Lights pulsating (flickering)
Page: Previous  1, 2
Harleyelf
Harleyelf is offline
PostPosted: Sun May 28, 2017 10:50 am    Post subject: Re: Lights pulsating (flickering) Reply with quote
I'd examine the wires near the fuses for corroded connector tips and broken wire strands. They were bent at a sharp angle fifty years ago.
VW BRETT
VW BRETT is offline
PostPosted: Mon May 29, 2017 10:12 am    Post subject: Re: Lights pulsating (flickering) Reply with quote
Going to replace the generator I think the stater is just to worn out or maybe a bad section in the winding
YOU CAME IN THAT THING? YOU'RE BRAVER THAN I THOUGHT.
63 SINGLECAB
67 13 WINDOW DELUX
20 ATLAS
VW BRETT
VW BRETT is offline
PostPosted: Mon Apr 15, 2019 4:10 pm    Post subject: Re: Lights pulsating (flickering) Reply with quote
Well I figured it out and forgot to post the solution, turned out I had the unusual 38 amp gen and was trying to use a 30 amp regulator, updated to the correct 38 amp regulator and problem solved. Boy do I feel dumb, never even thought to check the amps on the gen, had the motor out and was replacing it when I noticed it, did put a new 38 amp gen in as well so now I have an extra one
63 SINGLECAB
67 13 WINDOW DELUX
20 ATLAS
BarryL Premium Member
BarryL is offline
PostPosted: Mon Apr 15, 2019 6:56 pm    Post subject: Re: Lights pulsating (flickering) Reply with quote
That was a one year only generator that had it's own fan tin, hub, and fan bolt. Glad you fixed it.
VW BRETT
VW BRETT is offline
PostPosted: Tue Apr 16, 2019 6:36 am    Post subject: Re: Lights pulsating (flickering) Reply with quote
The motor was built by the PO I had no idea never even heard of a 38 amp gen. The Samba forums are what educated me on the subject.
63 SINGLECAB
67 13 WINDOW DELUX
20 ATLAS
Page: Previous  1, 2
Page 2 of 2
