54bug Samba Member
Joined: January 16, 2011 Posts: 142 Location: WashingtonDC
Posted: Tue Jun 27, 2017 6:02 am Post subject: Updated Engine, Exhaust much louder... Opinions |
Hi All
Just completed a top end rebuild on my Bus! 1776 now has new Pistons/Cyls, CB Panchito 044 heads, & matched Kadrons. I'm still running heater boxes and an EMPI Stainless header, and matching stainless Phatboy exhaust.(Still need heat) The Kadrons replaced a set of Weber 34 ICT's.
The changes are profound, the bus is now fast and very loud. It runs great but the noise, while marginally OK at slow speeds, makes my ears ring after highway driving. I didn't expect the change in exhaust volume. I never liked the EMPI muffler's output pipe, as it is 6" short of clearing the bumper.
Looking for suggestions on a "quieter" muffler that will fit on the bus, and have a tip that extends out near the bumper. I' leaning toward the A-1 muffler sold by Aircooled.net: the site asks for vehicle type when ordering. I'm hoping that changes the setup. I have an A-1 on my beetle with a similar, but stock valve head, motor. It's fairly loud but not painful.
Looking for suggestions to:
1- Minimize the noise, and avoid tickets.
2- Fit in the body of my Double cab.
3- Minimally Dampen performance
Thanks in Advance, Scott[/list][/list] |
theDrew Samba Member
Posted: Tue Jun 27, 2017 9:16 am Post subject: Re: Updated Engine, Exhaust much louder... Opinions |
in experience..the A-1 is quiet loud. Fun for a bit, but after a few minutes on the freeway the drone rattles the teeth _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
1985 Vanagon Campmobile w/ 2005 EJ25 |
sactojesse Samba Member
Joined: November 21, 2006 Posts: 2655 Location: Sacramento, California, USA
Posted: Tue Jun 27, 2017 9:30 am Post subject: Re: Updated Engine, Exhaust much louder... Opinions |
IME, the Phatboy/Mondo mufflers are loud. Try switching to dual quiet packs with the same exhaust. Or, since you are running 044 Panchitos, upgrade to 1 1/2" flanged heater boxes and the Bugpack system that is designed to bolt up to those. _________________ 1966 Karmann-Ghia convertible |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
dgsaz Samba Member
Joined: November 04, 2008 Posts: 579 Location: Phoenix / San Diego
Posted: Wed Jun 28, 2017 3:42 pm Post subject: Re: Updated Engine, Exhaust much louder... Opinions |
54bug wrote: |
Hi All
I'm running almost the same set up. Last month I was looking at how old and rusty my 20 year old header was and I took it off to have a better look. Ugg!
In addition to being almost rusted through is some places the inside were starting to rot. If you shake the muffler, it sounded like a beer can with gravel inside.
So, I bought an new header and muffler. Empi, ceramic coated. The new header fit so poorly that I sent it back, but kept the muffler. Took the old header out and had it sand
blasted inside and out, then ceramic coated. Bolted the combo up. New gaskets always help.
But what impressed me was the sound of the muffler. Nice and quiet (not stock), good at RPM, with a nice little rumble at idle. The fit looks good although I have not yet hung the back bumper yet. Here what I used;
http://www.jbugs.com/product/55-3666.html?Category_Code=empi-vw-mufflers
You can see the pitting in the old header under the ceramic coat.
Cheers, dgsaz |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Wed Jun 28, 2017 4:16 pm Post subject: Re: Updated Engine, Exhaust much louder... Opinions |
The stainless Fatboy mufflers are loud as hell. I think they use as thin a gauge stainless as possible, and the mufflers are much louder than the plain steel equivalent, at least that's my experience.
I shit canned the stainless muffler from a stainless AA sidewinder, and modified a small magna flow to fit. Much less Honda-fart-can/ snare drum rattle, better constant low rumble. Might not be quieter, but certainly less harsh. _________________ modok wrote:
74 Thing Samba Member
Posted: Wed Jun 28, 2017 4:22 pm Post subject: Re: Updated Engine, Exhaust much louder... Opinions |
Get rid of your current muffler and go for a single quiet pack like in that photo with the bus and make sure you extend the exhaust tip past the rear bumper out the back. |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Wed Jun 28, 2017 6:34 pm Post subject: Re: Updated Engine, Exhaust much louder... Opinions |
Buy a Vintage Speed muffler, Annendorp BAS muffler, or other non-4-1 style system. It will hurt peak power, but will be quieter.
Also, not related, but unless your Kadron manifolds have been match-ported all the way to the top, with attention to maintaining the Panchitos' minimum cross-section, you're power is suffering. The Kad manifolds might even need welding to accomplish it. Hopefully you're not using the steel ones. |
54bug Samba Member
Posted: Fri Jun 30, 2017 5:57 am Post subject: Re: Updated Engine, Exhaust much louder... Opinions |
Hey All
Thanks for the replies. I'm going to try the smaller EMPI ceramic muffler... Hoping the reduction in noise isn't paired with a reduction in flow, more to come.
As Bugguy 1967 noted, the Kadronn manifolds needed a lot of work to match the new heads. I did heavy mods to a set of aluminum manifolds to get things to fit. Also needed a lot of work to smooth out the low quality castings.
Contemplating a new Header/Muffler, but that's for another day.
Scott |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12409 Location: Over 2002 posts deleted!
Posted: Fri Jun 30, 2017 7:10 am Post subject: Re: Updated Engine, Exhaust much louder... Opinions |
54bug wrote: |
Hey All
Scott |
You may get reduction in noise...
Until this happens!
Good luck! _________________ Some people are so busy being clever they don't have time enough to be wise. |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2745 Location: Hamble, Hampshire, UK
Posted: Fri Jun 30, 2017 10:15 am Post subject: Re: Updated Engine, Exhaust much louder... Opinions |
My EMPI muffler went like that afer a backfire. Some of the fragments hit the ground a second or so after the backfire.. _________________ Ancient vehicles and vessels
