67dubcab Samba Member
Joined: February 12, 2009 Posts: 214 Location: sebastopol C.A
Posted: Mon May 01, 2017 10:28 pm Post subject: Re: Porsche Powered Mid-Engine Double Cab Build |
The D.C. is back on its wheels and off the lift.
The basic swap is done, still have to fabricate the tandem master cylinder and clutch master mounting plate thingy in the cab.
It is very rough at this point, as I want to see if all the geometry is right before finishing the mounts, brackets, ect....
So far just pushing it off the lift and maneuvering it about the steering effort is much less than stock, like half.
_________________ Porsche powered mid-engine double cab build
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...highlight= |
slowlearner Samba Member
Joined: November 11, 2016 Posts: 12 Location: Sydney, Australia
Posted: Thu May 25, 2017 4:38 pm Post subject: Re: Porsche Powered Mid-Engine Double Cab Build |
Hi there, I've just finished reading through this whole thread. WOW! Just WOW!
Huge props to you for all the great work. Sad you've got two junky motors, but you've made it work and raced it. More than most people ever get done on any project. Keep up the good work.
P.s. twistedminis is fantastic! |
Posted: Wed May 31, 2017 7:59 pm Post subject: Re: Porsche Powered Mid-Engine Double Cab Build |
Thanks slow learner for checking in.
Hopefully more track time in the future, the goal is to get it worthy of open track testing and D.E. events.
I re-located the oil cooler to the spot I was planning on after the A-arm suspension swap, with the beam gone it should get sufficient flow (still need to add ducts).
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Thu Jun 01, 2017 5:55 am Post subject: Re: Porsche Powered Mid-Engine Double Cab Build |
67dubcab wrote: |
Going to go back to the stock front bumper now? |
Posted: Sun Jun 04, 2017 6:39 am Post subject: Re: Porsche Powered Mid-Engine Double Cab Build |
I like that much better than your front bumper. |
Posted: Sun Jun 04, 2017 10:17 am Post subject: Re: Porsche Powered Mid-Engine Double Cab Build |
The bumper center vent is staying but will get further modified for the new layout. I am planning on closing in the air path for better flow with some abs sheeting.
The new spot will help take some weight off the nose and be less vulnerable so that is a win.
I know the bumper is a bit abrupt visually, but the final version will be a bit cleaner. _________________ Porsche powered mid-engine double cab build
Mid Engine Bug Samba Member
Posted: Sun Jun 04, 2017 3:40 pm Post subject: Re: Porsche Powered Mid-Engine Double Cab Build |
Nice to see another mid engine VW on here! Will be following your build since our vehicles share a few similarities.
And did I read that you arent running sway bars? All I run is a front and it made a huge difference. Just had to mess with the rear spring rates after. |
Posted: Sun Jun 04, 2017 6:04 pm Post subject: Re: Porsche Powered Mid-Engine Double Cab Build |
Hey mid engine bug guy.
Yep, lots of solving of the same build details, to me the most interesting part.
I have seen your build on another forum, I appreciate both the concept and your solutions, nicely crafted sir!
There is another build like yours, by Volkdent on the german look forum, which you may have seen.
As to the sway bars, I did not put them on my earlier version as I new I was going to swap out the complete front end, I relied on high spring rates to keep roll in check, though if you check out my autocross video there was still plenty.
I am presently looking for a adjustable splined bar set up for the new front end, looks like you are using one on your rig.
Stephen _________________ Porsche powered mid-engine double cab build
Posted: Sun Jun 04, 2017 9:52 pm Post subject: Re: Porsche Powered Mid-Engine Double Cab Build |
Stephen - thanks for the good words on my Bug. I know you have put just as much sweat and tears in to your VW and the outcome shows. I am pretty sure I have seen the other build by Volkdent. Nice build as well.
I did see your video and the amount of body roll. Between your new front suspension and a sway bar, it should be taken care of. Yes I am using just a standard straight splined sway bar. I got it from Kartek offroad. They have a bunch of different sizes to use. They also have a couple different selections for the arms coming off it. I trimmed mine a few inches shorter but of course that will depends on the application and a million other things. If you have any questions along the way, feel free to ask. Good luck with the rest of your awesome build!
Sean |
Posted: Thu Jun 15, 2017 7:48 pm Post subject: Re: Porsche Powered Mid-Engine Double Cab Build |
Thanks Sean for the kind words and the Kartek site tip.
I finally found a site that has the spring rates for the different splined bars and connecting arm lengths at HRPWORLD. Now I can guesstimate the bar rate to try and get it close the first time.
I will see if the #550 coil springs are about right then add in the sway bar rate to get in the total spring rate frequency ballpark (race truck/dump run truck)!
One of the last bits to do is the new braking system, mostly mounting the pedal assembly. Got the basic idea figured out, now working on fabrication.Lots left to do.
