Andrew Samba Member
Joined: October 27, 2000 Posts: 5865 Location: Who in the what now?
Posted: Tue Oct 12, 2004 6:17 pm Post subject: Anybody running an aftermarket swaybar? |
Where did you get the bushings for it. The thick ones that go around the sway bar and then clamp to the lower torsion arm. The bushings that came with my sway bar are way too small to work with the stock clamps, but I can't find anyplace that will sell the bushing or the clamp kit for a 7/8" sway bar... Help? _________________ -Andrew |
beep Samba Member
Joined: March 02, 2004 Posts: 30 Location: columbia,sc
Posted: Tue Oct 12, 2004 7:58 pm Post subject: |
Andrew, Try http://www.addco.net/
Addco Mfg. Linville, NC lists a 7/8 front sway bar... I would assume that they also have the mounting hardware.
I wouldn't be beyond trying to drill out the stock rubber bushings to accept the larger bar... _________________ 66 21dlx |
rusty57 Samba Member
Joined: October 21, 2003 Posts: 2089 Location: Bakersfield,CA.
Posted: Tue Oct 12, 2004 8:16 pm Post subject: |
I don't mean to jump in, but i was wondering if anyone knows if a swaybar from a 66 will bolt right up to a 65 front end with no mods. Thanks. _________________ 67 Ghia coupe, Retired military.
www.TagDefender.com |
imtb Samba Member
Posted: Fri Apr 07, 2017 11:12 am Post subject: Re: Anybody running an aftermarket swaybar? |
I've used the front addco in the past and was very happy with it. I ordered both from autoanything and installed the front right away quick and easy. I even left the stock one figured it couldnt hurt and this thing needs all the helpit can get in the wind. I finally got around to installing the rear, not as easy as front but well worth it. I am happy I did it, with the stiffer tires and front and rear sway bars I am not getting blown around on the higway, the bus finally feels planted on the road.
Front hard to see.
Rear.
easy e Samba Member
Joined: May 28, 2008 Posts: 3930 Location: 1 hr north of Santa Barbara
Posted: Tue Apr 11, 2017 7:03 am Post subject: Re: Anybody running an aftermarket swaybar? |
Everywhere is out of the rears...
I contacted Addco... the 952 rear (for 55-67) was discontinued last year.
They said they'd make a run of them... but it had to be an order of more than ten.
I'm making an order.
Send me a PM if interested (future planning... if you're reading this in 2018, don't PM me)
Is that stock + Addco swaybars on the front?
_________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
imtb Samba Member
Posted: Tue Apr 11, 2017 7:13 am Post subject: Re: Anybody running an aftermarket swaybar? |
Yes, on front stock + addco. I figured the stock one is helping reinforce front end. I'll try and take a better pic.
Did you check with autoanything? Scott is the conatct, I talked too. |
easy e Samba Member
Posted: Tue Apr 11, 2017 7:55 am Post subject: Re: Anybody running an aftermarket swaybar? |
imtb wrote: |
Did you check with autoanything? |
Yes, I called & talked to a human.
They looked up "Addco" for sway bar for split VW bus... no sway bar. _________________ aka: Evan
Mr. Electric Wizard Samba Member
Joined: August 07, 2003 Posts: 2846 Location: Smyrna, TN
Posted: Tue Apr 11, 2017 9:00 am Post subject: Re: Anybody running an aftermarket swaybar? |
I would love to have a rear on my 1966 bus.
Maybe after I've done everything else though.
Not in a super big hurry. _________________ "Saying what we think gives us a wider conversational range than saying what we know."
~ Cullen Hightower
(T)exas (C)oalition (B)uses
(H)eidenhammer (B)ully (B)oyz
--1966 De Luxe Camper |
dlicious Samba Member
Joined: September 07, 2006 Posts: 245 Location: Spring(pronounced Sprang), TX
Posted: Tue Apr 11, 2017 7:01 pm Post subject: Re: Anybody running an aftermarket swaybar? |
I would be interested in a rear sway bar.
I'm still trying to figure out which front one to get! Empi one comes with crappy bushings, but no clamps. I can't seem to find another manufacture.
And now I'm reading up on camber compensators for the rear. None listed specifically for a bus, but everybody says they work.
Did they say how long it would take to bring to market once they had 10 orders? _________________ '63 Caravelle Camper
dLk |
Clara Samba Member
Posted: Tue Apr 11, 2017 7:10 pm Post subject: Re: Anybody running an aftermarket swaybar? |
On my '61 15 window on the front I have a front 66/67 VW bus sway bar.
On the rear I have a vintage EMPI camber compensator.
Driving yesterday I noticed on a particular curve it handled better than the '66 Cragar Kombi with stock front sway bar.
I was driving about 10mph faster. 50mph instead of 40mph
_________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
easy e Samba Member
Posted: Wed Apr 12, 2017 11:31 am Post subject: Re: Anybody running an aftermarket swaybar? |
I got the front ordered through Summit.
Let me know when the rear is available for purchase. _________________ '63 Caravelle Camper
dLk |
60freak Samba Member
Joined: October 08, 2002 Posts: 861 Location: Indiana
Posted: Wed Apr 12, 2017 12:06 pm Post subject: Re: Anybody running an aftermarket swaybar? |
FWIW-Here is what I did with my '65 sundial. Swaybars (7/8") and camber compensator are empi products I believe. Welded 2 mounting tabs for rear sway bar near the transmission cradle (see pics). Bus handles like a dream at 75-80mph on the interstate (2007cc with VERY tall gearing), semi's don't push the bus around or make it "rock", takes curvy roads awesome too. Been offroading on rock trails a lot with only 3 wheels making contact to ground and never had any issues. Figured this may give you ideas. Good luck!
imtb Samba Member
Posted: Wed Apr 12, 2017 1:36 pm Post subject: Re: Anybody running an aftermarket swaybar? |
I thought about mounting my rear like in the above pics, welding to the tranny craddle, but followed the instructions.
