Geothing Samba Member
Posted: Tue Jun 20, 2017 9:56 am Post subject: Newbie checking in with first questioni |
Hi all, just picked up a '74 Thing in pretty good shape, excited to clean her up and get her out exploring on the logging roads here in Oregon! I'm replacing the tired torsion bars and inner and outer bushings: do I need to take off the rear fenders to get the bars out??
TIA
Geothing |
Cal Dez Rat Samba Member
Joined: May 17, 2004 Posts: 36 Location: Extreme So. Cal. Desert
Posted: Tue Jun 20, 2017 10:19 am Post subject: Re: Newbie checking in with first questioni |
I was able to reclock my torsions to lift my Thing up in the rear without removing the fenders. It might be tight, but it can be done. |
iltis74 Samba Member
Joined: November 20, 2003 Posts: 826 Location: Anchorage, AK
Posted: Tue Jun 20, 2017 11:31 am Post subject: Re: Newbie checking in with first questioni |
Do the torsion bars ever get tired? I've only been aware of swapping in stronger ones for drag race launches and such.
There are different amounts of splines on the inner and outer ends of the bars, I believe the numbers are 40/44. This allows you to, say, drop one inner spline, come up one outer spline, and have a net ride height change of about 1/4". That's how you set your rear ride height. Stiffer torsions are still going to have to be clocked and adjusted for ride height, and probably toss the end around more on rough roads.
If you're unaware of this and just yard the things out and new ones in, the odds of the rear end sitting level off the bat are slim at best. You need the car level, and you need an inclinometer.
This could be old news. With only one post, it's difficult to judge your knowledge base. _________________ 65 Beetle
74 Thing
87 Syncro |
Posted: Wed Jun 21, 2017 12:49 am Post subject: Re: Newbie checking in with first questioni |
You likely need new torsion bar bushings which should bring the height back close to stock, index the existing bars from there to get the height you want. |
YDBD Samba Member
Joined: February 25, 2017 Posts: 891 Location: Bavaria, Germany
Posted: Wed Jun 21, 2017 5:02 am Post subject: Re: Newbie checking in with first questioni |
Probably easier with the fenders off. And even easier is air shocks. _________________ '56 pan Dune Buggy since '69
don't live in the past...but when I did:
'67 bug
'64 baja
'60 dune buggy
'73 Personenkraftwagen Type 182 "Thing" |
Madkel Samba Member
Joined: May 02, 2008 Posts: 106 Location: North San Diego County
Posted: Wed Jun 21, 2017 8:28 am Post subject: Re: Newbie checking in with first questioni |
Yes, torsion bars get tired. Yes, you can re-adjust to raise and lower, but older tired bars may not hold the new set.
No need to remove rear fenders. I was able to upgrade my bars from the stock 24mm to sway a way 25mm with no issues and no problems with fender interference. Just make sure the bars are stock length as there are 3 choices for the length of torsion bars and torsion end caps.
Just need to follow the directions and be very safety minded as there is a lot of tension.
Evan after placing new bars they will sag a bit as they settle and may need to be re-adjusted to level or get the ride height you are looking for.
All part of the fun of owning a ACVW.
Enjoy and use the forums. Lots of great info and good people here. _________________ 1973 Type 181 - 2016cc - 091 trans
ITS A FUN RIDE! |
Posted: Wed Jun 21, 2017 1:58 pm Post subject: Re: Newbie checking in with first questioni |
Hi guys -
Thanks for all the input! Yes, in my experience torsion bars will "relax" over time, and resetting them won't restore the same spring rate, as Madkel suggests. I've worked on many earlier swing axle VWs, so I'm familiar with the spline/preload setup procedures - it's always a hassle! Minimally I'm putting in new bushings, as the old ones are shot!
Did I see on this forum of a guy who makes spring plates to move the rear wheel back and down just a little bit (1" or so) that doesn't require changing anything else? Maybe an upgrade for later!
Thanks again everybody!
Geothing |
