Danwvw Samba Member
Posted: Sat May 13, 2017 1:16 pm Post subject: Re: Loveland Pass |
Bulli Klinik wrote: |
Like these guys said, it's all about driving style. Regardless of all the modern cars passing you at 90 mph up the passes, keep it in a low gear, wound up and happy. A spinning cooling fan is your friend. Keep trying to grab a higher gear and it will get hot. |
Sometimes this is true not a general rule at all though based on my experience. If the engine has a little extra compression ratio and it runs hot perhaps it's a non-dog house with the steel oil cooler. They get pretty hot. The more throttle at high RPM the more heat the heads make. Sometimes if the grade is not too steep it's better in 3rd with more throttle. But on a really steep grade to even pull it you got to go to 2nd and back off on the throttle to keep the heat generated down. One thing going for the Air Cooled is the cooling they get from breathing though. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