Question would the camber compensator keep my wheels from tucking in. I am trying to lift with coil overs, excpet when I raise them it just pushes down on the wheels and jacks them in. Or do I have week torsion bars and need to readjust?
I am up to almost 65 pretty stable but still feels a little squirly.
Here is the front sway bar and mounting detail Maybe if I used longer bolts on the end link I could rotate level, I may try that. I probably should take off stock one but dont really casuing any issue.
easy e Samba Member
Posted: Wed Apr 12, 2017 1:44 pm Post subject: Re: Anybody running an aftermarket swaybar? |
The camber compensator and rear sway bar do the same thing... apply a restorative force on the axles.
The bigger your coil overs... the more restorative force you'll need = a dead end for raising (unless you want real stiff suspension).
To keep same ride quality as stock... you'll need to change the geometry but not applied forces... kinda the opposite of how a dropped spindle would be. _________________ aka: Evan
Clara Samba Member
Posted: Wed Apr 12, 2017 2:12 pm Post subject: Re: Anybody running an aftermarket swaybar? |
imtb wrote: |
Question would the camber compensator keep my wheels from tucking in. I am trying to lift with coil overs, excpet when I raise them it just pushes down on the wheels and jacks them in. Or do I have week torsion bars and need to readjust?] |
It is normal for the rear wheels to tuck when you lift them off the ground.
A camber compensator does not change this. Don't worry about it.
The only split bus I had that did not do wheel tuck this was the baja BD. It has suspension mods. It was class 7 off-road raced in 1976. I think the thing on the RGBs is a Johnson anti-hop kit. You might look in the off road forums for anti-tuck info. If you feel you really need it.
Evidently if you catch air it can be a good thing.
Lack of tuck when airborne:
https://www.thesamba.com/vw/gallery/pix/248482.jpg
https://www.thesamba.com/vw/gallery/pix/173452.jpg _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4532 Location: Cedar Falls, Iowa
Posted: Sat Apr 15, 2017 6:45 pm Post subject: Re: Anybody running an aftermarket swaybar? |
dlicious wrote: |
Did they say how long it would take to bring to market once they had 10 orders? |
In theory, a rear anti-sway bar (AKA anti-roll bar) on a swing axle bus should not work. Or at least should not lead to better handling.
Here's the history:
The first application I know of a leaf spring camber compensator was a Porsche with Super 90 engine. 1960? They were installed together with about 2 clicks less torsion bar preload. IOW the camber compensator was carrying some of the vehicle weight.
Why it worked was: Decouple the rear suspension from the chassis. This lets the body roll MORE. as the body rolls more, it puts more load on the outside FRONT wheel. This also keeps the rear from jacking up so much and tucking in. Since the tires are more vertical, they develop more lateral force.
I believe all Porsche 356C's used these, but perhaps only the SC, which was the S90 successor.
Corvair went to these on their last year with the swing axle, 1964.
VW went to something like this in 66,67 and 68 4 speed cars. But wait- they were anti sway bars? No, they are Z-BARS, a anti roll bar with levers going opposite directions. So it does JUST THE OPPOSITE OF A conventional anti roll bar.
But to work, you need to reduce the load of the torsion bars on the spring plates. That the only thing that decreases the roll couple.
Oh, Daimler Benz used about the same thing on all their 1950s cars that had the LOW-PIVOT swing axles. There was a compression spring between the two axle housings.
So, maybe your bus is better with a rear conventional anti roll bar, but I cannot understand why, because it flies in the face of everything I know.
And Mercedes and Porsche and VW: with swing axle rear, you push the roll couple to the front. Tires don't bite when tucked in.
A 1963 Porsche tested higher on a skid pad than any other car since till 1984 Chevy Corvette went 1.0 G. 21 years the champ.
Al _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
Posted: Sat Apr 29, 2017 6:43 pm Post subject: Re: Anybody running an aftermarket swaybar? |
I got the front mounted. Addco 723
Super easy install and I am very happy with the product.
I can't believe how much better the bus tracks on the road! We had 30 MPH winds today and i was suprised at how stable it was. Before I would have ended up in a ditch!
I'm going to buy the rear as soon as they are available.
dLk |
SCZ9-1-1 Samba Member
Joined: May 20, 2003 Posts: 716 Location: Santa Cruz, CA
Posted: Fri Jun 09, 2017 8:55 pm Post subject: Re: Anybody running an aftermarket swaybar? |
Anyone know the status on the rear kits from Addco? |
keo808 Samba Member
Posted: Thu Jun 15, 2017 11:48 am Post subject: Re: Anybody running an aftermarket swaybar? |
FWIW...I ordered the Addco 723 (front) and 952 (rear) through Summit Racing today. I purchased through the website which indicated "out of stock", but the parts are a special order item and they will be ordering them from the supplier with an expected delivery date of 9/12/2017 and free shipping. My thought is if anyone wanted to order, now may be a good time, in hopes that it may increase the chances that the order will be filled and delivered in the time expected. As many bus owners before me can relate...order the part and hope for the best. |
