Whats up with this Petri wheel?
Rasser
Rasser is offline
PostPosted: Tue Jun 06, 2017 2:49 pm    Post subject: Whats up with this Petri wheel? Reply with quote
Hi, I need a little help here guys Smile
This wheel was hooked up so the golden lady push button would activate the high beam lights, and the horn ring activated the horn.
It wasn't working to good, so now I want to make it a bit better.
Does anyone have any idea to what I can use as an insulator between the horn ring and steering wheel. It looks like someone already tried to do something, but it just didnīt work out that well (the rubber "o"-ring).
The red wire (goes to horn button) was connected to the little coil and spring, and runs against a brass plate through a little hole in the steering wheel. Cool setup which I haven't seen before. Was this a normal feature on all Petri accessory steering wheels?
Any tips and help is welcome
Thanks
Rasmus
1957 Ghia - http://www.thesamba.com/vw/forum/viewtopic.php?t=647222
1966 Deluxe bus
[email protected]
ToolBox
ToolBox is offline
PostPosted: Thu Jun 08, 2017 9:16 am    Post subject: Re: Whats up with this Petri wheel? Reply with quote
Try some heat shrink tube or some thin wall nylon tubing.
Rasser
Rasser is offline
PostPosted: Sat Jun 10, 2017 1:28 pm    Post subject: Re: Whats up with this Petri wheel? Reply with quote
Thanks
But my trouble was how to get the "spring effect" from the hornring, without it beeing to hard and not being able to use the push, or being to soft and activating the horn.
I used some soft self adhesive rubber molding, and it worked out great. very positive feel to the horn ring. Also cleaned up the contact surface area, and it works great now.
But I left out the extra spring loaded little coal brush thing that goes through the steering wheel and contacts the brass plate behind it.
I have never seen something like this before on a steering wheel. If anyone has any more info about this (old manuals, commercials or anything - please let me know). Very cool setup by the way!
1966 Deluxe bus
[email protected]
RareAir
RareAir is offline
PostPosted: Fri Jun 16, 2017 7:50 am    Post subject: Re: Whats up with this Petri wheel? Reply with quote
Multi control steering wheels are very cool. Not too many people are even actually aware what the accessory horn ring was used for. When I show them the working example on my cars, the look on their faces is priceless Cool
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
Rasser
Rasser is offline
PostPosted: Sun Jun 18, 2017 2:36 am    Post subject: Re: Whats up with this Petri wheel? Reply with quote
Thanks Rareair!
That picture is great, it shows the parts included. But what is the steel part in the back of the box used for?
I doesn't seem like the part is that common, judging from the replies in this thread Smile. But thanks for your help.
I need to make mine working again, and hook it up to my high beam again Wink
Thanks
Rasmus
1966 Deluxe bus
[email protected]
RareAir
RareAir is offline
PostPosted: Sat Jul 15, 2017 10:16 pm    Post subject: Re: Whats up with this Petri wheel? Reply with quote
That metal piece is just a jig. It's not needed to facilitate the multi control functions. It allows the installer to properly align and drill a hole in the steering wheel hub for the horn/light contact to pass through.
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
empiracer
empiracer is offline
PostPosted: Wed Apr 26, 2023 9:46 am    Post subject: Re: Whats up with this Petri wheel? Reply with quote
Would anyone have any instructions for hooking up the light flashing option for this steering wheel ?
or be able to explain
