jackstar Samba Member
Joined: February 15, 2008 Posts: 274 Location: Gulf Breeze, Florida
Posted: Thu May 18, 2017 5:05 pm Post subject: what size is screw holding inside black door latch |
I need the size of the beveled screw that is in the center of the inside door latch on the inside of the door. I took it off and went to the metric hardware store and the could not place it. Any help is appreciated.
Jack |
airschooled Air-Schooled
Posted: Thu May 18, 2017 7:48 pm Post subject: Re: what size is screw holding inside black door latch |
What year bus? (EDIT: Late Westy; hi Jack!)
Are you talking about the one circled in yellow here? It's M5x10mm or M5x11mm, countersunk philips, depending on the M-Code.
Robbie
(stole the picture from Colin!)
_________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Posted: Fri May 19, 2017 3:26 am Post subject: Re: what size is screw holding inside black door latch |
Robbie,
No, I am talking about the single screw that is in the center of the square plate that has the black plastic finger like door latch. It is located above the arm rest in the drivers/passenger door. Sorry I don't have a picture. |
Sage79 Samba Member
Joined: September 13, 2008 Posts: 433 Location: Holland MI
Posted: Fri May 19, 2017 4:17 am Post subject: Re: what size is screw holding inside black door latch |
Oh, behind the cab door pull. That might be hard to find even at a good hardware or fastener store. I've got an extra I can mail you if you PM me your address. Do you still have the little metal washer plate?
Dirk _________________ Dirk
'79 Westy 2.0FI
'73 Sportsmobile 1.7dual Solex 003Auto - now my daughter's
'77 delux 2.0FI 090Auto - now my son's |
static Samba Member
Joined: March 22, 2002 Posts: 1831 Location: The High Desert
Posted: Fri May 19, 2017 10:47 am Post subject: Re: what size is screw holding inside black door latch |
Can we have a number, or reference locale?
BayCreamPuff Samba Member
Joined: August 10, 2015 Posts: 769 Location: Oakland, CA
Posted: Fri May 19, 2017 11:40 am Post subject: Re: what size is screw holding inside black door latch |
I believe he's referring to #48 that holds the interior handle cover plate (#46 & #47) to the door frame.
From the microfiche:
#48 - 014 263 3 - SCREW, CSX - AM5x10
As seen in this photo
_________________ Cream Puff
'79 CA Stock FI Deluxe Campmobile
Earl Grey
'87 GoWesty 2.2 Westfalia
Marsha Mellow
'00 Eurovan VR6 Full Camper |
Sage79 Samba Member
Posted: Sat May 20, 2017 4:16 am Post subject: Re: what size is screw holding inside black door latch |
That's what I'm referring to as well. I've got an extra plus the square washer not shown but on the OG trim. _________________ Dirk
'79 Westy 2.0FI
