What did you do for your Bay recently?
Page: Previous  1, 2, 3 ... 409, 410, 411 ... 462, 463, 464  Next
static
static is offline
PostPosted: Sun May 07, 2017 7:29 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Pretty simple and cheap improvement:
I replaced the bulbs in the front (amber) turn signals from clear bulbs to amber bulbs.
Now, my front amber turn signals are more amberish.
More amber = better (since, frequently, the lenses are faded)
I replaced my side marker clear, incandescent bulbs to red LED bulbs. Now, my red side markers look much more red. More red = better.
Total cost for all four bulbs? About $1.00
(Pro tip: buying Chinese stuff direct from China is much cheaper than buying your Chinese stuff through a USA middleman)
cv66seabear
cv66seabear is offline
PostPosted: Sun May 07, 2017 9:09 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Replaced the seat belts with retractable ones - don't work as smooth as I'd like.
Put up a couple of assist handles.
Tried to replace the visor holder, but how in the heck do you put a screw in, when you have to have the visor in there already? Do you have to take the visor off at the side, screw in the holder, then replace the visor on the side?
Did a little measuring in preparation for installing my auxilliary battery. Looks like I'll put in a holder, then go through the firewall to hook up to the main. Since I'm mounting under the rear seat, I'll also put the fuseblock and Bluesea ACR under there.
Rear brakes need love = the right has a bad master cylinder. Parts just arrived, not sure if my skill level is up to it... (heck I couldn't replace the visor holder!)
"Not all who wander are lost." JRR Tolkien
1979 Campmobile - "Pancho Verde"
Old Friends - gone now:
1964 Beetle "Liebchen"
Mark 3 Jetta "Liebchen Zwei"
Passat Wagon "Wolf"
2015 Passat Sedan "Rudy"
richardandtory
richardandtory is offline
PostPosted: Fri May 12, 2017 7:27 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
https://www.youtube.com/watch?v=mLEqgevxMAo&t=10s
TurtsMcSlow
TurtsMcSlow is offline
PostPosted: Fri May 12, 2017 9:50 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Made the switch to a pertronix ignitor.
notchboy
notchboy is offline
PostPosted: Sat May 13, 2017 8:51 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
I did too a couple weeks back with a SVDA. Bus runs like a top Cool
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
wcfvw69 Premium Member
Samba Purist
wcfvw69 is offline
PostPosted: Sat May 13, 2017 11:22 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Yup, tow truck drivers love them there Petronix modules! Laughing
The Samba member since 2004.
airschooled
Air-Schooled
airschooled is offline
PostPosted: Sat May 13, 2017 11:31 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Ooooohhhhh buurrrnnn! You even found one with a vintage trailer for Jason! Laughing
Learn how your vintage VW works. And why it doesn't!
www.airschooled.com
cdennisg
cdennisg is offline
PostPosted: Sat May 13, 2017 2:51 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
I've had tow Pertronix modules fail on me while on the road. Both were quickly repaired by the set of points in the glove box, once the issue was diagnosed. That took some time..
Always keep spare parts and tools on board.
nothing
Samba Purist
wcfvw69 is offline
PostPosted: Sat May 13, 2017 2:58 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
It's very rare that you see folks report breaking down due to points or condensers unless they were negligent with their servicing. In 3 decades of VW ownership, I've never had an issue w/points or condensers.
Now, I LOVE the idea of those electronic ignitions but I simply see too many people report them failing, causing a breakdown. Even if you do carry a spare distributor or points and condensers, with today's heavy traffic, you just know the module would burn up in the worst possible spot on the freeway, potentially causing an accident.
HelmutofBuffalo
HelmutofBuffalo is offline
PostPosted: Sun May 14, 2017 5:43 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
I think anything man made can fail. I have the Compufire electronic ignition on mine (see pic.) Works beautifully.... and yes the module did burn out at one time, luckily it was not while out on the road.
However (in a different Bus) I also experienced a set of points break at the spring. Leaving me stranded. Lesson learned, always carry spare points etc.
