ytsejam82 Samba Member
Posted: Sat May 27, 2017 8:30 pm Post subject: 091 input shaft too long? |
hi! im going to change my 002 for a 091. i use clutch flywheel starter and bell housing from my 002, i have mounted the gearbox on the engine already. and it seems ok.
now i have second thoughts, is the input shaft too long since i use the the shorter. 002 bellhousing for my new 091? does it matter? thinking of endplay |
Posted: Sat May 27, 2017 9:07 pm Post subject: Re: 091 input shaft too long? |
ytsejam82 wrote: |
The input shaft has to match the engine. A Type 1 engine takes a shorter input shaft than a Type 4 engine. Both the 002 and 091 bellhousing are essentially the same depth, so have no bearing on what length shaft you use. |
Posted: Sun May 28, 2017 5:31 am Post subject: Re: 091 input shaft too long? |
thanks! that sounds great! i have a 2l type 4btw |
Tcash Samba Member
Posted: Sun May 28, 2017 11:21 pm Post subject: Re: 091 input shaft too long? |
The shafts in that photo are not labelled correctly.
The 002 tranny came with two different input shaft depending on which engine it was being used with.
The correct information from the source you link to is:
Quote: |
091 311 105 A, INPUT SHAFT ,1968-71 TYPE 2 BUS WITH A TYPE I ENGINE, 002 BELL HOUSING, , SHORT SNOUT (287MM OVERALL LENGTH)
091 311 105, INPUT SHAFT, 1972-79 TYPE 2 BUS WITH A TYPE IV ENGINE, 002 OR 091 BELL HOUSING, , LONG SNOUT (298MM OVERALL LENGTH) |
As you can see there is almost no difference in the depth of the bellhousings, the difference is mainly in the shape instead.
rustbus Samba Member
Posted: Sat May 04, 2019 3:33 pm Post subject: Re: 091 input shaft too long? |
so any baywindow bus transmission that was mated to a T4 engine will have the longer input shaft?
I'm swapping transmissions and my replacement has had its shaft cut short.
the existing input shaft is f#%ked where the oil slinger and input shaft seal ride... the whole transmission is toast
i have a couple 002 transmissions i can check for use.. will their shafts be long enough, can i measure with the bellhousing installed? _________________ May of '72 Deluxe. 2.0L L-Jet CS & 091 trans conversion
my Bus thread |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3898 Location: Seattle, WA
aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Sat May 04, 2019 11:08 pm Post subject: Re: 091 input shaft too long? |
Cut it off by 3/8 inch _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
babysnakes Samba Member
Posted: Sun May 05, 2019 5:33 am Post subject: Re: 091 input shaft too long? |
002 '71 and earlier had the short shaft. 002 '72 had a long shaft. But you have to measure. I replaced the the shaft in my '72 trans with a shorter one from an earlier bus. I didn't feel good about cutting the shaft. So you can't go by the numbers on the trans. |
Posted: Sun May 05, 2019 5:36 am Post subject: Re: 091 input shaft too long? |
002 '71 and earlier had the short shaft. 002 '72 had a long shaft. |
sodbuster Samba Member
Joined: August 08, 2004 Posts: 1085 Location: wherever my baywindow takes me.
Posted: Mon May 06, 2019 7:19 am Post subject: Re: 091 input shaft too long? |
You are already using your bell housing from your 002. Use the input shaft too. Take the 091 input shaft out and put the 002 input shaft in. be sure to re-use the 091 shaft coupler though. |
Posted: Mon May 06, 2019 8:39 am Post subject: Re: 091 input shaft too long? |
sodbuster wrote: |
As people have said above, the necessary input shaft it determined by the engine one runs (Type 1 or Type 4) and not the bellhousing. |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Mon May 06, 2019 9:34 am Post subject: Re: 091 input shaft too long? |
Wildthings wrote: |
sodbuster wrote: |
And more specifically for those who remember best with a factoid:
Type 1 engine supports the short input shaft with the pilot bearing right there in the gland nut holding on the flywheel.
Type 4 engine supports the long input shaft that has to travel through the flywheel all the way to the pilot bearing waaaaay inside the crankshaft itself.
Colin _________________ www.itinerant-air-cooled.com |
