krautclassicparts Samba Member
Ghia 1966 Samba Member
Posted: Sun Dec 08, 2013 10:56 pm Post subject: |
R headlights for split the same size and dimensions as the ones used in the 1960s... I know there r different cosmetic and look wise but would they fit without modifications in fenders?! Also r front fenders the same from early 1950s to 1967?! _________________ - Split De luxe 1950
- Oval Ragtop 1956
- Karmann Ghia 1966 Convertible
- Bug 1970 Convertible |
930 Samba Member
Posted: Thu Jun 05, 2014 1:22 am Post subject: |
I am a bit lost with the headlight identification so hence I am resurrecting this quite an old thread which I found using search...and apologies in advance if these lights appear to be 13 in a dozen 60's lights I don't know so hence I am asking...
Can anyone help me identifying these headlights? Both chrome rings have a 17mm long "Bosch" text written in 12 o'clock position. Adjusters in both rings are on 9 and 12 o'clock position.
Both lenses have a VW logo in 12 o'clock position and "Hella" on the bottom. The other lens has a large A and NL written on the bottom and number 44-10804. The other has a small A and NL on the left side of the lens and a number 41-10804 on the bottom.
Both reflectors have a text LE/YE 180x2A (1/5) and LE1801 A-K 1049.
janerick3 Samba Member
Posted: Thu Jun 05, 2014 7:50 pm Post subject: |
930 wrote: |
The Hella symmetric lenses are no older than 1958. The date codes on the Bosch assemblies are stamped on the back of the reflectors (not the buckets) and consist of 1 or 2 numbers, followed by a letter. _________________ Thanks,
Jan K. |
930 Samba Member
Posted: Thu Jun 05, 2014 10:14 pm Post subject: |
janerick3 wrote: |
930 wrote: |
The Hella symmetric lenses are no older than 1958. The date codes on the Bosch assemblies are stamped on the back of the reflectors (not the buckets) and consist of 1 or 2 numbers, followed by a letter. |
Hi Jan,
thanks for a prompt reply, appreciate it.
I will check the date codes and will post them here accordingly. |
930 Samba Member
Posted: Thu Jun 12, 2014 8:30 am Post subject: |
Found out that these are manufactured in 1958 as per the date codes. (found a link elsewhere on thesamba where the date codes were...)
This sounds right as the Bosch in the rings is smaller and the lenses are symmetrical. |
Posted: Thu Jun 12, 2014 9:48 pm Post subject: |
The lenses have been replaced at some point in the car's lifetime. The original lenses would have been Bosch symmetrics with the "script" Bosch name at the bottom. _________________ Thanks,
Jan K. |
AlanInMass54 Samba Member
Joined: August 29, 2003 Posts: 1070 Location: Massachusetts
Posted: Tue Mar 17, 2015 9:21 am Post subject: |
Sorry to dredge this back up. My car is a (mostly) December 52. I found these old Bosch headlights long ago. They're beat and missing parts. First are springs, screws, etc still available (wolfsburg west only shows parts for later assemblies), and second are they what should be in there?
I can always look for others but I had these and would be happy if I could make use of them. |
Hustlers67 Samba Member
Joined: September 21, 2011 Posts: 263 Location: Sydney, Australia
Posted: Wed Mar 18, 2015 1:28 pm Post subject: |
Are the sizes of the headlights different from the 50s to 60s? Can I fit the Porsche style light grilles on early 60s (sloping) headlights? |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Wed Mar 18, 2015 2:32 pm Post subject: |
Hustlers67 wrote: |
All the same size. Yes, they'll fit _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
TheFop Samba Member
Joined: February 03, 2014 Posts: 302 Location: Auckland - New Zealand
Posted: Mon Jun 12, 2017 12:55 am Post subject: Re: Bosch headlight info |
Hi Folks, Sorry for dragging up an old post but I just found these headlights in my stash of bits that came with a Beetle I bought a while ago, these have been in storage in a box for at least 15 years and likely longer.
The codes on the glass are 1305614001 and 1208 and they are symmetrical with a stylised Bosch script so from what I'm able to ascertain are likely early 50's Beetle or Pre A 356.
The reflectors don't have any writing on the back and are in really nice condition with just a bit of spidering under the finish but are very servicable.
There are two slightly different buckets, one is black/grey with the original codes including a VW sign and the other is just grey with no writing, both have 3 drain holes and are in pretty decent condition.
The chrome rings are very nice with a couple of tiny dents likely from a piece of gravel being flipped up and the screw tabs have very slight surface corrosion, however no Bosch markings.
The bulb holders/terminal connectors are Bosch based on the small Bosch logo and again nice condition bar a bit of dusty grime which appears to wipe off with little effort.
They came to me in pieces but I believe I have all the bits to put them back together.
So a couple of questions, are these likely to be early 50's or as the Bosch markings aren't on the rings, or reflectors are they likely to be parts from various periods to make a good set.
2nd question is what is a fair price for them if anyone was looking for a set? My Beetle is a New Zealand 67 so although these would be very cool they aren't the right lights for it and these may be able to help fund some of the cost for the paint on my 67. _________________ Rusty 61 RHD Karmann Ghia Coupe - Resto in progress....slowly
Stock 69 LHD Karmann Ghia Coupe - Driver
67 New Zealand Spec Beetle - Being rebuilt
63 New Zealand Spec Beetle - Going Baja!
86 T25 Westfalia - Family Fun car |
Porsche904 Samba Member
Posted: Mon Jun 12, 2017 1:34 am Post subject: Re: Bosch headlight info |
Bosch old script logo lenses marked NL A indicates 55-59 lenses, 3 hole buckets came after 53 |
Posted: Mon Jun 12, 2017 6:53 am Post subject: Re: Bosch headlight info |
The reflectors appear to have been re-silvered at some point, so the date codes are lost.
However, Bosch lenses often, but not always, have a date code cast into the lip, at the 12 o'clock position. This code contains a Roman numeral (I-IV) for the quarter, followed by a letter for the year. _________________ Thanks,
Jan K. |
TheFop Samba Member
Posted: Tue Jun 20, 2017 10:31 pm Post subject: Re: Bosch headlight info |
Thanks for the responses, I thought the old stylized Bosch script was until 57?
I've looked for the number and roman numeral at 12 o'clock on the lens but all I can see is something like 335, 538 or 535 but its hard to tell. based on the script and the roman numeral this doesn't make sense as they would be something like 1973 75 or 78 which they cant be because of the script. _________________ Rusty 61 RHD Karmann Ghia Coupe - Resto in progress....slowly
