MConstable Samba Member
Joined: May 04, 2004 Posts: 1822 Location: Saint Charles IL
Posted: Thu Apr 27, 2017 2:50 pm Post subject: Turn signal help |
My right front turn signal light comes on when I turn on the lights, but it doesn't blink when I hit the turn signal or the hazards. not sure what would cause this, turn signal relay or? |
citroen Samba Member
Joined: February 28, 2010 Posts: 1578 Location: louisville ky
Posted: Thu Apr 27, 2017 6:55 pm Post subject: Re: Turn signal help |
Have you removed the bulb to make sure it has a double contact bulb and not a single contact |
74 Thing Samba Member
Posted: Thu Apr 27, 2017 8:10 pm Post subject: Re: Turn signal help |
It should be the bulb or the contacts for the bulb. |
perello Samba Member
Joined: April 15, 2005 Posts: 829 Location: where social security comes for free
Posted: Fri Apr 28, 2017 2:20 am Post subject: Re: Turn signal help |
I found another (funny) source of misbehaviour:
the frame that holds the speedo is hold by 4 screws to the car frame...right?
well yesterday I saw that the grounding was very loose on that frame, by fixing it better I got rid of many electrical gremlins I had on the turn signal! _________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
Posted: Thu May 11, 2017 9:35 pm Post subject: Re: Turn signal help |
citroen wrote: |
I have the double contact bulb, could it be the turn signal relay? |
cecil Samba Member
Joined: February 23, 2005 Posts: 461 Location: Stockton, CA
Posted: Wed May 24, 2017 12:22 pm Post subject: Re: Turn signal help |
Instructions on You Tube on how to test relay.....easy _________________ I may not be that funny or athletic or good looking or smart or talented....I forgot where I was going with this
I have this wierd desease called "must tear everything up and put it back together when there's nothing wrong with it...Itus." |
