margrump Samba Member
Joined: December 02, 2015 Posts: 8 Location: visalia, ca.
Posted: Wed May 24, 2017 9:36 am Post subject: Wiring harness question |
I have a 73 standard beetle, I would like to install a new wring harness, is there one available that would incorporate the use of an alternator instead of the stock generator? |
allenw Samba Member
Joined: September 20, 2016 Posts: 221 Location: Dalton, GA
Posted: Wed May 24, 2017 6:11 pm Post subject: Re: Wiring harness question |
I believe the 73 already has an alternator not a generator unles an older engine has been installed. You got a pic? |
empi3 Samba Member
Joined: October 03, 2015 Posts: 347 Location: SW Wyoming
Posted: Thu May 25, 2017 8:30 am Post subject: Re: Wiring harness question |
If you have an alternator with an internal regulator, how about this one?
http://www2.cip1.com/ProductDetails.asp?ProductCode=C17%2DWK%2D113%2D72%2D73
Steven _________________ The fact someone posts a thousand messages a month does not mean the messages contain anything worth reading.
Bob Hoover
1970 Beetle
1956 Ragtop Beetle |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15987 Location: North Florida, USA
Posted: Thu May 25, 2017 2:00 pm Post subject: Re: Wiring harness question |
The above wiring harness should be the ticket for your car.
Alternatively, the conversion from generator to alternator is rather simple and compared to re-wring the whole car is a "piece of cake". The diagram from Speedy Jim's site below shows the conversion:
It involves splicing two wires together to extend the blue #61 wire all the way to the alternator. You will need to clip the end of this wire off and replace the ring with a quick disconnect connector.
The hardest part is joining the three heavy gauge (8AWG) red wires together under the rear seat. If you can scrape up a stock alternator wiring junction (from a recycle yard?) it almost becomes a plug-n-play upgrade by just inserting the female terminals into the junction. Even the above wiring harness may not contain this junction.
If you cannot find one, you may need another type of junction that can support bringing three 8AWG wires together (car audio power distribution block?). Soldering them and then wrapping them in multiple layers of heat shrink tubing is probably a last resort. _________________ AshMan40
evillrdnikon Samba Member
Joined: February 26, 2014 Posts: 180 Location: Las Vegas
Posted: Thu May 25, 2017 2:09 pm Post subject: Re: Wiring harness question |
are you looking for a replacement harness or an upgraded harness with the newer style fuses? |
Posted: Mon May 29, 2017 11:56 am Post subject: Re: Wiring harness question |
Stock or not (which I don't know) My bug has a generator and I was thinking of updating wiring harness to later style fuses. Speedy Jim's diagram looks like it's a slam dunk and thank you for that!
Mark |
