Clutch Throw out (release) Bearing
Page: Previous  1, 2
Forum Index -> Eurovan Share: Facebook Twitter
Jooknon
Jooknon is offline
PostPosted: Thu Jun 01, 2017 12:37 pm    Post subject: Re: Clutch Throw out (release) Bearing Reply with quote
Ok. A used transmission is on its way from Nashville today, with plans to install it over the weekend.
I'll be putting a new clutch kit and guide bearing sleeve thing. Is there any other parts/sealants/gaskets/O-Rings that I should be putting in there?
The only other possible thing I can thing of is this, "Always replace seal between flange shaft and drive shaft" but the book never clearly states what the flange shaft is. Can someone clear this up?
Does anyone have any tips or tricks that I know before just going with the instructions in the Bentley manual?
How necessary is the VW3250 tool? Can I get away without it?
Ben
93 MV Weekender
cc-91tech
cc-91tech is offline
PostPosted: Thu Jun 01, 2017 2:49 pm    Post subject: Re: Clutch Throw out (release) Bearing Reply with quote
Hallo Ben,
i think its to late form my answer but you need not the tool.
I hope it went well.
Andy
Jooknon
Jooknon is offline
PostPosted: Thu Jun 01, 2017 6:50 pm    Post subject: Re: Clutch Throw out (release) Bearing Reply with quote
Thanks Andy.
I'm not starting until Saturday morning.
Any other tips I should now? or steps in the manual that I can skip?
Thanks!!
Ben
93 MV Weekender
cc-91tech
PostPosted: Thu Jun 01, 2017 9:43 pm    Post subject: Re: Clutch Throw out (release) Bearing Reply with quote
Hello Ben,
Take the left drive shaft completely out, you have more space.
At the transmission wele copper paste, and also lubricate the release bearing.
The coupling you can center with a big thorn.
Installation and removal with lifting platform roundabout 4 hours.
If you have any questions do not hesitate to contact us.
And sorry for my english I come from Germany.
And leave space to adjust the engine up and down.
Andy
Jooknon
Jooknon is offline
PostPosted: Sat Jun 03, 2017 7:02 am    Post subject: Re: Clutch Throw out (release) Bearing Reply with quote
Did you have to remove the right drive shaft as well? Or could you leave it connected on the wheel side?
Ben
93 MV Weekender
Mr Brown
Mr Brown is offline
PostPosted: Sun Jun 04, 2017 7:02 am    Post subject: Re: Clutch Throw out (release) Bearing Reply with quote
I rebuilt my gearbox last summer, not too difficult but then I had an aircraft component overhaul shop at my disposal. Those rollers are most likely from the small bearing in the mainshaft which is the common failure item.
As for re & re of the gearbox I took off far more than the book states to make it easier to handle the gearbox but I was doing other maintenance such as PS rack rebuild coolant flush etc. You may want to do the flywheel while you are in there which requires a holding tool and new stretch bolts. I would set side a full two days if you are doing this on the ground.
Jooknon
Jooknon is offline
PostPosted: Sun Jun 04, 2017 7:09 am    Post subject: Re: Clutch Throw out (release) Bearing Reply with quote
Thanks for the info.
I've currently got it up on on my neighbors lift and the transmission is out. Found that the clutch release levers little spring clip was broken and the little nub it levers on had worn a hole all the way thru it. Got a new clutch kit and release bearing and release bearing guide installed last night
Today will be installing the replacement tranny, putting in some new linkage bushings and putting it all back together.
Ben
93 MV Weekender
cc-91tech
PostPosted: Sun Jun 04, 2017 10:35 am    Post subject: Re: Clutch Throw out (release) Bearing Reply with quote
Hello Ben,
good job.
Let me know when you're done.
If you sometime want to convert to syncro let me know.
Greetings Andy
Jooknon
Jooknon is offline
PostPosted: Mon Jun 05, 2017 4:44 am    Post subject: Re: Clutch Throw out (release) Bearing Reply with quote
Just finished the tranny install last night. So far the junkyard transmission is doing great. I was worried at first because of a ticking sound but turned out the 5th gear cover had a small dent in it that needed pushing back out. Sorry about a lack of pictures but my hands were too greasy.
On another note I changed the oil (first since I've owned it). Getting that oil filter off SUCKS!!!! Is there a special trick I don't know about? I couldn't fit any filter straps in there and ended up having to do a combination of channel locks and stabbing it with a screwdriver to turn the dang thing. It had a WIX filter on it so that's what I put on. But I did see online that there ones with that nut welded to the end so you can use a socket. Is that the kind I should be using?
Today I'll be driving the van to work, as a test drive. Fingers crossed nothing bad happens.
Ben
93 MV Weekender
Jooknon
Jooknon is offline
PostPosted: Mon Jun 05, 2017 5:05 am    Post subject: Re: Clutch Throw out (release) Bearing Reply with quote
Forgot I had this one:
Ben
93 MV Weekender
Joshwa
Joshwa is offline
PostPosted: Mon Jun 05, 2017 5:48 am    Post subject: Re: Clutch Throw out (release) Bearing Reply with quote
Nice work
93 Weekender TDI conversion (AHU)
93 MV TDI conversion (1Z)
Weekender rear cot
Late model cabin air filter on 93
Euro spec bumper install on 93
Reply to topic    Forum Index -> Eurovan All times are Mountain Standard Time/Pacific Daylight Savings Time
Page: Previous  1, 2
Page 2 of 2
