CNSRANCH Samba Member
Joined: March 15, 2017 Posts: 126 Location: United States
Posted: Fri Jun 16, 2017 3:02 pm Post subject: How to Properly tighten Front Axle Nuts |
1973, disc brakes, axle nut is the kind that tightens down........
Found that there was a wobble in both front wheels when I got the bug. Snugged the nuts down, and off I went.
100 miles later they were loose again. Nuts didn't move so I'm sure I didn't have everything seated properly, and that's where my slop was coming from.
I'm afraid of crushing the bearings.......I snugged the nuts down tight, and just backed them off a tad. Wheel turns freely.
What's the proper procedure? |
GS guy Samba Member
Joined: December 03, 2007 Posts: 967 Location: Maryland
Posted: Fri Jun 16, 2017 5:44 pm Post subject: Re: How to Properly tighten Front Axle Nuts |
That's how I've always done it - snug it down while turning the wheel until it no longer turns freely (and you can "feel" the tightness in the bearings), then back off - again while turning the wheel until it frees up and turns smoothly without any binding. Snug the locking screw and done. I always make sure the races are fully seated in the hubs when changing the bearings - so no questions about any seating issues.
Jeff _________________ 70's vintage Deserter GS buggy - undergoing transformation to Super GS! |
wythac Samba Member
Posted: Fri Jun 16, 2017 6:03 pm Post subject: Re: How to Properly tighten Front Axle Nuts |
^X2.
Here is some more discussion in the beetle forum. Wealth of info there on issues common to all beetles;
https://www.thesamba.com/vw/forum/viewtopic.php?t=407102&highlight=front+hub+nuts
Also, just making sure you know about tightening the Allen head pinch bolt on the spindle nut once you set the clearance...a simple mistake if you are new to VWs. |
