fifthcenturycheese Samba Member
Joined: May 04, 2014 Posts: 172 Location: Pismo Beach
Posted: Mon May 29, 2017 7:03 pm Post subject: Can you identify this case in this 67??? |
Sorry, I don't have the serial number, does anyone out there recognize what this case might be in this 67? Can't recognize the gray painted lobe under the distributor...Thanks for your help!
aircooled Samba Member
Joined: December 02, 2003 Posts: 1290 Location: Heartland, Neb
Posted: Mon May 29, 2017 7:55 pm Post subject: Re: Can you identify this case in this 67??? |
Go to the Technical tab https://www.thesamba.com/vw/archives/info/bugchassisdating.php. I can't see the serial number in your picture. _________________ 67 Sun Roof / Born Sept 66 / Second Owner
67 Convertible / Born Aug 66 / Second Owner
Member of 67 Posse
Omaha Volkswagen Club
Neb VVWCA Chapter Rep
Volkswagen Club of Nebraska |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Tue May 30, 2017 7:44 pm Post subject: Re: Can you identify this case in this 67??? |
I was able to take a picture of the engine case today, here is the number...
Looks like H 5441999 Looks like someone painted it for some reason, either bad paint or case got too hot???
Thanks again....Mike |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Tue May 30, 2017 8:47 pm Post subject: Re: Can you identify this case in this 67??? |
At the technical tab atop this page you will find a link to a VIN list. It starts with Bus so click on Bug. I'm not seeing an H case by itself. Likely restamped.
Cases are often painted when they are rebuilt to make them look all purty. Flaking paint on a case is as much and indicator of old rebuild as it is having gotten too hot. Heat cycles in an engine are a parts of it's multiple lives. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Tue May 30, 2017 8:55 pm Post subject: Re: Can you identify this case in this 67??? |
Tasb, could this be an "H 5" case maybe? |
Zundfolge1432 Samba Member
Posted: Wed May 31, 2017 6:26 am Post subject: Re: Can you identify this case in this 67??? |
H5 yes and this is a perfect example of what happens when you paint a case. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31359 Location: Hot Arizona
