What are these three items and their purpose?
dembus
dembus is offline
PostPosted: Wed Jun 14, 2017 3:36 pm    Post subject: What are these three items and their purpose? Reply with quote
I'm starting to clean up the engine compartment and seeing some things that need attention, 71 Deluxe.
Thanks for any help!
1) Hose running into upper intake manifold. Engine #AE838482 50 HP?
2) Wire with inline fuse. What does it connect to? (Runs not connected)
3) Contraption inside near driver's side tail light.
1)
2)
3)
"Want a little peace of mind, grab the lowest branch and start to climb"
JJ Grey
69 Westy (R.I.P.)
68 Kombi
70 Westy
68 Beetle Sedan
69 Beetle Sedan
68 Deluxe
71 Deluxe
71 HT Westy
blue72beetle
blue72beetle is offline
PostPosted: Wed Jun 14, 2017 3:39 pm    Post subject: Re: What are these three items and their purpose? Reply with quote
#3:
https://www.thesamba.com/vw/forum/viewtopic.php?t=641337
-Andy-
-1970 Ghia-
-1971 Bus 1776 Microsquirt EFI-
vwjetboat
vwjetboat is offline
vacuum check valve .. back up or tag light fuse holder.. i ferget.. and vacuum solenoid...
MaddMatt
MaddMatt is offline
PostPosted: Wed Jun 14, 2017 3:40 pm    Post subject: Re: What are these three items and their purpose? Reply with quote
Vacuum line for power brakes
Reverse lights
Old emission control thingy.
It will make it. Trust me.
Owned: 71 Superbeetle, 72 Superbeetle, 63 Baja (on 69 pan) 74 baja, 74 Karmann Ghia
Own: 71 Deluxe Bus
Wasted youth
Wasted youth is offline
PostPosted: Wed Jun 14, 2017 3:42 pm    Post subject: Re: What are these three items and their purpose? Reply with quote
Item 1 is the vacuum line to your brake booster, and that little cap thing is the check valve.
The fused black wire feeds the back up lights.
I think item 3 is the Altitude Compensator, it connects to the carburetor. Search out the Samba and you will find information on that.
aeromech
aeromech is offline
1) Check valve for power brake booster vacuum line. Traps vacuum in the booster when your engine is off.
2) That's the power wire for the reverse lights. Inline fuse holder. The end you're holding should be connected to the + side of the coil. It runs forward to the reverse switch on the transmission and then back to your left reverse light.
3) Altitude corrector. See link above
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Tcash
Tcash is offline
PostPosted: Wed Jun 14, 2017 3:43 pm    Post subject: Re: What are these three items and their purpose? Reply with quote
Brake servo (booster) one way check valve.
Back up light fuse. That wire plugs onto the Positive #15 terminal on the coil.
Altitude adjuster.
https://www.thesamba.com/vw/forum/viewtopic.php?t=141397&highlight=altitude+adjuster
dembus
dembus is offline
PostPosted: Wed Jun 14, 2017 3:45 pm    Post subject: Re: What are these three items and their purpose? Reply with quote
Awesome! I'll do some searching and read up on two of the three.
Thanks for the quick replies!!
JJ Grey
69 Westy (R.I.P.)
68 Kombi
70 Westy
68 Beetle Sedan
69 Beetle Sedan
68 Deluxe
71 Deluxe
71 HT Westy
Wasted youth
PostPosted: Wed Jun 14, 2017 3:46 pm    Post subject: Re: What are these three items and their purpose? Reply with quote
Damn, Lois! You just got some service! Laughing
The Samba just keeps on giving...
dembus
dembus is offline
PostPosted: Thu Jun 15, 2017 6:30 am    Post subject: Re: What are these three items and their purpose? Reply with quote
No clamps on any of my fuel lines and I see my fuel filter right next to the coil. That looks like a ticking time bomb!!
