Joined: August 31, 2013 Posts: 12846 Location: North Carolina
Posted: Thu May 18, 2017 6:35 am Post subject: Single port thermostat rod vs dual port thermostat rod |
After doing some research, I have determined that the rod between the thermostat & the air deflection flaps is different between the single port & the dual port doghouse style. My single port Bus engine didn't have the rod or thermostat & bracket, I have these pieces from a doghouse style shroud, can anyone confirm this? _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51119 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu May 18, 2017 7:39 am Post subject: Re: Single port thermostat rod vs dual port thermostat rod |
211 119 163A is the PN# for the 68, I don't have a 71+ parts book so I can't tell you if the DP rod is the same in VW's opinion, to my eye there's no visible difference IIRC.
The link bar across the front between flap assemblies is different for sure. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Joined: January 01, 2007 Posts: 16859 Location: sticksville, ct.
Posted: Thu May 18, 2017 7:47 am Post subject: Re: Single port thermostat rod vs dual port thermostat rod |
http://www.jerseylooker.com/FicheDump/EarlyBaywindow/EarlyBay-1.html
middle of the page for the diagram
flaps, t stat, rod are the same. the doghouse rod that links them is not _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Thu May 18, 2017 8:05 am Post subject: Re: Single port thermostat rod vs dual port thermostat rod |
Thanks Skills & Busdaddy, now I just have to straighten the one that I have _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Thu May 18, 2017 8:48 am Post subject: Re: Single port thermostat rod vs dual port thermostat rod |
And if you want the preheated air function of 68-70, the right flap is different. If you don't need the cable style preheat, any right flap will work. Make sure you get the small under-cylinder deflector square installed with the slot facing the correct orientation. I forget which way that is, but Bentley shows it well, and it's borderline impossible to install the mechanism if it's installed incorrectly.
www.airschooled.com |
Posted: Thu May 18, 2017 9:13 am Post subject: Re: Single port thermostat rod vs dual port thermostat rod |
TDCTDI wrote: |
Thanks Skills & Busdaddy, now I just have to straighten the one that I have |
it's NOT 100% straight. it has a kick out at the bottom to center it to the t-stat
I will try and find a pic
from hazetguy
it will look like the one on the right.
and hazetguy can kiss my sweaty taint for stealing his pic _________________
Jake Raby wrote: |
Brian wrote: |
Last edited by skills@eurocarsplus on Thu May 18, 2017 9:16 am; edited 1 time in total |
Posted: Thu May 18, 2017 9:16 am Post subject: Re: Single port thermostat rod vs dual port thermostat rod |
asiab3 wrote: |
Robbie |
Thanks Robbie. Yes I do have the proper flap assembly & plan on using it, and the deflector is still in place. I've still got the sheath to air cleaner, ill have to make a cable unless I can find one. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
skills@eurocarsplus wrote: |
flaps are the same. t |
yes and no.i'm pretty sure the actual flap housings are the same.
on a single port, the cross bar connects directly to the arms of the flaps.
the doghouse style has an additional bracket where the cross bar attaches, so that the cross bar can clear all the extra junk on the front of a doghouse shroud.
single port:
gallery pic from sb001
doghouse:
gallery pic from Danwvw
gallery pic from mnussbau _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Posted: Thu May 18, 2017 9:19 am Post subject: Re: Single port thermostat rod vs dual port thermostat rod |
it will look like the one on the right. |
no, it won't. fresh air thermostat rods are longer and don't have the pinched crimp at the top, and are held to the flap with a push-nut.
no hate to you skillz, YOU GAVE ME CREDIT FOR A PIC OF MINE THAT YOU USED AND DIDN'T STEAL IT OR POST IT AS YOURS, unlike one of the MODERATORS of this forum.
it will look like the one on the left in this gallery pic from clara
hazetguy: invested?
aeromech Samba Member
Joined: January 24, 2006 Posts: 16954 Location: San Diego, California
Posted: Thu May 18, 2017 9:29 am Post subject: Re: Single port thermostat rod vs dual port thermostat rod |
This thread is timely for me. I'm building a new longblock for my 1971 and want to install a working flap assembly. I already have a jumble of parts but may decide to just purchase a complete assembly since I really have never screwed with this stuff before. I want it to be correct.
