FF007 Okrasa Gullwing Coupe Build
Chris R
Chris R is offline
PostPosted: Thu May 25, 2017 6:32 am    Post subject: FF007 Okrasa Gullwing Coupe Build Reply with quote
Hi Guys,
It's been over 5 years since I posted my first vintage speed build here and I am pretty excited to share my progress on my latest work with you. I wanted to thank everyone from the forum here that has shared their thoughts and support.
FF007 is a coach built, one-off design. I like to tie in influential design elements of an era in an effort to make a car that could almost be something that went missing back in its day.
Tom Bruch whom I met through this forum has become a great friend and many of the ideas that I put into my builds get bounced off of him.
The Okrasa "40HP" Engine was originally built for drag racing Ghia on the East Coast back in the 70's. Tom found the engine after being stored for something near 30 years and gave it a massage before sending it my way for the Coupe.
Here's what Tom had to say about the engine:
"This is a chickenhouse find that has been stored for more than 30 years that I know of. It is an 1800cc 74x88mm with Corvair pistons & cylinders. It has Okrasa heads, manifolds, and carbs. Very light 180mm flywheel. A quite nasty Engle cam. 9.5:1 compression. 1:1 1600 rockers. 8 dowel crank. Possibly an eary Clauds Buggy crank. The block is stamped with "KD" (factory rebuild) and a second "#961307" on the right side of the generator stand.
It could have seen some race use because the intake manifolds were ported, the throttle shafts profiled, thinned, and polished. The 32PBJ carbs appear to have been carefully cleaned up and deburred inside.
I have been able to trace some of the history. It was built in the late Sixties by Eddy Brahn who was the driver of the VW drag car called "Half Gas" with some connection to Victory VW in Newport News VA. The engine was built for a returning Vietnam Vet and hauled to Iowa in the right front seat of a Ghia. It was street raced for years in the Ghia until the car rusted out. The engine then changed hands a few times and ended up in a chickenhouse. I have to thank the person the stored it. There was clean oil in it, holes plugged and sealed. It was kept dry and turned over by hand. I actually started it in as-found condition and it sounded good. No noise or smoke. A few pushrod tube leaks, that was it."
More photos of the car:
mcdoc2000
mcdoc2000 is offline
PostPosted: Thu May 25, 2017 5:33 pm    Post subject: Re: FF007 Okrasa Gullwing Coupe Build Reply with quote
Great build! I'm looking forward to seeing this come along
Lingwendil
Location: Oakley, behind enemy lines in communist California
Lingwendil is offline
PostPosted: Thu May 25, 2017 10:19 pm    Post subject: Re: FF007 Okrasa Gullwing Coupe Build Reply with quote
Shocked
73 super beetle thread!
http://www.thesamba.com/vw/forum/viewtopic.php?t=649622
How to- Modify your Kadrons for SVDA!
http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
slalombuggy
slalombuggy is offline
PostPosted: Fri May 26, 2017 9:31 am    Post subject: Re: FF007 Okrasa Gullwing Coupe Build Reply with quote
WOW!!!!
If I ever win the lottery, you will be the first person I call, even before family
WOW
brad
1962 Canadian Buggy 121.253mph - Bonneville 2012
1957 LSR Buggy - Rowan's Rocket - goal -150mph
49vwsplit
49vwsplit is offline
PostPosted: Fri May 26, 2017 12:08 pm    Post subject: Re: FF007 Okrasa Gullwing Coupe Build Reply with quote
Check out his website. There's a cool vid on the car and some of the work involved in making this piece of art.
Spectacular Chris!!!
Officer: License and registration please.
Driver: What's the problem officer?
Officer: It indicates here you require glasses to operate a motor vehicle.
Driver: It's OK officer, I don't wear glasses..I have contacts.
Officer: I don't care WHO you know!!
anthracitedub
anthracitedub is offline
PostPosted: Sun May 28, 2017 8:52 am    Post subject: Re: FF007 Okrasa Gullwing Coupe Build Reply with quote
Very awesome work! Got the shits just looking at it.
Peter_N
Peter_N is offline
PostPosted: Mon May 29, 2017 12:04 pm    Post subject: Re: FF007 Okrasa Gullwing Coupe Build Reply with quote
Those curves Razz
I would love to see this project coming along!
Just interested, is one of the FFs equiped with a more performance based engine? Would be kinda cool to have such a nice car with 200bhp or so Cool
My 1958 PGSG project topic
Chris R
Chris R is offline
PostPosted: Fri Jun 16, 2017 8:17 am    Post subject: Re: FF007 Okrasa Gullwing Coupe Build Reply with quote
Thanks for all the feedback. Peter_N, I have a 160HP build coming along right now. That car will weigh around 1200LBS.
I've now completed the Gullwing and have had wonderful drives with it. Here is a quick video:
slalombuggy
PostPosted: Fri Jun 16, 2017 9:21 am    Post subject: Re: FF007 Okrasa Gullwing Coupe Build Reply with quote
WOW
