Littleeagle28 Samba Member
Joined: April 13, 2017 Posts: 171 Location: U.K. lincs
Posted: Tue Jun 20, 2017 2:04 pm Post subject: Vacuum pipe 1974 SB |
Whilst installing my engine, the vacuum pipe on the vacuum canister on the distributer broke off again.
What's the best method of fixing it?
Many thanks. |
Old n' slow Samba Member
Joined: October 29, 2012 Posts: 619 Location: Western Maryland
Posted: Tue Jun 20, 2017 2:30 pm Post subject: Re: Vacuum pipe 1974 SB |
Buy a new or used vacuum canister....
if that's not possible I imagine you can't braze weld or silver solder it since it has a rubber/fabric diaphragm inside, unless you take it apart first......you might try cleaning it thoroughly and using JB weld or the equivalent. _________________ Currently own : 1969 Beetle w/ 1600cc, Single Port, Solex 30 PICT 2, Dist. 113 905 205 T, stock exhaust.
All my daily drivers gone but not forgotten;
1964(sunroof)1967 & (2)1968 Beetles , 1968 Squareback , 1963 (23 window )Deluxe Sunroof Bus , 1969 Westphalia camper, 1974 Dasher , 1985 Vanagon , (2) 1981 Rabbit Diesels & a 1991 Jetta Diesel . |
Posted: Wed Jun 21, 2017 11:20 am Post subject: Re: Vacuum pipe 1974 SB |
Old n' slow wrote: |
if that's not possible I imagine you can't braze weld or silver solder it since it has a rubber/fabric diaphragm inside, unless you take it apart first......you might try cleaning it thoroughly and using JB weld or the equivalent. |
Many thanks for your suggestion.
I did epoxy it last time and it held ok, until I Manhandled the engine back in, and it broke off again.
Cheers. |
Luft kühl Samba Member
Joined: January 21, 2009 Posts: 1178 Location: Allentown, PA
Posted: Wed Jun 28, 2017 7:03 am Post subject: Re: Vacuum pipe 1974 SB |
Good tip air cool, may give this a shot. |