JJ Grey
69 Westy (R.I.P.)
68 Kombi
70 Westy
68 Beetle Sedan
69 Beetle Sedan
68 Deluxe
71 Deluxe
71 HT Westy
Wasted youth
PostPosted: Thu Jun 15, 2017 7:09 am    Post subject: Re: What are these three items and their purpose? Reply with quote
Yes, sounds like eventual bad news. In my opinion, there is no good reason to have that fuel filter in there. Relocate a GOOD quality fuel filter at the outlet of the gas tank, or at least outside of the engine compartment. Trust me, there is room under there.
Originally, the carbureted engines left the factory with unclamped rubber hose with woven fabric shield. Asiab3 (Robbie) had a theory that the woven fabric acted like a Chinese finger puzzle... and kept the hose tight.
Do yourself a favor.... spend some money on Gates Fuel injected hose that is rated for Ethanol and apply fuel injection hose clamps:
From O'Reilly Auto Parts, I use the Barricade™ Fuel Injection Hose:
http://www.gates.com/oreilly/PDFs/Fuel%20Systems.pdf
Make sure the counter help gets you the hose with the green printing on it. They had another fuel injection hose product, but make sure you get the Gates with the green printing.
These are the clamps I use... they don't have the worm drive and so the bands don't cut into the rubber:
https://www.google.com/?gws_rd=ssl#q=fuel+injection+hose+clamps&spf=1497535158929
Idea By removing the fuel filter from the engine compartment, using high quality hose that won't rot away because of Ethanol and using real hose clamps that won't cut into that expensive rubber hose, you will greatly reduce the risk of a tragic gasoline fire.
busdaddy
busdaddy is offline
PostPosted: Thu Jun 15, 2017 7:25 am    Post subject: Re: What are these three items and their purpose? Reply with quote
Oh no they didn't, when they rolled off the boat all the fuel lines had crimped on Ottiker (sp?) single use clamps you had to cut off, it seems many lazy mechanics didn't have replacements in stock so I guess they left them without anything.
Слава Україні!
Wasted youth
PostPosted: Thu Jun 15, 2017 8:01 am    Post subject: Re: What are these three items and their purpose? Reply with quote
What... Exclamation WTF?
Oetiker? https://www.google.com/?gws_rd=ssl#q=oetiker+clamps&spf=1497538827569
MaddMatt
MaddMatt is offline
PostPosted: Thu Jun 15, 2017 9:57 am    Post subject: Re: What are these three items and their purpose? Reply with quote
I apprenticed a guy in a vdub shop that has been doing it for 47 years. He worked for volkswagen for 26 years, running the dealership shop training and later setup the aircooled line at Westmoreland Assembly in 1978.
He always told me that original vw fuel lines never came with clamps. They just pressed on.
That being said, when he left VW and started his own aircooled garage, he ALWAYS installed clamps.
Own: 71 Deluxe Bus
Q-Dog
Q-Dog is offline
PostPosted: Thu Jun 15, 2017 10:14 am    Post subject: Re: What are these three items and their purpose? Reply with quote
The clamps are clearly visible on engine photos in the owner's manual. Wink
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
dembus
dembus is offline
PostPosted: Thu Jun 15, 2017 10:29 am    Post subject: Re: What are these three items and their purpose? Reply with quote
I'll definitely be putting clamps on the fuel lines, the non worm-gear type. I already got some of those. I will look into the Gate green print fuel injection hose if that's recommended now.
Thanks everyone!
JJ Grey
69 Westy (R.I.P.)
68 Kombi
70 Westy
68 Beetle Sedan
69 Beetle Sedan
68 Deluxe
71 Deluxe
71 HT Westy
Wasted youth
PostPosted: Thu Jun 15, 2017 1:41 pm    Post subject: Re: What are these three items and their purpose? Reply with quote
I see them both ways in old manuals... mostly without. Whatever... put 'em on!
Xevin Premium Member
Xevin is offline
PostPosted: Thu Jun 15, 2017 1:51 pm    Post subject: Re: What are these three items and their purpose? Reply with quote
X2 Colin runs without clamps. But he's got proper hoses for that.
Keep on Busin'
67rustavenger wrote:
Clatter wrote:
skills@eurocarsplus wrote:
SGKent wrote:
