rusty busty Samba Member
Joined: May 27, 2015 Posts: 310 Location: Vancouver BC
Posted: Wed May 17, 2017 9:21 pm Post subject: Re: My champagne getaway |
notchboy wrote: |
Dude thats a seriously nice score. Buff it and enjoy. |
Thanks man. That's the general plan _________________ 1978 CEII Get-away hightop |
sethpat Samba Member
Posted: Thu May 18, 2017 9:03 am Post subject: Re: My champagne getaway |
Yeah, that thing is cool. Hows the rust? it looks super clean
Hoping to get my bus done next month, planning on visiting some friends in Van. I'll have to get in touch so we can cruise |
Posted: Thu May 18, 2017 7:48 pm Post subject: Re: My champagne getaway |
Rust isn't bad. Just in the rockers a bit. Jacking points, outriggers, battery trays are all fairly solid. I'm not sure I'll be cruising in a month but hopefully. _________________ 1978 CEII Get-away hightop |
Posted: Thu May 18, 2017 7:53 pm Post subject: Re: My champagne getaway |
Busy day
Gas tank is garbage. So is the sender.
Seems the top of the transmission also makes a good home.
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Fri May 19, 2017 6:52 am Post subject: Re: My champagne getaway |
Actually the only evidence of rodents I've seen so far is on the transmission. Thankfully no signs inside or in the engine bay
I'm not sure why the top of the tank rusted. I do know that it's 3/4 full of varnish and sludge and it won't drain from the bottom due to sludge. I'm going to get a pump to drain it so it's lighter before I pull it out. What a mess!
Not a complete surprise though. When I first went to see the bus before buying it the whole ass end reeked of varnish. Now I know why. The sender didn't require tools to remove it was so rusted.
notchboy Samba Member
Joined: April 27, 2002 Posts: 22461 Location: Escondido CA
Posted: Fri May 19, 2017 8:34 am Post subject: Re: My champagne getaway |
Maybe the PO liked to put STP and all kinds of additives to the gas, creating a witches brew? _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Fri May 19, 2017 10:15 am Post subject: Re: My champagne getaway |
My thinking is that maybe there was a leak when it was parked 15 or 20 years ago. Maybe from the vent lines or around the sender. In the summer when it got hot some gas evaporated. At night when it cooled down the fuel vapour condensed on to the top of the tank. As it condensed it also drew moisture from the air which rusted the top of the tank. _________________ 1978 CEII Get-away hightop |
Posted: Fri May 19, 2017 11:04 am Post subject: Re: My champagne getaway |
rusty busty wrote: |
My thinking is that maybe there was a leak when it was parked 15 or 20 years ago. Maybe from the vent lines or around the sender. In the summer when it got hot some gas evaporated. At night when it cooled down the fuel vapour condensed on to the top of the tank. As it condensed it also drew moisture from the air which rusted the top of the tank. |
Or the grumpy tin foil hat wearing neighbor would come out at night, pull the motor, pull the fire wall, pull the tank. Fill it with molasses and sugar, put muric acid all over it, put all the stuff back in the bus like it never happened. Did this process several times over three months - all under the cover of night
All because the PO let his dog shit on this guys lawn all the time.
All I can say is its a weird one. _________________
t3kg wrote: |
1964 1500 S
Posted: Fri May 19, 2017 11:26 am Post subject: Re: My champagne getaway |
notchboy wrote: |
All I can say is its a weird one. |
Mystery solved _________________ 1978 CEII Get-away hightop |
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Sat May 20, 2017 5:50 pm Post subject: Re: My champagne getaway |
When I bought my 1977 CE-1 most of the cushioning material from the all seats was missing. I knew mice had been all through the bus and headliner for a long time, but I did not discover where their nests were until I removed the bottom heater ducting tubes... and pulled the gas tank. Along with it being packed all around with seat cushioning material, the added mouse piss made for some rust problems as well. (But not on the top of the tank)
Posted: Sat May 20, 2017 6:18 pm Post subject: Re: My champagne getaway |
Wasted youth wrote: |
Wow! I'm glad that's not what I found in my tank area.
It's pretty clean around my tank. I'll get some pics next time I go to my shop, but the corrosion is concentrated around the sender and then there's 2 lines of corrosion in a drip pattern right below the vent lines. Something was definitely dripping from the vent lines and corroding the tank.
I have another tank. I was thinking of getting it powder coated. I want to keep this bus a long time and I'd rather not have to mess with the tank again.
SamboSamba22 wrote: |
Shaggin' Wagen.
Without. A. Doubt.
Nice score dude.
Looks like you're having fun, keep it up. |
Buckets of fun
Ya. Sitting a year and a half my ass. _________________ 1978 CEII Get-away hightop |
Rodmullet Samba Member
Posted: Sat May 20, 2017 9:26 pm Post subject: Re: My champagne getaway |
That is one cool bus. Hope you keep it as original as possible. Love the funky 70s style.
Rod |
Posted: Sat May 20, 2017 10:21 pm Post subject: Re: My champagne getaway |
Definitely want to keep it as stock as possible. The wood paneling is crumbling in places but I want to replace it with something similar.
I'm really happy with how original it seems. The seal on the firewall was perfect and probably hadn't been open since Germany.
The engine still has what I'm assuming is a production number on the tin. Engine 429 of the day?
The only "hack" that I've seen so far is the egr is disconnected. _________________ 1978 CEII Get-away hightop |
Posted: Sat May 20, 2017 11:30 pm Post subject: Re: My champagne getaway |
My engine had those painted numbers on the tin in a few places, too. Numbers varied. Someone here once explained it, but I have since forgotten what was said |
WildIdea Samba Member
Joined: September 17, 2016 Posts: 928 Location: Black Hills, South Dakota
Posted: Sun May 21, 2017 7:09 am Post subject: Re: My champagne getaway |
I had a gas tank almost exactly like yours in my 77 sage green westy. It sat since 1995 after PO ran the motor with low oil and seized the crank. It looked like 50 burnt steaks inside and the sender looked exactly like yours.
The skunky gas that was still a fluid was some of the worst stuff ever. If I'd have had any previous experience with it I'd have not spilt a drop. Stunk up my whole garage to the point I had to literally chase down every singe arrant drip I got on the floor to get decent smelling air back. |
Posted: Sun May 21, 2017 9:18 am Post subject: Re: My champagne getaway |
It really is rank! I got a few drops on my gloves. I wiped it off with a rag right away but later I was driving my work truck and I had to pull over to throw out the gloves. Even with the windows open I couldn't be in the same vehicle as the gloves. _________________ 1978 CEII Get-away hightop |
MorkC68 Samba Member
Joined: December 23, 2015 Posts: 610 Location: Nottingham, England
Posted: Sun May 21, 2017 2:05 pm Post subject: Re: My champagne getaway |
fantastic bus fella, enjoyed reading about it!
Good luck with rebuilding it _________________ Major; 1977 Westfalia Campmobile
- Subaru EJ20
- Koni Classic adjustable dampers & Empi Heavy Duty Anti Roll Bar
- 180W Solar System
My blog: https://twolatebays.wordpress.com/ |
Posted: Mon May 22, 2017 6:00 pm Post subject: Re: My champagne getaway |
MorkC68 wrote: |
Good luck with rebuilding it |
Thanks! I'm just getting started. I only brought it home a week ago today
No time to work on it today. Just time for a couple of last pics of the worst gas tank in history. Finally out of the bus. I'm disposing of it tomorrow.
Inside
I've heard that if you're parking a car for a long time you should leave the gas tank full. That might be bad advise if it's being parked for a really really long time. Who plans to park a vehicle for 20 years though. _________________ 1978 CEII Get-away hightop |
