Farf Samba Member
Posted: Tue May 30, 2017 4:30 pm Post subject: Re: Soldering old, corroded copper wires (how to w/pics) |
epowell wrote: |
...one good pigeon-poop solder pic from a fledgling newby and the whole forum is HOPPING |
Admit it Ed, you've been trolling us from the start... |
kamzcab86 Samba Moderator
Posted: Tue May 30, 2017 5:01 pm Post subject: Re: Soldering old, corroded copper wires (how to w/pics) |
epowell wrote: |
Thanks so much Sodo for this help! [and everyone else also!] This place is a Gold Mine full of wonderful, generous, and KNOWLEDGABLE Dudes! |
And dudettes... just sayin'.
epowell wrote: |
You have to admit, this foto is priceless
[pic] |
When I first ventured into soldering, that's about what my solder job looked like (wires were twisted in the parallel style though). However, I practiced-practiced-practiced! on scrap wire first. _________________ ~Kamz
2016 Golf GTI S
epowell Samba Member
Joined: September 23, 2015 Posts: 4733 Location: Czech (mostly) Vancouver (sometimes)
Posted: Wed May 31, 2017 12:21 am Post subject: Re: Soldering old, corroded copper wires (how to w/pics) |
E1 wrote: |
Thanks Sodo and responders, great info! |
Yes it is... and my van is absolutely FULL of these kinds of bogus electrical connections. Just when I was thinking that I was 'getting ahead' with my van, I now realize that I need to not only learn soldering properly, but go thru ALL the wiring (eventually), and re-do most if not all of it. _________________ www.edwardpowell.com |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22641 Location: NYC/Upstate/ROW
Posted: Wed May 31, 2017 2:28 am Post subject: Re: Soldering old, corroded copper wires (how to w/pics) |
epowell wrote: |
Wow! Soldering is a popular topic! [even more than welding!]
We all started here , until some one taught us better, or until the Internet. _________________ .ssS! |
Gnarlodious Samba Member
Joined: September 28, 2013 Posts: 2319 Location: Adobe Jungle USA
Posted: Wed May 31, 2017 7:50 am Post subject: Re: Soldering old, corroded copper wires (how to w/pics) |
Sodo wrote: |
Gnarlodious wrote: |
I can't hardly believe I'm the only person on this board that uses acid flux. |
So you recommend acid flux on stranded wires in a corrosive environment?
If OK, this is exactly what members need to know. |
I do. The advantage of a good solder outweighs any disadvantage of excess paste on the metal. The paste I use is greasy and is only corrosive when hot. A good paste vaporizes totally at soldering temperature, leaving no residue. Use it sparingly, I do sometimes use a solvent to to remove excess, especially when soldering delicate boards:
_________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
cmayna Samba Member
Joined: August 18, 2014 Posts: 1147 Location: SF Bay area, CA
Wife said that since I am old, corroded and tired.....er wired , I should be able to appreciate this thread, which I do. I'm always out in the shop puttzing around with the welder, soldering iron, torch, etc.
It's always nice to learn different way to resolve such issues. I use steel wool or sand paper to help remove corrosion off of wires just as you would on copper pipes right before applying heat. _________________ '90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig |
Posted: Wed May 31, 2017 9:08 am Post subject: Re: Soldering old, corroded copper wires (how to w/pics) |
I liked the cleaning of flux, but my customers insisted I flux off, so I stopped. _________________ .ssS! |
Terry Kay Banned
Posted: Wed May 31, 2017 9:18 am Post subject: Re: Soldering old, corroded copper wires (how to w/pics) |
Liquid acid flux works great.
A Little Dab will do ya. _________________ T.K. |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Wed May 31, 2017 4:54 pm Post subject: Re: Soldering old, corroded copper wires (how to w/pics) |
Abscate wrote: |
I liked the cleaning of flux, but my customers insisted I flux off, so I stopped. |
If any of my customer said that, I would tell them to flux you. To each their own I guess. |
