Assistance on installation of engine pulley - found something
IdahoDoug
IdahoDoug is offline
PostPosted: Mon Jun 12, 2017 8:38 am    Post subject: Assistance on installation of engine pulley - found something Reply with quote
So, my original engine had the engine pulley mounted with just a rubber O ring behind it. My spare engine had a thin metal shim-like spacer behind that, which seemed to function as a shield to hold the rubber O ring from hitting the block itsel.
As usual, the Bentley is silent on this feature. Has anyone else found this arrangement behind their pulley? The Bentley even shows no O ring behind the pulley but the rear surface of the pulley seems set up to engage an O ring.
Thanks,
Doug
1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2016 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential. 1988 Mitsubishi Van w/ dual spinny seats, mid engine and solid axle.1990 burgundy parts Vanagon. 1984 Porsche 944, 1992 Lexus LS400, 1988 Toyota Supra 5 speed targa project in pieces, 2002 BMW 325iX
djkeev Premium Member
djkeev is offline
PostPosted: Mon Jun 12, 2017 9:25 am    Post subject: Re: Assistance on installation of engine pulley - found something Reply with quote
The Oring is used with Power Steering or A/C optioned engines.
Dave
Ghia
Vanagon
Beetle
IdahoDoug
PostPosted: Wed Jun 14, 2017 9:32 pm    Post subject: Re: Assistance on installation of engine pulley - found something Reply with quote
So, any input on the metal shim/plate like thing mine also had? And can anyone point to a Bentley page where they mention the O ring for PS/AC cars? Very puzzling.
jberger
jberger is offline
PostPosted: Thu Jun 15, 2017 8:14 am    Post subject: Re: Assistance on installation of engine pulley - found something Reply with quote
Are you referring to the metal "washer" that gets installed on the crank shaft behind the woodruff key? This has been on all the water boxers I have worked on. It functions as a seat for the oring. It is reminiscent of the oil slinger in type 1 engines but does not function as one as far as I know.
IdahoDoug
PostPosted: Thu Jun 15, 2017 5:36 pm    Post subject: Re: Assistance on installation of engine pulley - found something Reply with quote
THANK YOU!!! ding ding ding. OK. All I needed was reassurance that thing is supposed to be there and you described it and let me know you've seen them as well. Nowhere in the bentley. I've got it installed exactly like I found it. The last thing I wanted to do was reinstall some PO's misguided attempt to thwart a leak or something only to find out it sits in there and clicks and rings while the engine is running later. Thank you so much for chiming in. Literally heading out and by the time you read this the pulley will be bolted on.
Doug
