Alphawolf9413 Samba Member
Posted: Fri May 26, 2017 6:46 pm Post subject: Won't turn on please help!! |
My 1964 bug won't turn on the headlamps work but the stereo won't I think it's the battery but I tried jumping it and it didn't work so do I need another new battery or what please help! I use the 12v battery |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Fri May 26, 2017 6:51 pm Post subject: Re: Won't turn on please help!! |
Turn on headlights. If your headlights don't dim when you try to start, then electrical wiring from the headlight switch or the electrical part of the ignition switch.
If the stereo doesn't work bu lights work, doubt that it's just a battery issue. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Fri May 26, 2017 7:05 pm Post subject: Re: Won't turn on please help!! |
It doesn't try to turn over at all. When I try to start it absolutely nothing happens |
KTPhil Samba Member
Posted: Fri May 26, 2017 9:33 pm Post subject: Re: Won't turn on please help!! |
Probably wiring issue; check the wire from the light switch to the fusebox and/or ignition switch. Start there and use a test light or VOM to check. |
