Shinnlinger Samba Member
Joined: May 25, 2017 Posts: 122 Location: New Hampshire
Posted: Tue Jun 20, 2017 8:38 pm Post subject: FI vs duals. New vs rebuilt |
So a local VW guy says the dual solex setup from cb performance is pretty good and less than $400. This seems like an ideal way to replace my progressive setup in my 74 but everyone here seems to lean toward FI.
As it so happens, i have a 77 which I may need to turn into a parts bus for political reasons. It's a long story but potentially i have a used FI system complete with fuel tank but some questionable history available. Worth the hassle of swapping to a non FI '74 and troubleshooting?
I'm also on the verge of acquiring a derelict 73 with a stock dual setup that has been sitting for many years. They will most likely need a complete rebuild/re bush but perhaps an option? Better than new solexes?
Open to advice.
Thanks.
Dave |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51125 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Jun 20, 2017 10:43 pm Post subject: Re: FI vs duals. New vs rebuilt |
I like both stock carbs and FI, but the FI wins if I had to choose just one. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Jun 21, 2017 3:20 am Post subject: Re: FI vs duals. New vs rebuilt |
That is helpful to know FI works noticeably better than carbs. My question is more along the lines of what's the best option for my progressive carbed '74 weighing cost and convenience.
1) Convert it to a used FI that is not know to be 100%?
2) Rebuild or most likely have rebuilt/rebushed a stock '73 dual set up?
3) Buy a brand new Solex dual arrangement from CB performance for $400? |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Wed Jun 21, 2017 12:11 pm Post subject: Re: FI vs duals. New vs rebuilt |
My preferences would be in that order: 1) 2) 3) _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Wed Jun 21, 2017 12:24 pm Post subject: Re: FI vs duals. New vs rebuilt |
Shinnlinger wrote: |
1. Convert to a not known )condition wise) used FI system? Good luck.
2. Dual Webers dialed in with LM-2 _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
