gravygrabber Samba Member
Posted: Tue Jun 20, 2017 6:24 pm Post subject: Need a little help with a 83 vanagon engine replacement |
Own a small import shop and work on a lot of newer VW's and I had a 59 Bug back in the late 90's. Anyway I have a customer that has an 83 Vanagon and he wants to fix it for his kid so he can take it out of state for college. The van runs but has a lack of power and fouls a plug on one of the cylinders plus it's been sitting a bit. He did jump it and ran it up/down the block pretty recent so it's probably going to need work but it's not a complete resurrection.
He's pretty convinced he wants a new engine installed. Reman. engine whatever. I've never worked on this model so I'm not sure where to even go. Saw several online but not sure what companies are good or not. He also would like it to go a little bit faster. He was talking about a fuel injection back to carb swap. I'd rather just swap a reman engine in and address any other needs at the same time and keep the fuel injection. Where the kid is taking it it's almost sea level and we at at 3800-3900 ft. Doesn't make sense to me to change to carb.
I'm also going to have to check over the rest of the van and address the brakes, etc.. Basically make the van road worthy. He also mentioned trying to get the camping stuff going like the fridge, battery for the accessories.
From my limited research it looks like you can swap in a bigger engine like a 2.1L?
Any ideas before I start this adventure? |
Zeitgeist 13 Samba Member
Posted: Tue Jun 20, 2017 6:53 pm Post subject: Re: Need a little help with a 83 vanagon engine replacement |
A 2.1 WBX would be a nice bump up in power. Since you've worked on newer VWs, then perhaps an upgrade to an ABA inline engine from a Mk3 Golf/Jetta would also fit the bill. Both of those are probably the value leaders for engine upgrades, and given that the rest of the van will need attention, they make a lot of sense from a budget perspective. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Tue Jun 20, 2017 11:16 pm Post subject: Re: Need a little help with a 83 vanagon engine replacement |
An 83 model is a different animal from an 83 1/2 model. The first is aircooled and the second is water cooled. Which one do you have? |
danfromsyr Samba Member
Posted: Wed Jun 21, 2017 5:37 am Post subject: Re: Need a little help with a 83 vanagon engine replacement |
for shops I'll toss out HEadflow masters as a top tier shop.
http://www.headflowmasters.com/vw-longblocks.html
stay away from GEX _________________
Abscate wrote: |
metropoj Samba Member
Posted: Wed Jun 21, 2017 7:49 am Post subject: Re: Need a little help with a 83 vanagon engine replacement |
If it is an air cooled and owner wants to go to a single weber progressive carb, I don't suggest it.
Based on many years of Type II with Type IV boxer motors (EFI and carbed), the carb intake runners are too far away from the heads and cause all kinds of issues with poor throttle response. They drive horribly, ice up very easily in cold weather.
Easier than fuel injection, well, maybe. But, it will never run right. _________________ John.
86 TiiCo powered Westy. |
the joker Samba Member
Posted: Wed Jun 21, 2017 2:51 pm Post subject: Re: Need a little help with a 83 vanagon engine replacement |
there are heated manifolds and factory single carbs
Factory installed , find one
my 84 has a factory carb set up on run it on a 2.1 l wasser,
how do you know the eng shot. low compression , low oil pressure ? |
Posted: Thu Jun 22, 2017 10:14 am Post subject: Re: Need a little help with a 83 vanagon engine replacement |
It's definitely injected with some early Bosch setup. I assumed it was watercooled. Did they come injected with air cooled engines?
What's wrong with GEX btw? Seems like good prices. I don't know if this customer will pony up 4K with a reman on this one but the GEX price seems reasonable. |
Posted: Thu Jun 22, 2017 10:43 am Post subject: Re: Need a little help with a 83 vanagon engine replacement |
gravygrabber wrote: |
The 80-83 Vanagons had a 2.0L Type 4 aircooled engine, but in the middle of the 83 model year VW moved over to a 1.9L watercooled boxer engine. Then in '86 they went to a 2.1L watercooled boxer engine.
If this is not a US spec model there would have been other engines available as well.