Posted: Sat Jul 22, 2017 6:25 pm Post subject: Re: Porsche Powered Mid-Engine Double Cab Build |
Finished plumbing the pedal/master cylinder thing.
Took it for a spin for the first time in seven months.
Initial impressions: much lighter steering effort, more steering angle lock to lock which should help during drift competitions
Improved steering feel, though not as much as expected from a manual rack and pinion as I think the bevel box blocks some feel.
Will know more after rough tuning suspension alignment and dialing in spring rate. _________________ Porsche powered mid-engine double cab build
californiadrifter Samba Member
Joined: January 23, 2017 Posts: 4 Location: Redondo Beach
Posted: Sun Jul 23, 2017 12:25 pm Post subject: Re: Porsche Powered Mid-Engine Double Cab Build |
Wow! I'm new to the forums and really enjoyed reading this whole thread. What a monumental accomplishment, just getting this on the road. Congrats!
Looking forward to seeing where you go from here. |
Posted: Sun Aug 13, 2017 7:02 pm Post subject: Re: Porsche Powered Mid-Engine Double Cab Build |
Thanks for the kind words californiadrifter.
I drove to the treffpunkt show in concord with a buddy, the front tires were rubbing on the inner arches on bumps so I swapped the rear coilers which have #650 springs with the fronts (#550) and felt like that should be the correct spring rate, still going to add front splined sway bar to help with roll.
found this photo in the d.c. gallery, Im the guy on the right with the hippie hair. _________________ Porsche powered mid-engine double cab build
Posted: Sun Aug 13, 2017 7:12 pm Post subject: Re: Porsche Powered Mid-Engine Double Cab Build |
credit to DadaCheese for photo, Im sure there were other samba folk attending as there were plenty of lovely Volkswagens and Porsches scattered amongst the greens. _________________ Porsche powered mid-engine double cab build
TommyTotembus Samba Member
Joined: March 27, 2014 Posts: 16 Location: Sebastopol, CA
Posted: Tue Aug 15, 2017 9:45 pm Post subject: Re: Porsche Powered Mid-Engine Double Cab Build |
67dubcab wrote: |
Will know more after rough tuning suspension alignment and dialing in spring rate. |
Brakes upon brakes! so next time that i ride with you me arse will pass by me face at the stoplight?! |
Posted: Wed Sep 27, 2017 11:32 pm Post subject: Re: Porsche Powered Mid-Engine Double Cab Build |
Hey Tommytotumbus, only if you choose not to fasten the four point safety harness, then yes-you could end up outside the bus,in front.
I needed all the brakes I had today as two dudes in a lowered Miata cut me off in a clown maneuver. All sixteen little Brembo pistons were in full effect.
As I told my wife, all the work is to make the bus safer, in this case it paid off.
Would have been a pretty hard hit with stock brakes, plus I needed to steer around them as I held the brakes at threshold, so win for suspension mods too.
Credit also for many years of sport bike riding as the only way to remain death-free on a motorcycle is to expect stupid at ANY time. _________________ Porsche powered mid-engine double cab build
SplitBusVanatic Samba Member
Joined: August 16, 2005 Posts: 338 Location: Co. Mayo. Ireland
Posted: Thu Oct 12, 2017 10:03 am Post subject: Re: Porsche Powered Mid-Engine Double Cab Build |
67dubcab wrote: |
?.... the only way to remain death-free on a motorcycle is to expect stupid at ANY time. |
Love it.
So true.
Great build thread. One of my favourites. |
Posted: Mon Apr 16, 2018 7:07 pm Post subject: Re: Porsche Powered Mid-Engine Double Cab Build |
Thanks SplitBusVanatic.
Took the D.C. off the road for a bit to finish up the front suspension install, made some small adjustments and did the final welding of the pick-up points.
prepping frame rails
finish welding parts and paint
bolting in arms
all back in
Posted: Fri Feb 22, 2019 9:13 pm Post subject: Re: Porsche Powered Mid-Engine Double Cab Build |
D.C. back on the lift for some more mods/hacks.
Finally got the three piece wheels built with the widths/offsets that I needed.
Next up were anti-rub tubbs.
Wheels are front-17"8.5" rear-17"9.5"
Tires front 225/45/17 rear 255/40/17 _________________ Porsche powered mid-engine double cab build
Posted: Tue Feb 26, 2019 9:29 pm Post subject: Re: Porsche Powered Mid-Engine Double Cab Build |
Missed this shot of the tubs roughed in, plenty left to do to call them done.
Suspension now has 3" off droop and 2.5" of compression before fouling and with #700 springs I should be able to jump railroad crossings at 110.
Will be a bit of time till I road test as I need to pull engine for a dramatic oil leak and likely have transaxle re-built with L.S.D. installed so I am no longer one wheel drive.
