what size is screw holding inside black door latch
jackstar
jackstar is offline
PostPosted: Thu May 18, 2017 5:05 pm    Post subject: what size is screw holding inside black door latch Reply with quote
I need the size of the beveled screw that is in the center of the inside door latch on the inside of the door. I took it off and went to the metric hardware store and the could not place it. Any help is appreciated.
Jack
airschooled
Air-Schooled
airschooled is offline
PostPosted: Thu May 18, 2017 7:48 pm    Post subject: Re: what size is screw holding inside black door latch Reply with quote
What year bus? (EDIT: Late Westy; hi Jack!)
Are you talking about the one circled in yellow here? It's M5x10mm or M5x11mm, countersunk philips, depending on the M-Code.
Robbie
(stole the picture from Colin!)
Learn how your vintage VW works. And why it doesn't!
www.airschooled.com
jackstar
jackstar is offline
PostPosted: Fri May 19, 2017 3:26 am    Post subject: Re: what size is screw holding inside black door latch Reply with quote
Robbie,
No, I am talking about the single screw that is in the center of the square plate that has the black plastic finger like door latch. It is located above the arm rest in the drivers/passenger door. Sorry I don't have a picture.
Sage79
Sage79 is offline
PostPosted: Fri May 19, 2017 4:17 am    Post subject: Re: what size is screw holding inside black door latch Reply with quote
Oh, behind the cab door pull. That might be hard to find even at a good hardware or fastener store. I've got an extra I can mail you if you PM me your address. Do you still have the little metal washer plate?
Dirk
Dirk
'79 Westy 2.0FI
'73 Sportsmobile 1.7dual Solex 003Auto - now my daughter's
'77 delux 2.0FI 090Auto - now my son's
static
static is offline
PostPosted: Fri May 19, 2017 5:50 am    Post subject: Re: what size is screw holding inside black door latch Reply with quote
Look here: http://www.bus-ok.de/index.php?k=4104&lang=eng
airschooled
Air-Schooled
PostPosted: Fri May 19, 2017 10:47 am    Post subject: Re: what size is screw holding inside black door latch Reply with quote
Can we have a number, or reference locale?
www.airschooled.com
BayCreamPuff
BayCreamPuff is offline
PostPosted: Fri May 19, 2017 11:40 am    Post subject: Re: what size is screw holding inside black door latch Reply with quote
I believe he's referring to #48 that holds the interior handle cover plate (#46 & #47) to the door frame.
From the microfiche:
#48 - 014 263 3 - SCREW, CSX - AM5x10
As seen in this photo
Cream Puff
'79 CA Stock FI Deluxe Campmobile
Earl Grey
'87 GoWesty 2.2 Westfalia
Marsha Mellow
'00 Eurovan VR6 Full Camper
Sage79
Sage79 is offline
PostPosted: Sat May 20, 2017 4:16 am    Post subject: Re: what size is screw holding inside black door latch Reply with quote
That's what I'm referring to as well. I've got an extra plus the square washer not shown but on the OG trim.
Dirk
'79 Westy 2.0FI