GEX will reuse any and all parts they can, whether they match or not or if they are at the wear limit. Their headwork is dismal and is often little more than a media blasting. |
chrissev2 Samba Member
Posted: Thu Jun 22, 2017 11:02 am Post subject: Re: Need a little help with a 83 vanagon engine replacement |
"I assumed it was watercooled. Did they come injected with air cooled engines?"
It's a VW. Never assume anything. Yes they came air cooled. You can tell the difference easily by looking at the front. Air cooled has no lower front grille. Water cooled does.
Here's some pics of a 1981 air cooled: http://momentcar.com/volkswagen/1981/volkswagen-vanagon/
There is little point in trying to convert an air cooled Vanagon to water.
Also if it is an 83 and it is water cooled likely the cooling pipes will be leaking unless they have been replaced as the 83s used the metal pipes and they will be 34 years old. _________________ 1986 westfalia auto 1.9TD
2023 VW Atlas 3.6 VR6 Highline
2019 Golf Wagon 4 motion
1978 Volkswagen super beetle convertible
1992 Eurovan 2.5 5spd westfalia |
Posted: Thu Jun 22, 2017 1:04 pm Post subject: Re: Need a little help with a 83 vanagon engine replacement |
stay clear of waterboxer inc they are scumbags |
david2676 Samba Member
Joined: September 06, 2008 Posts: 452 Location: san jose, ca
Posted: Thu Jun 22, 2017 1:32 pm Post subject: Re: Need a little help with a 83 vanagon engine replacement |
call Adrian at head flow masters ... I am sure he will build you a motor that is enough... _________________ 64 bug
91 Vanagon/ Subaru swap Westfalia |
Posted: Thu Jun 22, 2017 1:33 pm Post subject: Re: Need a little help with a 83 vanagon engine replacement |
Make sure the rods are hand-planked. Attention to detail counts. _________________ Casey--
y u rune klassik? |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
Posted: Thu Jun 22, 2017 3:31 pm Post subject: Re: Need a little help with a 83 vanagon engine replacement |
Appreciate the replies. Need something already built and ready to throw in I'm afraid. Need to get it done before end of July. Hoping there is company that has a reman. ready to ship and it will be as painless as possible. I already have a Porsche 911 I have to do soon and I only have one lift. |
Posted: Thu Jun 22, 2017 4:02 pm Post subject: Re: Need a little help with a 83 vanagon engine replacement |
Also just confirmed with pics from the owner it's definitely air cooled and fuel injected so that's probably a plus for me. Should be easier to get done less to worry about. Need a good engine supply company at this point to get one coming so I can start on it. |
Vanagon Nut Samba Member
Posted: Thu Jun 22, 2017 4:50 pm Post subject: Re: Need a little help with a 83 vanagon engine replacement |
what about an AVP ?
http://www.avp-worldwide.com/engines.htm
Looks like Busdepot.com (one of our excellent vendors) may also sell an AVP air cooled rebuilt:
http://www.busdepot.com/071100627 _________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
Posted: Thu Jun 22, 2017 6:53 pm Post subject: Re: Need a little help with a 83 vanagon engine replacement |
You want good quality head work, headwork will make or break these engines. Good headwork and a mild cam upgrade and you should have an engine that will run well for many thousands of miles. |
Posted: Wed Jul 12, 2017 3:10 pm Post subject: Re: Need a little help with a 83 vanagon engine replacement |
Still looking |
Jeffrey Lee Samba Member
Joined: February 04, 2014 Posts: 1488 Location: Wisconsin
Posted: Wed Jul 12, 2017 3:50 pm Post subject: Re: Need a little help with a 83 vanagon engine replacement |
As Vanagon Nut mentioned, a good affordable option would be an AVP rebuilt. They’re a reputable rebuilder, and being in CA, can probably ship to you in Montana relatively quickly.
“All heads get new seats, guides, and new exhaust valves, reground on the intake valves. Then all heads are step cut to take the unleaded, lower quality fuel of today.”
You’d no doubt want to talk with them, but it looks like #630 is the engine you’d want.
Good luck! _________________ Camp Westfalia
Camping Tips • Newsletter • Cool Campervan Apparel
www.CampWestfalia.com |
