Tcash Samba Member
Posted: Thu Jun 15, 2017 11:00 am Post subject: Re: rear A arm bush replacement |
Sorry the clip is out of the Bentley.
Tcash |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21519 Location: Oklahoma City
Posted: Thu Jun 15, 2017 8:07 pm Post subject: Re: rear A arm bush replacement |
Tcash wrote: |
Tcash |
Thanks......actually just found this morning that that exact clip was used in the Haynes manual as well.
Its odd......that the bushings were made to be under tension when the suspension moves in the bus....and that the steel bushes are supposed to stay stationary......and that knurled ends were NOT used to help the bush to not turn.
As I noted.....so many I have found....ARE turning.....and it does no damage to them.....and in fact would prevent inadvertant "wind up".
That springiness of the bushings does nothing in comparison to the rest of the suspension. A pin prick of spring action at best.
I know why my car does it....and also why some of the other rear trailing bushings on other....mostly water cooled vehicles.....work like this......and its always because an eccentric adjustment is present on the yoke. But its not on the bus...or any that I have worked on.
But.....one could easily be installed....making adjustment of rear toe-in simpler. Perhaps they were looking ahead. I know on other cars this is an adjustment that the dealers could install when needed....and in that case the stationary bushing would be necessary.
Interesting! Ray |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Fri Jun 16, 2017 7:28 am Post subject: Re: rear A arm bush replacement |
Maybe VW did not knurl the ends on the bus because it's not critical if the bushing turns,yes it will wear parts,but would probably last until the end of the warranty,then they sell you a new part and call it normal maintenance.
When the bushing serves as an alignment feature then it must stay in place if it turns it becomes a safety issue.
It may only cost a dime to knurl the ends,but a million dimes soon add up. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy
1974 parts bus
A smart man learns from his mistakes,a very smart man learns from other's mistakes. |
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Fri Jun 16, 2017 7:42 am Post subject: Re: rear A arm bush replacement |
raygreenwood wrote: |
I know why my car does it....and also why some of the other rear trailing bushings on other....mostly water cooled vehicles.....work like this......and its always because an eccentric adjustment is present on the yoke. But its not on the bus...or any that I have worked on |
The water cooled VW's inner sleeve aren't supposed to pivot on the bolt either. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
John Pedersen 1 Samba Member