Robbie, I'm confused on that small under cylinder deflector you're talking about. Is that the usually missing sheet metal blocker deal that most new heads don't have? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Thu May 18, 2017 9:31 am Post subject: Re: Single port thermostat rod vs dual port thermostat rod |
aeromech wrote: |
I'm confused on that small under cylinder deflector you're talking about. Is that the usually missing sheet metal blocker deal that most new heads don't have? |
original heads had these deflectors underneath, in the area where the t-stat rod passes through. i thought someone reproduced them, but i'm not sure.
gallery pic from jimhens714
you can see it installed in this pic from Letterman7 (not the one the arrow is pointing to).
hazetguy: invested?
Posted: Thu May 18, 2017 9:32 am Post subject: Re: Single port thermostat rod vs dual port thermostat rod |
hazetguy wrote: |
blaa blaa blaa |
I said it will look like the one on the right in terms of the bends. I did mean the bends going thru the head.
fuck flaps. throw a radiator in that bitch _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Thu May 18, 2017 9:35 am Post subject: Re: Single port thermostat rod vs dual port thermostat rod |
Yes, I was speaking of these guys.
Gallery photo from JimHens
One on each head. Left side has to go on before sled tin, which goes on before the left heat exchanger. Right side can go on in situ. I still can't recall which way the slot goes, but I think it points towards the driver's seat.
They are a serious kindness to your exhaust valves.
Ry-dog Samba Member
Joined: May 31, 2003 Posts: 450 Location: Lunenburg, MA
Posted: Thu May 18, 2017 9:58 am Post subject: Re: Single port thermostat rod vs dual port thermostat rod |
That cylinder tin piece is available through awesome powder coat.. Seems their website isn't working at the moment. _________________ '70 Westy
'14 Jeep Grand Cherokee EcoDiesel |
Posted: Thu May 18, 2017 10:04 am Post subject: Re: Single port thermostat rod vs dual port thermostat rod |
The one that I have was attached to the fan shroud & was either bent when a PO removed the shroud or at some point in storage/moving.
It's had a pretty rough life though, I might have to get some rod & bend another up & tap the lower end.
Here it is after straightening it out.
Clatter Samba Member
Joined: September 24, 2003 Posts: 7537 Location: Santa Cruz
Posted: Thu May 18, 2017 10:11 am Post subject: Re: Single port thermostat rod vs dual port thermostat rod |
It was VERY common for a PO to bend these things up!
Almost any first-timer would yank and yank wondering why the fan shroud was not coming off.
It's still a mystery to me what the actual bends were supposed to look like.. _________________ Bus Motor Build
What’s That Noise?!? |
Posted: Thu May 18, 2017 10:32 am Post subject: Re: Single port thermostat rod vs dual port thermostat rod |
My heads are L3 from Aircooled.net. I have no idea if they have the deflectors or not. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Thu May 18, 2017 10:34 am Post subject: Re: Single port thermostat rod vs dual port thermostat rod |
fuck flaps. throw a radiator in that bitch |
I thought it would be nice to take one back to original for once, if it doesn't cooperate, it's totally getting the 1.8t I've got sitting on the floor stuffed in it. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Thu May 18, 2017 10:46 am Post subject: Re: Single port thermostat rod vs dual port thermostat rod |
When I find bent rods like that I look very carefully at the C shaped thing on the flap the rod attaches to, if its been stretched the fulcrum changes and the flaps may not open fully. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu May 18, 2017 10:51 am Post subject: Re: Single port thermostat rod vs dual port thermostat rod |
i would NOT use that rod. the threads are trashed and that's a very easy way to destroy the thermostat fitting.
sheesh, are you going to farmington this weekend? let me know, i could bring you a good one. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
