stevo96 Samba Member
Posted: Sun Jun 18, 2017 11:41 pm Post subject: Bumper doesn't fit? |
Hi
Purchased this bus a while back and the bumper wasn't fitted. The engine is out of a beetle so I'm having trouble fitting the bumper. Rather than buy a new exhaust is there a way of modifying the exhaust or bumper for it to fit?
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Mon Jun 19, 2017 1:08 am Post subject: Re: Bumper doesn't fit? |
There are two ways to do it. One is the right way. That would be to either buy the correct muffler and tail pipe or, less desirable, modifying the Bug muffler.
The other way is the typical "hippie hack" which involves clearancing your apron for the PS pea shooter and then torching some holes in the bumper for the two tail pipes. I think you know the preferred method. If you end up doing it the other way I would suggest you keep it a deep, dark secret or you will labeled a heretic and a butcher. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
Abscate Samba Member
Joined: October 05, 2014 Posts: 22671 Location: NYC/Upstate/ROW
Posted: Mon Jun 19, 2017 4:17 am Post subject: Re: Bumper doesn't fit? |
Technically, it's a heretic butcher but that might just be splitting hares.
Mmmmm, hares....dinner... _________________ .ssS! |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4574 Location: St Charles, MO
Posted: Mon Jun 19, 2017 6:45 am Post subject: Re: Bumper doesn't fit? |
Do it right and get the correct Bus muffler with damper and correct "?" shaped tailpipe! Don't wreck a nice bumper with a torch. Hey, that left side bumper mounting bracket is 1959 thru about 1961 with that factory-added bracket for the early 40 hp tailpipe support bracket. Cool!
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
EverettB Administrator
Joined: April 11, 2000 Posts: 69830 Location: Phoenix Metro
Posted: Mon Jun 19, 2017 8:16 am Post subject: Re: Bumper doesn't fit? |
BulliBill wrote: |
Do it right and get the correct Bus muffler with damper and correct "?" shaped tailpipe! Don't wreck a nice bumper with a torch. Hey, that left side bumper mounting bracket is 1959 thru about 1961 with that factory-added bracket for the early 40 hp tailpipe support bracket. Cool! |
They used them later too - my original '63 has it even though it's a 1500cc Bus.
I think they used it while the 40hp was still available. _________________ How to Post Photos
62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1276 Location: Surprise, AZ
Posted: Mon Jun 19, 2017 9:23 am Post subject: Re: Bumper doesn't fit? |
EverettB wrote: |
BulliBill wrote: |
I think they used it while the 40hp was still available. |
And the Parts Catalog calls out up to Chassis # 1 167 862 on the mount bracket, so yea into '63. Also, ditto on not accommodating the exhaust by destroying the bumper...change the exhaust setup instead. _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold) |
Posted: Mon Jun 19, 2017 2:49 pm Post subject: Re: Bumper doesn't fit? |
Someone mentioned if a zoom box will fit? |
ronjonlasvegas Samba Member
Joined: October 08, 2004 Posts: 902 Location: Las Vegas, NV
Posted: Mon Jun 19, 2017 3:07 pm Post subject: Re: Bumper doesn't fit? |
I am not sure if a zoomie exhaust will fit. Here is an option for a brand new correct exhaust.
https://www.thesamba.com/vw/classifieds/detail.php?id=1952965 _________________ September 1964 Standard Sunroof walk through SWR/BG original paint. |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Mon Jun 19, 2017 3:51 pm Post subject: Re: Bumper doesn't fit? |
Buy a $140 muffler or destroy a $250 bumper? Why is there even a discussion? _________________
EverettB wrote: |
FU#5 |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Mon Jun 19, 2017 6:36 pm Post subject: Re: Bumper doesn't fit? |
or if the money is not there, just leave the bumper off until the funds for the correct exhaust are there, or for a fancy exhaust if that is what strikes your fancy _________________ regards
Uli
Posted: Mon Jun 19, 2017 9:32 pm Post subject: Re: Bumper doesn't fit? |
It's $300 for an exhaust over here hence why I'm looking for a cheaper option. I've now removed the peashooters, tried to bend them, it ain't happenin! |
Pinetops Samba Member
Posted: Mon Jun 19, 2017 10:02 pm Post subject: Re: Bumper doesn't fit? |
You could weld up the right hole in the muffler and make a bus shaped pipe for the left side. I haven't tried it but I have a bus exhaust I've never used that looks like someone "converted" this way.
Either that or weld up some pea shooters with elbows in them, I've seen that done before. _________________ "A rolling bus gathers no rust." |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2541 Location: Ocean Beach in Beautiful BLUE California
rodgersbadassbus64 Samba Member
Joined: January 24, 2009 Posts: 418 Location: Ortonville, Minnesota
Posted: Tue Jun 20, 2017 8:59 am Post subject: Re: Bumper doesn't fit? |
I always cut the lower part of the lower pan off with a skinny wheel. That way it doesn't look stupid. And a bug muffler doesn't need new holes. You can also mount the bumper brackets first and then put the bumper on to it to see if you need to space the brackets a little to make things fit....
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Tue Jun 20, 2017 9:27 am Post subject: Re: Bumper doesn't fit? |
stevo96 wrote: |
Take one to a muffler shop and have them make you two short bends that will shoot down and miss your apron. It will be louder without the stingers but will still be muffled. |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13282 Location: Tejas!
hitest Samba Member
Posted: Thu Jun 22, 2017 6:15 pm Post subject: Re: Bumper doesn't fit? |
Hmm, specialty tips to allow the installation of the wrong muffler? Me thinks those were to make a bug look kewl like all the Detroit bargain barges of the day.
Now then, if a cat daddio were to make an "s" bend in tips I'd see the bus crowd on its feet. _________________
EverettB wrote: |
FU#5 |
cru62 Samba Member
Posted: Fri Jun 23, 2017 5:59 am Post subject: Re: Bumper doesn't fit? |
It's kind of hard to see but on my DC I used a pair of early bus exhaust tips. I had them on the bus with a stock bumper before I installed the Bice rear bumper. The turn down was perfect for both applications. They don't have baffles and sound pretty sporty. I eventually modified some bug tip interior baffles to work using some stainless steel wool which quieted down the exhaust tone just enough.
https://www.thesamba.com/vw/gallery/pix/575564.jpg _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
