Brunocerous Samba Member
Posted: Wed Jun 21, 2017 3:50 pm Post subject: EV VR6 engine photo? |
Does anyone happen to have a photo of their VR6 engine (AES or otherwise) they might be willing to share?
I'm trying to figure out where the other end of this coolant hose goes (following a spark plug replacement).
Any guidance would be greatly appreciated!
Cheers,
Bruno
JMB3 Samba Member
Posted: Fri Jun 23, 2017 5:36 am Post subject: Re: EV VR6 engine photo? |
That is fantastic. Thank you for the photo!
I'd been looking at coolant line diagrams but wasn't too clear on that particular tee connection. |
Posted: Fri Jun 23, 2017 5:38 am Post subject: Re: EV VR6 engine photo? |
Oh, and kudos on the clean engine! Mine looks like it sat on the set of "The Mummy." |
Posted: Sat Jun 24, 2017 10:38 am Post subject: Re: EV VR6 engine photo? |
Thanks again. I found the culprit.
It might have been a blessing in disguise, as the busted hose insert coming off the tee looks corroded.
So far, I don't see whether the tee includes the insert that fits into the coolant line can be replaced or whether I need a new tee.
JMB3 Samba Member
Posted: Sat Jun 24, 2017 11:01 am Post subject: Re: EV VR6 engine photo? |
Have you visited the wiki article I referred you to yet? There is no separate insert. You have a busted Tee, as many of us have previously experienced. The article provides many options for replacement, from super expensive to fairly reasonable. I wouldn't use the Dorman part for more than a temporary fix. Please contribute to the article if you find any other solutions. |
gakali Samba Member
Joined: August 19, 2007 Posts: 448 Location: Cambridge, Ontario, Canada
Posted: Sat Jun 24, 2017 12:07 pm Post subject: Re: EV VR6 engine photo? |
The previous owner of my van made up a new one by soldering together the appropriate copper plumbing bits. Seems to have worked ok so far. _________________ Why do it? Because you can.
1999 Eurovan
2003 A4 Avant 1.8T Quattro
1992 W201 190e 2.3 Mercedes
2006 W220 S600 V12 Twin Turbo 5.5 Mercedes |
Posted: Mon Jun 26, 2017 7:44 pm Post subject: Re: EV VR6 engine photo? |
JMB3 wrote: |
Thanks again for the Dorman warning. I ended up opting for the MINI Cooper genuine part. Fingers crossed. |
Posted: Mon Jun 26, 2017 7:47 pm Post subject: Re: EV VR6 engine photo? |
gakali wrote: |
The previous owner of my van made up a new one by soldering together the appropriate copper plumbing bits. Seems to have worked ok so far. |
That's neat! I'd love to see what that looks like, if you have a photo of it.
A previous owner of mine bypassed the heater core with cast-iron plumbing elbows. I had considered something similar but opted for the MINI Cooper version.
Turk.380 Samba Member
Posted: Tue Jun 27, 2017 6:49 am Post subject: Re: EV VR6 engine photo? |
oh man.. this is the same thing that busted years ago in my '99 MV with the Climatronic system.
whatever version was in my van.. simply DID NOT EXIST in the Etka parts system. He even looked up Canadian and Euro versions.. nothing was exactly like mine.
After ordering 3 different assemblies and none of them being correct, the parts counter guy just dis-assembled all 3 they got in and used the various components to make up an assembly that matched mine, and GAVE IT TO ME while muttering some colorful metaphors about VW and the whole EuroVan line..
I think it was around '06 or '07 and they were still available form the dealer _________________ Brian W
St. Louis, MO
'64 SO-33 Hatch Top Westy | '87 Syncro Westy: Subaru EZ30D powered | 2002 VW Winnebago Vista |
Posted: Fri Jun 30, 2017 8:13 pm Post subject: Re: EV VR6 engine photo? |
stl_stadtroller wrote: |
I think it was around '06 or '07 and they were still available form the dealer |
That's what I was afraid of! That I'd need a time machine to get the OEM part |
Posted: Fri Jun 30, 2017 8:14 pm Post subject: Re: EV VR6 engine photo? |
On a lark, I stopped at my local independent auto parts store and I found a Napa heater hose tee (part no. 660-1593) to replace the busted 3/4 x 3/4 x 3/8 connector on my 1999 EuroVan MV.
Is it of decent enough quality to use? Or is the comparable MINI version preferable?
