hillmotorsports Samba Member
Joined: December 27, 2014 Posts: 432 Location: Morrisburg, Ontario, Canada
Posted: Sat May 27, 2017 5:36 am Post subject: Re: What did you do yesterday on your buggy? |
Jim
Is that a carbon shift tube? _________________ Rosemarie and Paul Hill
Morrisburg, Ontario
(With way more projects than spare time!) |
SoCal67Volks Samba Member
Joined: April 07, 2008 Posts: 158 Location: San Pedro California
Posted: Sat May 27, 2017 8:55 am Post subject: Re: What did you do yesterday on your buggy? |
hillmotorsports wrote: |
Jim
Is that a carbon shift tube? |
Paul,
Yes things were just too crowded and there was no way the stock shift tube would squeeze in. Even with the 1/2" diameter carbon fiber shift rod I had some trimming to do. _________________ 1967 Type 1 Sunroof
Meyers Manx Kickout
Meyers Manx SR2
"Making a car look complicated is easy, making it look simple is hard." John Buttera |
Singerdude Samba Member
Joined: March 07, 2015 Posts: 464 Location: Quebec, Canada
Posted: Sat May 27, 2017 9:15 pm Post subject: Re: What did you do yesterday on your buggy? |
Damn I wish we would be allowed to register custom made frames here. SoCal67Volks yours looks AWESOME. From a safety and regulations standpoint it doesn't make sense. i would have way more confidence in beating the snot out of that than a cut/welded stock one that endured 45 years of abuse. |
Posted: Sun May 28, 2017 3:40 am Post subject: Re: What did you do yesterday on your buggy? |
Singerdude
You need to adjust your perspective.....
If you think along the lines of of the Meyers Tow'd you can make a new frame similar to the frame here but utilize the rear suspension/torsion tube/transmission mount section of the VW frame. Now you still have an original, oem VW chassis number on a new and improved frame.
Not sure how much different the regs are in Quebec.... _________________ Rosemarie and Paul Hill
Morrisburg, Ontario
YDBD Samba Member
Joined: February 25, 2017 Posts: 891 Location: Bavaria, Germany
Posted: Sun May 28, 2017 6:06 am Post subject: Re: What did you do yesterday on your buggy? |
Out cruising the buggy with the bike trailer on a gorgeous day in Bavaria.. _________________ '56 pan Dune Buggy since '69
don't live in the past...but when I did:
'67 bug
'64 baja
'60 dune buggy
'73 Personenkraftwagen Type 182 "Thing" |
Posted: Mon May 29, 2017 2:02 pm Post subject: Re: What did you do yesterday on your buggy? |
Singerdude
Not sure how much different the regs are in Quebec.... |
Quebec has probably the strictest laws in CAN in respect to custom built cars but the lousiest, least enforced laws for regular cars... You see people on the roads with crapped out mid-90's Sunfire rustmobiles rolling undisturbed. But custom builders have to jump through endless hoops or sometimes bend the laws a bit to get their cars registered. Bureaucratic idiocy...
For sure there are workarounds like what you suggested, I not a fabricator by any stretch of the imagination so my results would be worlds away from a bought trick chassis from Airkewld or others... |
Posted: Mon May 29, 2017 6:35 pm Post subject: Re: What did you do yesterday on your buggy? |
Singerdude
Dave Barrett of Manxchassis (Arizona, not far from Las Vegas NV) would be my 1st choice but Berrien Buggy in PA could also build a tube chassis with an oem VW torsion/suspension/transmission mount with the serial number unmolested.
It might be worth your while to call either or both and discuss this directly with them. _________________ Rosemarie and Paul Hill
Morrisburg, Ontario
Posted: Mon May 29, 2017 6:58 pm Post subject: Re: What did you do yesterday on your buggy? |
Oh I'm not in need for a chassis, my buggy is complete. But seeing as it now has a rather lively 2276 in the back and I'm pushing it pretty hard on very twisty roads. I'm pretty sure I'm outside of the driving parameters that these things were originally engineered for. I'm also considering Turbo-ing it. Add to that the fact that a 45 years old chassis surely must have some sort of metal fatigue. A nice tube chassis with coilovers on all corners would be confidence inspiring and would add a lot of "trickness" factor. But if I ever start a buggy from scratch I will surely keep your ideas in mind |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 852 Location: South Florida
Posted: Sun Jun 11, 2017 9:43 am Post subject: Re: What did you do yesterday on your buggy? |
Replaced my buggy's rear window with a clean new piece of clear plexiglass:
Built its frame using window moulding from a VW Vanagon about 3 decades ago. Original plexi had yellow'd and micro stress crack'd; it was getting hard to see thru. |
911pickup Samba Member
Joined: March 06, 2004 Posts: 625 Location: Near Goats on the Roof
Posted: Thu Jun 29, 2017 7:55 am Post subject: Re: What did you do yesterday on your buggy? |
I finally got my Thing off the lift and running properly. I've decided to drive my Thing this summer and save my dune buggy project for the winter.
Storing my buggy this way gives me more room in my shop. More room means I now have room for another project.
motoRAT Samba Member
Posted: Sun Jul 02, 2017 11:15 am Post subject: Re: What did you do yesterday on your buggy? |
still working on the shell
_________________ Be curious, dismantle it all, reassemble it, go for a ride! |
Posted: Sun Jul 02, 2017 12:51 pm Post subject: Re: What did you do yesterday on your buggy? |
new dash and "tailgate"
cj92345 Samba Member
Posted: Sun Jul 02, 2017 1:50 pm Post subject: Re: What did you do yesterday on your buggy? |
[img]https://www.thesamba.com/vw/gallery/pix/1662891.jpg[/
Picked up wheels |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Sun Jul 02, 2017 7:53 pm Post subject: Re: What did you do yesterday on your buggy? |
cj92345 wrote: |
Picked up wheels |
Fixed it for you! _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
oprn Samba Member
Joined: November 13, 2016 Posts: 12740 Location: Western Canada
Posted: Mon Jul 03, 2017 6:30 am Post subject: Re: What did you do yesterday on your buggy? |
I ran into a snag on my new engine build, out of time to sort it out with all that is on our plate this summer so back in went the old tired 1600 DP with it's Kadrons and all their issues. Sorting out some details so we can drive it for the summer. Wiring yesterday and break adjustment today... |
Posted: Mon Jul 03, 2017 11:18 am Post subject: Re: What did you do yesterday on your buggy? |
thanks SBD! |
Posted: Thu Aug 03, 2017 11:11 am Post subject: Re: What did you do yesterday on your buggy? |
finally, the fiber is ready for paint
oprn Samba Member
Posted: Sat Aug 05, 2017 6:55 am Post subject: Re: What did you do yesterday on your buggy? |
I finally solved all the electrical issues I (and the previous 2 owners since 1976 no doubt) have been having. The original builder used the stock Bug wiring harness and fuse panel. No end of chasing electrical problems with lights etc. Then it dawned on me in the middle of the night that the fuse box including all the original ground connections were mounted on fiberglass!
I ran a ground wire from the fuse panel mounting bracket down to one of the master cylinder mounting bolts and... Bingo! All the problems evaporated! |
Posted: Sun Aug 06, 2017 3:54 am Post subject: Re: What did you do yesterday on your buggy? |
And I've done the controversial raptor
not bad, not bad at all _________________ Be curious, dismantle it all, reassemble it, go for a ride! |
oprn Samba Member
Posted: Sun Aug 06, 2017 6:31 am Post subject: Re: What did you do yesterday on your buggy? |
Aw man! After all that work I was hoping it would be shiny.
Anyway, good job and enjoy! |
