Joined: August 31, 2013 Posts: 12815 Location: North Carolina
Posted: Thu May 18, 2017 10:55 am Post subject: Re: Single port thermostat rod vs dual port thermostat rod |
busdaddy wrote: |
When I find bent rods like that I look very carefully at the C shaped thing on the flap the rod attaches to, if its been stretched the fulcrum changes and the flaps may not open fully. |
Thanks for the heads up, but in this case, the rod was on a different set of flaps than the ones that I'll be using. It's still worth checking though. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Thu May 18, 2017 10:59 am Post subject: Re: Single port thermostat rod vs dual port thermostat rod |
hazetguy wrote: |
are you going to farmington this weekend? let me know, i could bring you a good one. |
I didn't even know that it was this W/E, that would be great thanks. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Thu May 18, 2017 1:40 pm Post subject: Re: Single port thermostat rod vs dual port thermostat rod |
i've got one packed. look for me in the swap. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Posted: Thu May 18, 2017 2:10 pm Post subject: Re: Single port thermostat rod vs dual port thermostat rod |
Yes sir! Thanks! _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
blue72beetle Samba Member
Joined: April 23, 2008 Posts: 846 Location: Fort Wayne, IN
Posted: Mon Jun 19, 2017 3:11 pm Post subject: Re: Single port thermostat rod vs dual port thermostat rod |
Can a doghouse fan shroud be added to a single port engine? _________________ -Andy-
-1970 Ghia-
-1971 Bus 1776 Microsquirt EFI- |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Jun 19, 2017 4:02 pm Post subject: Re: Single port thermostat rod vs dual port thermostat rod |
blue72beetle wrote: |
Can a doghouse fan shroud be added to a single port engine? |
Yes, but you'll need a doghouse style cooler as well as the adaptor mount and the appropriate seals to convert the oil port sizes (depending on your case), you'll also need the wider fan and a different link bar for the thermostat mechanism. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Tcash Samba Member
aeromech Samba Member
Joined: January 24, 2006 Posts: 16923 Location: San Diego, California
Posted: Mon Jun 19, 2017 7:20 pm Post subject: Re: Single port thermostat rod vs dual port thermostat rod |
You guys are awesome _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Mon Jun 19, 2017 7:28 pm Post subject: Re: Single port thermostat rod vs dual port thermostat rod |
I know right?
It just occured to me you'll also have to retap the case or use step studs since most SP's have 6mm studs yet the adaptor is 8mm.
Along with the front tin Tcash posted (you can cut a hole in your existing tin if you like) you'll need the 2 exhaust duct tins for the cooler to reach that hole. And a Hoover bit, can't forget that. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Tcash Samba Member
