Rocker replacement
90runner
90runner is offline
PostPosted: Wed Jun 21, 2017 12:06 pm    Post subject: Rocker replacement Reply with quote
Finally have a little money to start fixing my Thing and I am wondering what would be a reasonable price to have my rockers replaced. I have the parts ready to go but this job is outside my skill set.
74 Thing stock lots of rust figured someone needed to save it.
KAmes
KAmes is offline
PostPosted: Mon Jun 26, 2017 6:41 pm    Post subject: Re: Rocker replacement Reply with quote
I don't really know what body shops would charge for that but as a novice that's done it I didn't find it overly difficult. Body work can be expensive but I would think it to be as reasonable as any car. Just ask at your local shops, even if expensive you'll be glad you did it.
911pickup
911pickup is offline
PostPosted: Wed Jun 28, 2017 12:43 pm    Post subject: Re: Rocker replacement Reply with quote
Mine need replacing too. Crying or Very sad
911pickup
PostPosted: Thu Jun 29, 2017 7:24 am    Post subject: Re: Rocker replacement Reply with quote
I noticed replacement inner rocker panels are available. Can these be installed with the body on the pan?
KAmes
KAmes is offline
PostPosted: Thu Jun 29, 2017 8:39 am    Post subject: Re: Rocker replacement Reply with quote
Yes, that's what I did. Well, in my case I used the lower half, that's all I needed, and left the upper half intact so as to not disturb the door post structure. I cut out the lower inner rocker from about halfway down, unbolted it from the pan (broke most of the bolts) welded in the new section and then did the outer rocker the same way. Worked out pretty good and I didn't have to disturb parts of it that didn't need fixing.
