satisfied with the seal. Not wowed, but it serves its purpose.
Again, not a VW seal as stated, every once in a while, I do have dishearten surprises from the Depot, but its what it is, Im not sure what wouldve taken place if I had called and raised questions, but for now, Ill keep being lazy.
Did not use any weatherstripping adhesive. None. _________________ The Bus Barn Ltd. Co.
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Sat Jun 10, 2017 6:45 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
All my grey seals snapped right in and fit WO splits- the black lighter foam ones never fit and now full of cracks- so Be happy- think you got the better one.
like that bus- good job.
did you get a spring? try Ace hardware. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Posted: Sun Jun 11, 2017 4:37 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
For working on your birthday, the least a man can do is be grateful he can cruise in such style!
So far I'm loving the new, cleaner throttle response. Mountain Home show in 2 weeks!
WillamM,
I'm using the original spring, attached to the arm as shown in my questionable photo I posted prior to Jason's response. I'm weary on finding one with the correct tension, I don't want to excessively damage the carbs. _________________ The Bus Barn Ltd. Co.
Posted: Fri Jun 16, 2017 1:15 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
So as I noted in the Steering Coupler thread, I ordered the wrong part number (coupler) for my bay window, though not discovering the differences until removing the old one. So for now, the old one is back in place, and boy, is it shot!
Please be advised the smaller coupler shown next to original is indeed WRONG for our bay window bus applications:
Anyone have any leads on good, quality bus steering couplers?
In the event of having to reassemble the steering goods, I decided to figure out why my horn quit working for me. Verifying grounds, cleaning a couple connections, and indeed seeing the terminal on the spade of the bottom steering column, upon reinstallation of parts, the horn is now back in action!
Woo-hoo! Now I can honk at hot ladies and driving monkey idiots! But mainly hot broads now that Im single, bus life gets lonely... _________________ The Bus Barn Ltd. Co.