1979 Type I Convertible
notchboy
notchboy is offline
PostPosted: Sun May 14, 2017 8:23 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Haha assholes Rolling Eyes Laughing
I have my saucy pointed 009 on deck IF my junk should fail Cool
1964 1500 S
wihr
wihr is offline
PostPosted: Sun May 14, 2017 11:45 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
I have over 200,000 miles on my Allison (Crane) electronic ignition. The only time it ever failed me was when a outside wire broke. I fixed it quickly. The best improvement to the car I have ever made. Plugs last twice as long.
WW
WIHR
1970 Campmobile "Van Ordinaire"
2009 Lincoln Town Car "Behemoth"
1969 Lambretta 150 DL "Nina"
1962 Matchless G 12 CS 650cc
cdennisg
cdennisg is offline
PostPosted: Sun May 14, 2017 12:14 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Electronic ignition is excellent, for sure. I just noted that I have had two different aftermarket systems fail while on the road. Neither of which I bought and installed, they came with the vehicle/engine when I bought them.
I would consider the Crane or Mallory ignition systems in the future. But for now I'll keep using the points and condensers I have stashed away.
BTW, I had a condenser fail once many years ago. I have seen broken contact point springs, too.
nothing
cv66seabear
PostPosted: Tue May 16, 2017 7:10 am    Post subject: Re: What did you do for your Bay recently? Reply with quote
Replaced the left rear drum. shoes and Cylinder. 15 minute video on YouTube - 5 hours for us!
BUT... now the right side will be easier!
Passat Wagon "Wolf"
DeltaBravo
DeltaBravo is offline
PostPosted: Fri May 19, 2017 8:49 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Replaced my nasty, crusty front panels with my own custom creation.
1976 Bus, 2.0 Hydraulic lifters, Manual.
My engine rebuild. http://www.thesamba.com/vw/forum/viewtopic.php?t=656536&postdays=0&postorder=asc&start=0
https://www.thesamba.com/vw/forum/viewtopic.php?p=8444317#8444317
https://www.thesamba.com/vw/forum/viewtopic.php?t=673255&highlight=
https://www.thesamba.com/vw/forum/viewtopic.php?t=674097&highlight=
https://www.thesamba.com/vw/forum/viewtopic.php?t=672791&highlight=
1988 Porsche 911 Carrera Cab
1987 Buick Grand National
dillon70
dillon70 is offline
PostPosted: Sun May 21, 2017 5:42 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Got my middle seat back from being reupholstered to match the others. It's probably been 25+ years since this was installed in the bus. She's come along way:)
Before
After
KentABQ Premium Member
KentABQ is online now
PostPosted: Sun May 21, 2017 6:06 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Wow, that red looks great!!! Great transformation, and thanks for posting the pics. Are you using this as a daily driver?
-Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!"
---WildIdea
Bus ownership via emoticons:
Very Happy Shocked Mad Sad Embarassed d'oh! Pray Brick wall Pray Dancing Dancing Dancing ---williamM
dillon70
dillon70 is offline
PostPosted: Sun May 21, 2017 8:24 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Thanks!!
She's a garage queen at least 5 days a week, but we get out for the weekend club meet/cruise or occasional car show.
cbaucom1
cbaucom1 is offline
PostPosted: Sun May 21, 2017 9:45 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
Globespotter wrote:
Took off the Westfalia decal from the front that the PO had put on when he refurbed the bus.
I like the cleaner stock look for a Bay, since the Westfalia decal was only on the front on Vanagons.
Also:
Built dividers for my under seat storage. The best part is that now I can pull out my coleman stove from the front without raising the seat, and not have to pull out all the stuff that used to just be piled in there. Also keeps my tools accessible in a removable tray and helps organize everything!
This is inspiring. Mine becomes a sloshed around, junk drawer of tools and random camping items. But, where do you put the tent poles?
d-rick
d-rick is offline
PostPosted: Tue May 23, 2017 5:00 pm    Post subject: Re: What did you do for your Bay recently? Reply with quote
I swapped out a rusty front beam for a good solid one today on the '77 westy I am working on...fun stuff.
No pic..B/C we all know what a rusty front beam looks like Smile
1959 mango-trailerbus
1962 single cab *1/2
1966 13 window
1967 panel/camper
1968 cig-panel *1/2
1968 passenger bus *1/2
1969 beetle
1969 dormobile
1978 sage green Westy
1990 DoKa
2002 Golf TDI
Page 410 of 464
